Viser bare en kjerne i task manager?
Carridhin
Regner med at du bruker Windows XP?
For example, with dual core servers, Windows 2000 Server "sees" each core as a separate processor.  Windows 2003 Server, on the other hand, sees each socket as a processor.  That's because Windows 2003 Server was built with an "understanding" of dual core and hyperthreadable procs.  This will make a big difference on which operating system you choose for your dual-core boxes, especially if they are 4-ways.  For example, Windows 2000 will think that a 4-way dual core server is actually an 8-way.  This makes it necessary to run either Windows 2000 Advanced Server or Windows 2000 Datacenter Server.  This is because, Windows 2000 Server (standard) will only utilize 4 processors (in this case, 4 of the 8 cores).
http://64.233.183.104/search?q=cache:ZqZgQ...nn&client=opera
Ikke minst; Viser det 2 CPUer i BIOS? (Maskinen ser på det som 2 CPUer)
