karl hungus Skrevet 12. september 2002 Del Skrevet 12. september 2002 jeg får følgende feilmelding når jeg installerer sp1 på en nyformatert disk med xp pro : "failed to install catalog files" hva kan dette skyldes?? Lenke til kommentar
ZoRaC Skrevet 12. september 2002 Del Skrevet 12. september 2002 At cab-filene er corrupte kanche? I don't know... :razz: Lenke til kommentar
karl hungus Skrevet 12. september 2002 Forfatter Del Skrevet 12. september 2002 tror ikke det, sp1-fila brant jeg fra en annen maskin hvor installeringen gikk smertefritt.. Lenke til kommentar
kåre klut Skrevet 12. september 2002 Del Skrevet 12. september 2002 Fant dette på TweakTown forum: Quote: Took the advise and did a search in microsoft knowlege base. Found the solution and sucessfully install SP1, but after two tries. So if anybody have similar problem here is the solution that worked for me. 1. Go to Microsoft Knowlege base page and type" Failed to installed catalog file" , in Windows SP 2. Search results will show tons of article/solution, but I picked the most appropriate one which is the fist one on th elist 3. According to the article, the catalog files were corrupted so need to rename it as old, in this case deb.old in CatRoot2 directory under Windows/Systems32/CatRoot2 4. Two methods either rename the deb log file or rename the whole CatRoot2 directory 5. First method failed in my case - it says something about Cryptographic Service not active - as somenone posted in another post 6. So try method 2 - rename the whole CatRoot2 to catroot.old. Close Windows Explorer. 7. Install SPI - voila!... I think my system is a tad faster now.. http://forums.tweaktown.com/showthread.php...=&threadid=4602 Lenke til kommentar
Mumiene Skrevet 14. september 2002 Del Skrevet 14. september 2002 Bruker dere samme cd key ?? Lenke til kommentar
