Marihuana, hasj, cannabis - farlig eller ikke?
Har du prøvd hasj?
2 342 stemmer
  1. 1. Har du prøvd hasj?
    • - Ja.
      875
    • - Ja, men jeg kommer ikke til å gjøre det igjen.
      157
    • - Nei.
      890
    • - Nei, men jeg kunne tenke meg å prøve det.
      449
Kilden din kunne jo ha sitert resten av artikkelen (som de linker til):
Whether this is true for all cannabinoids remains unclear, as HU-210 is only one of many and the HU-210 in the study is highly purified.
“That does not mean that general use in healthy people is beneficial,” said Memorial psychology professor William McKim. “We need to learn if this happens in humans, whether this is useful in healthy people, and whether THC causes it as well.”
McKim warns that marijuana disrupts memory and cognition. “These effects can be long-lasting after heavy use,” he said. “This makes it difficult to succeed academically if you use it excessively.”
“Occasional light use probably does not have very serious consequences. [but] there is some evidence that marijuana smoke might cause cancer.”
Still, the positive aspects of marijuana are becoming more plentiful as further research is done. McKim says it’s not surprising that THC and compounds like it could have medicinal effects.
“Many have been identified,” he said. “It stimulates appetite in people with AIDS, it is an analgesic, and blocks nausea in cancer patients undergoing chemotherapy. And it treats the symptoms of glaucoma.”
The research group’s next studies will examine the more unpleasant side of the drug.
Så de vet ikke om det skjer i mennesker, de vet ikke om det skjer med naturlig THC eller bare denne ene (og 100 x sterkere) syntetiske varianten, og advarer om at marihuana forstyrrer hukommelsen. Så resultatet kan være at du får mer hjerne å huske med, men ikke klarer å bruke den? :p
Noen får poste en link når de er ferdig å forske på skadevirkningene...
Geir :)
Det stod ikke at det var THC som skapte den positive effekten, men CBN (cannabinoider). Det stod at de måtte finne ut om THC skapte denne effekten også.
6765922[/snapback]
Nettopp. Men den biten av historien hadde ikke siden terhi linket til brydd seg med å sitere. De tok bare med den hyggelige "smoking pot can make the brain grow" delen av historien.
Geir :)
Jepp, THC er visst en cannabinoid, min feil.
THCV (Tetrahydrocannabivarin) is found primarily in strains of African and Asian cannabis. THCV increases the speed and intensity of THC effects, but also causes the stone to end sooner. Weed that smells strong (prior to smoking) might indicate a high level of THCV.
Psykoaktivt.
CBD (Cannabidiol) increases some of the effects of THC and decreases other effects of THC. High levels of THC and low levels of CBD contribute to a strong, clear headed, more energetic stone.
Cannabis that has a high level of both THC and CBD will produce a strong head-stone that feels almost dreamlike. Cannabis that has low levels of THC and high levels of CBD produces more of a buzz. The mind feels dull and the body feels tired.
Psykoaktivt? Nah.
CBN (Cannabinol) is produced as THC ages and breaks down, this process is known as oxidization. High levels of CBN tend to make the user feel messed up rather than high.
CBN levels can be kept to a minimum by storing cannabis products in a dark, cool, airtight environment. A vacuum packed, light-proof container stored in a frost free freezer is recommended. Marijuana should be dry prior to storage.
Psykoaktivt.
CBC is believed not to be psychotomimetic in humans; however, its presence in plants is purportedly very potent has led to the suspicion that it may be interacting with THC to enhance the high.
Sikkert ikke psykoaktivt, men har en effekt.
Men så er det oppdaget hundrevis av andre stoffer som også skal ha en viss effekt.
Endret av ArmenMinAU
Psykoaktivt.
Nei.
Fra fyren som skjeller ut folk som bruker wikipedia som kilde....
6770736[/snapback]
Har aldri flamet noen som har brukt Wikipedia. Les det som faktisk står i innleggene mine før du pirker (om du pirker uten å ha lest, fremstår du kun som en idiot), jeg kritiserte en subjektiv Wikipedia-artikkel som en person linket til, og sa ingenting negativt om den personen.
Javel, hvordan vet vi at det som du postet i Wikipedia er sant?
Men ja det er vel ikke psykoaktivt. Men det er likevel en del av Cannabis. Dessuten har disse stoffene innvirkning (ikke bare på rusen).
6770835[/snapback]
Artiklene om cannabinoider er bra skrevet, så jeg tviler på at de inneholder mye feil.
Selvfølgelig har de (til en viss grad) innvirkning, men biologisk sett ville det vært ugunstig om det eliminerte THC-en.
Kort sagt gir THC hovedrusen, altså blir det feil å sammenligne marihuana med sprit, eller generelt sammenligne sluttprodukt med råvare.
Endret av superseven
Men herregud da.
