gorro Skrevet 28. januar 2006 Del Skrevet 28. januar 2006 Hello, as usual I'm working for my norsk girlfriend When I was at her pc I enabled DMZ because she couldnt use emule. I've set DMZ enabled, and I've specified the ip addres that is assigned by router to the ethernet port. After this setting, she can use emule but msn 7.5 transferts of files r almost impossible(very very very slow), so I told her how to do to rechange the DMZ back to disabled. She sets it disabled and rewrites the ip of host dmz server back to 0.0.0.0., settings apply and restart. But after the restart it is still enabled and the host server still there. 1)why she cant turn it off anymore? 2)why msn transferts are slower with dmz on? Thanks Lenke til kommentar
Zerge Skrevet 28. januar 2006 Del Skrevet 28. januar 2006 I would say that there might be a bug in the firmware. You should probably get her to look for an upgraded firmware. About the msn transfer, I have no clue. The only thing I can say is that I have experienced alot of "speedproblems" with msn transfer before. Lenke til kommentar
gorro Skrevet 29. januar 2006 Forfatter Del Skrevet 29. januar 2006 I would say that there might be a bug in the firmware.You should probably get her to look for an upgraded firmware. About the msn transfer, I have no clue. The only thing I can say is that I have experienced alot of "speedproblems" with msn transfer before. 5514501[/snapback] Do you have the 871bt? I need help by someone using 871bt. Lenke til kommentar
