Hvordan får jeg bildene med på HotSaNIC?
Noen som vet hvordan jeg får med bildene på HotSaNIC ? slik som dette: http://hotsanic.sourceforge.net/example/index.html SLik den viser trafikk å sånt. Takker for svar.
5506786[/snapback]
RTFM
GENERATING WEB-STATISTICS
The images on the statistics pages will be built automatically by HotSaNIC every 15 minutes. If you like to build the graphs more ore less often, you are welcome to decrease or increas the time-base as you like by editing the main settings file. But be careful with too low timespans, because it will use more CPU time (which may be needed for more important tasks ... ).
Usually you should not have to worry about anything except the output-directory, which has to be configured correctly (you will have to enter the full path!) in the main settings file.
If not yet done, run makeindex.pl to generate all html files. The script will gather every module and build the necessary index-files for your webpage. In case you install a new module, just let HotSaNIC run a couple of minutes to inititalize the plugin's databases. Then you just call makeindex.pl again and it will rebuild all html files. New plugins can be installed quite "on the fly". Just copy it to the "modules" directory and add it to the RUN and SHOW entries in the main settings.
"rrdtimer" will call "convert.sh" about every 24h (timebase may be configured in main settings file). This script will generate pictograms on the main index page of your webstats from the actual weekly graphs. This will require "convert" from "ImageMagick" to be installed.
