Hjelp til samba (fedora core 4)
sliter med å få samba opp og gå. prøver å connecte med smbclient (på samme maskin) og får følgende melding etter å ha blitt spurt om passord og skrevet det inn:
session setup failed: Call timed out: server did not respond after 20000 milliseconds
[veggiss@linuxveggiss log]$ cat /etc/samba/smb.conf
# workgroup = NT-Domain-Name or Workgroup-Name
  workgroup = WORKGROUP
  server string = sambaveggiss
  valid users = veggiss
  hosts allow = 127.0.0.1 192.168.0.100/108
  hosts deny = 0.0.0.0/0
log file = /var/log/samba/%m.log
# all log information in one file
#   log file = /var/log/samba/log.smbd
# Put a capping on the size of the log files (in Kb).
  max log size = 50
# Security mode. Most people will want user level security. See
# security_level.txt for details.
  security = user
  dns proxy = no
# Case Preservation can be handy - system default is _no_
# NOTE: These can be set on a per share basis
;  preserve case = no
;  short preserve case = no
# Default case is normally upper case for all DOS files
;  default case = lower
# Be very careful with case sensitivity - it can break things!
;  case sensitive = no
#============================ Share Definitions ==============================
  idmap uid = 16777216-33554431
  idmap gid = 16777216-33554431
  template shell = /bin/false
  winbind use default domain = no
[homes]
  comment = Home Directories
  browseable = yes
  writable = yes
[veggiss]
       path = /home/veggiss
       writeable = yes
       browseable = yes
testparm gir disse resultatene:
Load smb config files from /etc/samba/smb.conf
Processing section "[homes]"
Processing section "[veggiss]"
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
       max log size = 50
       dns proxy = No
       cups options = raw
[homes]
       read only = No
aner ikke om det er et firewall problem heller, her er status på iptables (tror jeg)
[root@linuxveggiss log]# /sbin/iptables -L -v
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target     prot opt in     out     source               destination
   0     0 RH-Firewall-1-INPUT  all  --  any    any     anywhere             an     ywhere
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
112K  127M RH-Firewall-1-INPUT  all  --  any    any     anywhere             an     ywhere
Chain OUTPUT (policy ACCEPT 66805 packets, 5061K bytes)
Chain RH-Firewall-1-INPUT (2 references)
1047  102K ACCEPT     all  --  lo     any     anywhere             anywhere
  14  1080 ACCEPT     icmp --  any    any     anywhere             anywhere                 icmp any
   0     0 ACCEPT     ipv6-crypt--  any    any     anywhere             anywher     e
   0     0 ACCEPT     ipv6-auth--  any    any     anywhere             anywhere
  15  1461 ACCEPT     udp  --  any    any     anywhere             224.0.0.251              udp dpt:5353
   0     0 ACCEPT     udp  --  any    any     anywhere             anywhere                 udp dpt:ipp
104K  126M ACCEPT     all  --  any    any     anywhere             anywhere                 state RELATED,ESTABLISHED
   5   240 ACCEPT     tcp  --  any    any     anywhere             anywhere                 state NEW tcp dpt:ssh
   0     0 ACCEPT     tcp  --  any    any     anywhere             anywhere                 state NEW tcp dpt:ftp
6018  854K REJECT     all  --  any    any     anywhere             anywhere                 reject-with icmp-host-prohibited
hvis noen greier å tyde dette og finne ut hva som er galt, evt hjelpe meg med feilsøking så blir jeg glad, kanskje du får en klemz :p
Endret av veggiss
scannet boksen med nmap, og fikk følgende resultater:
Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2006-01-22 19:20 CET
Interesting ports on 192.168.0.101:
(The 1472 ports scanned but not shown below are in state: closed)
PORT      STATE         SERVICE
111/udp   open|filtered rpcbind
137/udp   open|filtered netbios-ns
138/udp   open|filtered netbios-dgm
631/udp   open|filtered unknown
897/udp   open|filtered unknown
32768/udp open|filtered omad
Nmap finished: 1 IP address (1 host up) scanned in 11.677 seconds
slo så av firewallen, men fremdeles ingen kontakt....arghh!
