Pc til maks 5000,- ?
Fra PSData:
AOPEN CD-RW 40X/12X/48X ATAPI Internal Bulk WO/SW, CRW4048B
545
WD Harddisk 80.0GB IDE 7200RPM UDMA-100 3.5"
949
Chieftec Case Midi ATX Tower 300W, TG-10W
695
GLACIAL Cooling Fan Socket A/370 All PIII/Celeron AMD Up-To 1.97GHz Low Noise 25dB, IGLO 2310
149
2 stk APACER Memory 256MB PC-266 DDR Original PC2100, 256MB PC-266
1250
AMD CPU Athlon XP 1800 1.53GHz Socket A 266FSB Tray
699
ASUS Mainboard Socket-A nForce220 MicroATX LAN Audio VGA, A7N266-VM LAN
775
Sum 5062,-
[ Denne Melding var redigert av: Blippblopp på 2002-09-12 10:08 ]
AMD Athlon XP1800+ 1.53 GHz 266 MHz bus
KR 735
Asus A7S333 Hovedkort for Socket A DDR
KR 750
IBM Deskstar 60GB IDE 7200RPM
KR 950
Creative 3DBlaster GeForce3 Ti200 64MB
KR 920
DDR-DIMM PC2100 256MB DDR CL2.5
KR 554
Cooler Master CPU-Vifte Socket A/7/FCPGA
KR 139
Chieftec Matrix Medium Tower m/dør Sort
KR 920
SUM=4968kr
Hentet fra komplett.no
[ Denne Melding var redigert av: Citizenx på 2002-09-15 22:12 ]
