HoaXed Skrevet 23. januar 2006 Del Skrevet 23. januar 2006 Heihei.. Jeg skal ha en logg inn boks på forsiden til hjemmesiden min, hvor man kan logge seg inn i cutenews. Etter å ha lest litt rundt på readme og hjelpe filer har jeg ikke funnet noe. Problemet er størelsen på koden, og hva som skal taes med.. Koden til index.php <?PHP /*************************************************************************** CuteNews CutePHP.com Copyright © 2005 Georgi Avramov ([email protected]) ****************************************************************************/ error_reporting (E_ALL ^ E_NOTICE); require_once("./inc/functions.inc.php"); //################# $PHP_SELF = "index.php"; $cutepath = "."; $config_path_image_upload = "./data/upimages"; $config_use_cookies = TRUE; // Use Cookies When Checking Authorization $config_use_sessions = FALSE; // Use Sessions When Checking Authorization $config_check_referer = TRUE; // Set to TRUE for more seciruty //################# $Timer = new microTimer; $Timer->start(); // Check if CuteNews is not installed $all_users_db = file("./data/users.db.php"); $check_users = $all_users_db; $check_users[1] = trim($check_users[1]); $check_users[2] = trim($check_users[2]); if((!$check_users[2] or $check_users[2] == "") and (!$check_users[1] or $check_users[1] == "")){ if(!file_exists("./inc/install.mdu")){ die('<h2>Error!</h2>CuteNews detected that you do not have users in your users.db.php file and wants to run the install module.<br> However, the install module (<b>./inc/install.mdu</b>) can not be located, please reupload this file and make sure you set the proper permissions so the installation can continue.'); } require("./inc/install.mdu"); die(); } require_once("./data/config.php"); if(isset($config_skin) and $config_skin != "" and file_exists("./skins/${config_skin}.skin.php")){ require_once("./skins/${config_skin}.skin.php"); }else{ $using_safe_skin = true; require_once("./skins/default.skin.php"); } b64dck(); if($config_use_sessions){ @session_start(); @header("Cache-control: private"); } if($action == "logout") { setcookie("md5_password",""); setcookie("username",""); setcookie("login_referer",""); if($config_use_sessions){ @session_destroy(); @session_unset(); setcookie(session_name(),""); } msg("info", "Logg ut", "Du er nå logget ut, <a href=\"$PHP_SELF\">Logg inn</a><br /><br>"); } $is_loged_in = FALSE; $cookie_logged = FALSE; $session_logged = FALSE; $temp_arr = explode("?", $HTTP_REFERER); $HTTP_REFERER = $temp_arr[0]; if(substr($HTTP_REFERER, -1) == "/"){ $HTTP_REFERER.= "index.php"; } // Check if The User is Identified if($config_use_cookies == TRUE){ /* Login Authorization using COOKIES */ if(isset($username)) { if(isset($HTTP_COOKIE_VARS["md5_password"])){ $cmd5_password = $HTTP_COOKIE_VARS["md5_password"]; } elseif(isset($_COOKIE["md5_password"])){ $cmd5_password = $_COOKIE["md5_password"]; } else{ $cmd5_password = md5($password); } // Do we have correct username and password ? if(check_login($username, $cmd5_password)) { if($action == 'dologin'){ setcookie("lastusername", $username, time()+1012324305); if($rememberme == 'yes'){ setcookie("username", $username, time()+60*60*24*30); setcookie("md5_password", $cmd5_password, time()+60*60*24*30); } else{ setcookie("username", $username); setcookie("md5_password", $cmd5_password); } } $cookie_logged = TRUE; }else{ setcookie("username", FALSE); setcookie("md5_password", FALSE); $result = "<font color=red>Feil brukernavn og/eller passord</font>"; $cookie_logged = FALSE; } } /* END Login Authorization using COOKIES */ } if($config_use_sessions == TRUE){ /* Login Authorization using SESSIONS */ if(isset($HTTP_X_FORWARDED_FOR)){ $ip = $HTTP_X_FORWARDED_FOR; } elseif(isset($HTTP_CLIENT_IP)) { $ip = $HTTP_CLIENT_IP; } if($ip == "") { $ip = $REMOTE_ADDR; } if($ip == "") { $ip = "not detected";} if($action == "dologin") { $md5_password = md5($password); if(check_login($username, $md5_password)){ $session_logged = TRUE; @session_register('username'); @session_register('md5_password'); @session_register('ip'); @session_register('login_referer'); $_SESSION['username'] = "$username"; $_SESSION['md5_password'] = "$md5_password"; $_SESSION['ip'] = "$ip"; $_SESSION['login_referer'] = "$HTTP_REFERER"; }else{ $result = "<font color=red>Feil brukernavn og/eller passord</font>"; $session_logged = FALSE; } }elseif(isset($_SESSION['username'])){ // Check the if member is using valid username/password if(check_login($_SESSION['username'], $_SESSION['md5_password'])){ if($_SESSION['ip'] != $ip){ $session_logged = FALSE; $result = "IP'en din ble ikke godkjent. Kontakt webansvarlig!"; } else{ $session_logged = TRUE; } }else{ $result = "<font color=red>Feil brukernavn og/eller passord!