Vet ikke hvordan det er hos deg, men min Samba på FC4 lytter på denne måten:
# netstat -tpan | grep LISTEN
tcp        0      0 0.0.0.0:139                 0.0.0.0:*                   LISTEN      2533/smbd
tcp        0      0 0.0.0.0:445                 0.0.0.0:*                   LISTEN      2533/smbd
Endret av buskmann
tcp        0      0 0.0.0.0:139                 0.0.0.0:*                   LISTEN      11546/smbd
tcp        0      0 0.0.0.0:445                 0.0.0.0:*                   LISTEN      11546/smbd
snodig...samme som meg, bortsett fra 11546, er det prosess id ellerno?
har du mulighet til å poste smb.conf, eller utdrag av den hvertfall? jeg hadde dette oppe å gå med fedora core 1 før pcen tryna, men nå vil det seg sannelig ikke.
Endret av veggiss
Prøvd å bare kommentere ut "host allow"?
5482022[/snapback]
gjorde det nå, men fremdeles ikke noe som skjer. virker som det er ett eller annet som bøgger med smb.conf eller samba, for jeg får spørsmål om passord, men så blir det timeout.
okkk...nå blanker jeg smb.conf, og prøver med en helt enkel en:
[global]
netbios name = SAMBA
[share1]
path = /tmp
[share2]
path = /home/veggiss/Music
comment = Musikk
niks, virket heller ikke, kan også luke ut smb.conf som sted for feilen da.
fant følgende i smbd.log
[2006/01/22 22:21:26, 0] lib/util_sock.c:get_peer_addr(1150)
 getpeername failed. Error was Transport-endepunktene er ikke sammenkoblet
Endret av veggiss
hvis du ser noe om audit-ett-eller-annet samtidig med du forsøker å koble til... Eventuelt er en annen mulighet tcp-wrappers.. /etc/hosts.*
Uansett vil jeg kanskje anbefale at du kjører fixfiles relabel og tar en reboot.
Og en annen ting; så vidt jeg husker skal det være mulig å legge på en -v eller to og få litt mer info om hva smbclient driver med.. Så kan det hende du klarer å lokalisere feilen..
Endret av xeon
når jeg starter maskinen så lytter den ikke på samba portene, virker som om samba ikke kjører, eller har feilet under oppstart. tar jeg smb restart så ser jeg at den lytter på portene med netstat. får fremdeles samme beskjeden når jeg prøver å koble til.
@Torbjørn: jeg kjører alt dette på terminalvindu. selv om jeg slår av firewallen så får jeg samme feilmeldinger.
ah, ser det nå. dette virker rart. har aldri vært borti noe lignende og jeg har brukt fedora i mange år med samba på nesten hver boks jeg har installert.
5483163[/snapback]
ja...skjønner ikke bæret jeg heller. jeg begynner nesten å mistenke at det er en corrupt innstallasjon eller at jeg fjernet noen pakker som jeg ikke skulle ha fjernet under innstallasjonen (er helt fersk innstall). tipper jeg reinnstallerer i morgen, så får vi se om det hjelper. orker ikke gruble mer på dette nå, kan liksom ikke skjønne hva jeg skal gjøre som jeg ikke har gjort.
5481998[/snapback]
Vedlagt.
Du kan skru opp loglevel for mer "verbose" logging.
5483331[/snapback]
takk for den. reinnstallerer alt nå, så får vi se hva som skjer. enten så funker det, eller så går maskina på dynga, og jeg kjøper meg et lass eksterne disker og en linksys boks som setter dem i nettverk..hehe
da var maskinen rettet for nå...får logget inn som bare det etter en reinnstall. tror jeg fjernet en pakke eller to for mye ellerno under den første innstallen. nå funker det hvertfall.
takk for all hjelpe dere som har bidratt!
kozemozeoverdoze :p
