loggon Skrevet 11. januar 2006 Del Skrevet 11. januar 2006 Problemene begynte etter firmware oppdatering, har forsøkt med reseting til factrory setting uten bedring. WiFig 3Com 3CRWE554G72 Welcome to the OfficeConnect Wireless 11g Cable/DSL Gateway Version 1.02.15 You are logged in as administrator ! Wireless Encryption is Switched off ! Please select the mode that applies to your ISP from the list below (If unsure, please contact your ISP): PPPoE is required (typically DSL users only) ISP provides configuration dynamically (via DHCP) ISP has provided a static IP address PPTP is required (some DSL users in Europe) Configuration Summary You have now completed the Gateway Configuration Wizard, and a summary of your chosen configuration is shown below. Wireless Channel 11 Service Area Name/SSID 3Com LAN IP Address 192.168.1.1 LAN Subnet Mask 255.255.255.0 DHCP Server Enable IP Pool Range 192.168.1.2 ~ 192.168.1.254 Internet Addressing Mode Dynamic Hostname MAC Address for Internet Connection Not cloned Timezone (GMT+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna Enable Daylight savings NO Note that no settings are saved until you press 'Finish' - to go back and make any changes, press 'Back'. To exit without saving the changes, press 'Cancel'. 2006/01/11 18:23:35 : FLASH TEST....................PASS 2006/01/11 18:23:35 : WAN ETHER TEST...........PASS 2006/01/11 18:23:35 : WLAN TEST....................PASS 2006/01/11 18:23:35 : DHCP client release. 2006/01/11 18:23:35 : DHCP Client : Send Discover 2006/01/11 18:23:35 : DHCP Client : Send Discover 2006/01/11 18:23:37 : DHCP Client : Receive Offer from 62.179.100.9 2006/01/11 18:23:39 : DHCP Client : Send Request, Request IP = 62.179.241.244 2006/01/11 18:23:39 : DHCP Client : Receive Ack from 62.179.100.9, Lease time = 604798 2006/01/11 18:23:40 : Dhcp client renew 2006/01/11 18:23:40 : Get Ip = 62.179.241.244 2006/01/11 18:23:40 : Get Netmask = 255.255.252.0 2006/01/11 18:23:40 : Get Gateway[0] = 62.179.240.1 2006/01/11 18:23:40 : Get Dns[0] = 62.179.100.35 2006/01/11 18:23:40 : Get Dns[1] = 62.179.100.36 2006/01/11 18:23:40 : Set WAN Subnet Mask = 255.255.252.0 2006/01/11 18:23:40 : Set Gateway IP = 62.179.240.1 2006/01/11 09:25:42 : Blocked access attempt from 221.208.208.5 2006/01/11 09:25:59 : Blocked access attempt from 62.179.233.97 2006/01/11 09:26:16 : 192.168.100.22 login Successful 2006/01/11 09:26:44 : Blocked access attempt from 62.179.229.227 2006/01/11 09:27:30 : Blocked access attempt from 62.179.217.187 2006/01/11 09:27:50 : Blocked access attempt from 204.16.208.67 2006/01/11 18:28:09 : DHCP client release. 2006/01/11 18:28:09 : DHCP Client : Send Release 2006/01/11 18:28:09 : DHCP Client : Send Discover 2006/01/11 18:28:09 : DHCP Client : Receive Offer from 62.179.100.9 2006/01/11 18:28:11 : DHCP Client : Send Request, Request IP = 62.179.241.244 2006/01/11 18:28:11 : DHCP Client : Receive Ack from 62.179.100.9, Lease time = 604800 2006/01/11 18:28:12 : Dhcp client renew 2006/01/11 18:28:12 : Get Ip = 62.179.241.244 2006/01/11 18:28:12 : Get Netmask = 255.255.252.0 2006/01/11 18:28:12 : Get Gateway[0] = 62.179.240.1 2006/01/11 18:28:12 : Get Dns[0] = 62.179.100.35 2006/01/11 18:28:12 : Get Dns[1] = 62.179.100.36 2006/01/11 18:28:12 : Set WAN Subnet Mask = 255.255.252.0 2006/01/11 18:28:12 : Set Gateway IP = 62.179.240.1 2006/01/11 18:28:32 : Blocked access attempt from 62.179.250.139 Status and Logs Status Usage Logs General Information 3C number 3CRWE554G72 Software version V1.02.15 Boot loader version V1.00.00 Wireless version V1.0.1.0 Hardware version R01A Serial Number 73CF359A2FAC6 Access From the Internet Discard PING from the internet side Yes Firewall Switched On Yes Internet Settings PPP over Ethernet Enabled No Internet IP Address 62.179.241.244 Dynamic IP Subnet Mask 255.255.252.0 ISP Gateway Address 62.179.240.1 Connected DNS 62.179.100.35 ; 62.179.100.36 Remaining Lease Time 6 days, 23:58:40 MAC Address 00-0D-54-A2-FA-C7 LAN Settings LAN IP Address 192.168.1.1 LAN Subnet Mask 255.255.255.0 Gateway's DHCP Server Enabled DHCP Range 192.168.1.2 to 192.168.1.254 LAN Port MAC Address 00-0D-54-A2-FA-C6 Wireless Settings Wireless Networking Enabled Yes Channel 11 Service Area Name/SSID 3Com WPA Encryption Disabled WEP Encryption Disabled Wireless MAC Address 00-0D-54-A2-FA-C6 Hardware Status Port Speed Duplex Cable / DSL Port 100 Full Duplex LAN Port #1 100 Full Duplex LAN Port #2 No Link No Link LAN Port #3 No Link No Link LAN Port #4 100 Full Duplex Internet time: Wed Jan 11 18:29:29 2006 Copyright © 2001 3Com Corporation. All Rights Reserved. Lenke til kommentar
shadowano Skrevet 17. november 2006 Del Skrevet 17. november 2006 Hei Jeg har en 3com ruter selv, 3CRWE554G72, samme som du. Jeg har funnet ut følgende feil ved ruteren og firmwarene: 3crwe554g72_01_02_13 Ved mange UDP tilkoblinger så crasher ruteren og går tilbake til fabrikkinnstillinger. All kryptering osv forsvinner. Skjedd meg mange ganger ved nedlasting av torrent osv 3crwe554g72_01_02_15 Siste firmware oppgradering. Denne fikser UDP problemet beskrevet over, men har en enda mer morsom feil. Kobler du kabel til ruteren så kan nettforbindelsen forsvinne plutselig. Du kommer ikke inn igjen på webgrensesnittet på ruteren. Det finnes to løsninger (i mitt tilfelle): ta ut strøm på ruteren og sett i etter 2 min, ELLER koble til via trådløst. Når jeg kobler til via trådløst så er plutselig maskin med kabel på nett igjen. En maskin jeg har stående på hele døgnet med kabel faller ut av nettet hver natt (og da bruker jeg trådløst med laptop på dagen/kvelden). Løsningen min ble å gå tilbake til firmware 01_02_13 og heller styre UDP tilkoblingene littegranne. Nå er iallefall pc'ene på nett helt til ruteren crasjer pga UDP tilkoblinger Håper dette hjalp deg noe Lenke til kommentar