</font>"; $session_logged = FALSE; } } if(!$username){ $username = $_SESSION['username']; } /* END Login Authorization using SESSIONS */ } ########################### if($session_logged == TRUE or $cookie_logged == TRUE){ if($action == 'dologin'){ //------------------------------------------- // Modify the Last Login Date of the user //------------------------------------------- $old_users_db = $all_users_db; $modified_users = fopen("./data/users.db.php", "w"); foreach($old_users_db as $old_users_db_line){ $old_users_db_arr = explode("|", $old_users_db_line); if($member_db[0] != $old_users_db_arr[0]){ fwrite($modified_users, "$old_users_db_line"); }else{ fwrite($modified_users, "$old_users_db_arr[0]|$old_users_db_arr[1]|$old_users_db_arr[2]|$old_users_db_arr[3]|$old_users_db_arr[4]|$old_users_db_arr[5]|$old_users_db_arr[6]|$old_users_db_arr[7]|$old_users_db_arr[8]|".time()."||\n"); } } fclose($modified_users); } $is_loged_in = TRUE; } ########################### // If User is Not Logged In, Display The Login Page if($is_loged_in == FALSE) { if($config_use_sessions){ @session_destroy(); @session_unset(); } // setcookie("username",""); // setcookie("password",""); // setcookie("md5_password",""); // setcookie("login_referer",""); echoheader("bruker","Vennligst Logg inn"); if($config_allow_registration == "yes"){ $allow_reg_status = "<a href='register.php'>(registrer)</a> "; }else{ $allow_reg_status = ""; } echo " <table width=\"100%\" border=0 cellpadding=1 cellspacing=0> <form name=login action='$PHP_SELF' method=post> <tr> <td width=80>Brukernavn: </td> <td width='160'><input tabindex=1 type=text name=username value='$lastusername' style='width:150;'></td> <td> $allow_reg_status</a></td> </tr> <tr> <td>Passord: </td> <td><input type=password name=password style='width:150'></td> <td> <a href='register.php?action=lostpass'>(Mistet passordet?)</a> </td> </tr> <tr> <td></td> <td style='text-align:left'> <input accesskey='s' type=submit style=\"width:150; background-color: #F3F3F3;\" value=' Logg inn... '><br/> </td> <td style='text-align:left'><label for=rememberme title='Husk meg i 30 dager. Vennligst ikke gjør dette vis andre personer har tilgang til din datamaskin!'> <input id=rememberme type=checkbox value=yes style=\"border:0px;\" name=rememberme> Husk meg</label> </td> </tr> <tr> <td align=center colspan=4 style='text-align:left;'>$result</td> </tr> <input type=hidden name=action value=dologin> </form> </table>"; echofooter(); } elseif($is_loged_in == TRUE) { //---------------------------------- // Check Referer //---------------------------------- if($config_check_referer == TRUE){ $self = $_SERVER["SCRIPT_NAME"]; if($self == ""){ $self = $_SERVER["REDIRECT_URL"]; } if($self == ""){ $self = "index.php"; } if(!eregi("$self",$HTTP_REFERER) and $HTTP_REFERER != ""){ die("<h2>Sorry but your access to this page was denied !</h2><br>try to <a href=\"?action=logout\">logout</a> and then login again<br>To turn off this security check, change \$config_check_referer in index.php to FALSE"); } } // ******************************************************************************** // Include System Module // ******************************************************************************** if($HTTP_SERVER_VARS['QUERY_STRING'] == "debug"){ debug(); } //name of mod //access $system_modules = array('addnews' => 'user', 'editnews' => 'user', 'main' => 'user', 'options' => 'user', 'images' => 'user', 'editusers' => 'admin', 'editcomments' => 'admin', 'tools' => 'admin', 'ipban' => 'admin', 'about' => 'user', 'preview' => 'user', 'categories' => 'admin', 'massactions' => 'user', 'help' => 'user', 'snr' => 'admin', 'debug' => 'admin', 'wizards' => 'admin', ); if($mod == ""){ require("./inc/main.mdu"); } elseif( $system_modules[$mod] ) { if( $member_db[1] == 4 and $mod != 'options'){ msg('error', 'Error!', 'Access Denied for your user-level (commenter)'); } elseif( $system_modules[$mod] == "user"){ require("./inc/". $mod . ".mdu"); } elseif( $system_modules[$mod] == "admin" and $member_db[1] == 1){ require("./inc/". $mod . ".mdu"); } elseif( $system_modules[$mod] == "admin" and $member_db[1] != 1){ msg("error", "Access denied", "Only admin can access this module"); exit; } else{ die("Module access must be set to <b>user</b> or <b>admin</b>"); } } else{ die("$mod is NOT a valid module"); } } echo"<!-- execution time: ".$Timer->stop()." -->"; ?> Noen som kan hjelpe og skjønner hva jeg mener Lenke til kommentar
neivoll Skrevet 23. januar 2006 Del Skrevet 23. januar 2006 http://cutephp.com/forum/index.php?showtopic=48 Lenke til kommentar
HoaXed Skrevet 24. januar 2006 Forfatter Del Skrevet 24. januar 2006 Takk, fungerte glimrende Lenke til kommentar
