Dual scsi i linux Fedora.
Hei,
Jeg satte opp en dual scsi drive på Linux I går, men fant ut at kun lun 0 var støttet som default.
Jeg har litt dårlig tid og ikke tid til å teste in-house eller lese mye så jeg tar den mest lettvinte løsningen, spør om noen andre kjapt kan fortelle meg hvordan jeg aktiverer lun 1 også.
Tilleggsinfo er,
Fedora Core 2 , kernel 2.6.5-1.358
Scsikort er Adaptec 2944UW
Problemet er at kunden har en del info i systemet han har atm. men fant dette på nett :
7.1 Enable more than 1 scsi device per adapter
Support for multiple LUNs can be configured in one of three ways.
Currently, the maximum number of LUNs that can be scanned for each device is 256.
(1) The kernel must be configured to have multiple LUN support enabled
in order for non-zero LUNs to be configured and accessible. Use
"make menuconfig" to build a kernel which has the option under
SCSI Support enabled to probe all LUNs on SCSI devices.
NOTE: If you have multiple adapters, set max_scsi_luns to the
largest number of LUNs supported by any one of these adapters.
(2) If the SCSI Mid-Layer is compiled in the kernel, the boot loader
can be configured to scan for multiple LUNs each time the system
boots.
On IA-32 and AMD-64
For RedHat Distribution :
a) Append the max_scsi_luns parameters to each of the kernel images
listed in the /etc/grub.conf file. For example:
kernel /vmlinux-2.6.9-5 ro root=/dev/hda2 max_scsi_luns=256
b) Reboot the system.
For SuSE Distribution :
listed in the /boot/grub/menu.lst file. For example:
kernel (hd0,1)/boot/vmlinuz root=/dev/hda2 max_scsi_luns=256
On IA-64
a) Add the following line to each of the kernel images listed in the
/boot/efi/efi/redhat/elilo.conf
append="max_scsi_luns=256"
/boot/efi/SuSE/elilo.conf
(3) If the SCSI Mid-Layer is compiled as a module, add the following
line to the /etc/modprobe.conf[.local] file to scan for multiple LUNs at
each boot:
options scsi_mod max_scsi_luns=256
Refer to your Linux distribution documentation to verify the steps to
rebuild the boot image and ramdisk for your distribution.
Section 7.5 of this readme does cover some of the steps required to
rebuild your initrd image.
Trur det skal gjøre susen....
Her har du det. Rediger /etc/grub.conf. og endre kommandolinja for den aktuelle kjerna slik som det står her. Reboot til den aktuelle kjerna.