Dette er verken en THC diskusjon eller en CBD diskusjon, men en Cannabisdiskusjon. Stoffene i Cannabis har alle innvirkninger på rusen som sagt tidligere. THC utgjør en liten prosent av Marihuana uansett (mer enn alle andre stoffer (omtrent 5-15%)).
Hvis du vil sammenligne Alkohol, så ikke sammenlign Øl eller noe lignende da dette blir som om jeg skulle sammenligne Cannabis som jeg hadde blandet inn i en kake.
Cannabis består kun av seg selv, mens alkoholiserte drikker (øl, vin, whisky osv.) består av mange andre ting enn kun Alkohol.
Dessuten er det et kjent faktum at typen Cannabis Indica gir en mer stein/sedaterende rus, og at denne typen inneholder mye mindre THC og mer CBD, mens Cannabis Sativa inneholder mer THC og mindre CBD, som gir en mer energisk "Up-high" rus. Forholdet mellom ulike Cannabinoider er det som bestemmer hvordan rusen oppleves.
Innholdet av cannabinoider og fordelingen
mellom dem er det som bestemmer
hvordan rusen vil
oppleves. Sativavariantene
er kjent for å ha en veldig
klar energisk og ”up high” rus.
Dette antar man skyldes at de inneholder
mer THC i forhold til CBD enn indicaplantene.
Tilsvarende er rusen fra en indica mer
sedaterende og gjør deg ”stein”. Dette antar
man at skyldes innvirkning fra et høyere innhold
av CBD.
Det finnes også to andre typer som heter Cannabis Ruderalis og Cannabis Rasta, men tror det er slik at Indica og Sativa er mer særegne når det kommer til rusen.
Drikker du et par mornings øl hver dag, og en sixpack på dagen og avslutter med noen nattis øl så blir det fort skadelig. Røyker du ei bønne på fredagskvelden er ikke det like farlig.
6773372[/snapback]
Røyker du et par mornings hver dag, og en en håndfull utover dagen og avslutter med noen på natten så blir det fort skadelig. Drikker du en halvliter øl på fredagskvelden er ikke det like farlig.
Geir :)
6773372[/snapback]
Geir :)
6773428[/snapback]
Hehe, ble litt rar den ja :whistle:
Men den siste påstanden din kan diskuteres.
6773372[/snapback]
Geir :)
6773428[/snapback]
6773513[/snapback]
En halvliter på fredagskvelden er dokumentert sunt. Hadde alkohol i små til moderate mengder vært skadelig, hadde alkohol også vært et narkotikum.
Ang. det forrige innlegget ditt: Cannabisen når den er ferdig tilberedt, er et sluttprodukt, det er også øl når den er ferdig. Sluttprodukt skal sammenlignes med sluttprodukt; alkohol i rein form er ikke st sluttprodukt.
I cannabis vet jeg ikke om andre cannabinoider enn THC, og THV som er psykoaktive, THV finnes det minimalt av.
6773372[/snapback]
Geir :)
6773428[/snapback]
Det er i prinsippet poenget mitt. Alt man tar for mye av blir skadelig, og det man gjør en sjelden gang blir ikke like skadelig. Men som oftest pleier man å si at hasj er så farlig fordi de som røyker tett blir skada. Uten å nevne i samme åndedrag at de som drikker tett også blir skadd. Alkoholisme er like ille som narkomani.
http://www.jointogether.org/news/features/...-dangerous.html
Virker ikke sånn på meg. Dessuten når vi snakker om sunnhet så er vel det ikke så altfor sundt med ølmage?
Alkohol i små moderate mengder ER skadelig, og ihvertfall over tid. Narkotika er ikke benevnelsen på at disse stoffene er farligere enn andre, men at disse stoffene er ulovlige. Alkohol er på linje med de sterkere narkotiske stoffene når det kommer til hvor farlig det er. Det var ulovlig en stund tidlig på 1900-tallet, men ble lovlig igjen da det viste seg at flere ble alkoholikere og drakk i denne tiden. Cannabis sitt forbud er derimot opprettet pga. propaganda og sprøyt fra gamledager:
"There are 100,000 total marijuana smokers in the US, and most are Negroes, Hispanics, Filipinos, and entertainers. Their Satanic music, jazz, and swing, result from marijuana use. This marijuana causes white women to seek sexual relations with Negroes, entertainers, and any others."
"...the primary reason to outlaw marijuana is its effect on the degenerate races."
"Marijuana is an addictive drug which produces in its users insanity, criminality, and death."
"Reefer makes darkies think they're as good as white men."
"Marihuana leads to pacifism and communist brainwashing"
"You smoke a joint and you're likely to kill your brother."
"Marijuana is the most violence-causing drug in the history of mankind."
Noe å se på BTW:
Cannabis er en plante og består kun av seg selv og sine egne stoffer. Tilberede cannabis kan man gjøre på mange måter, eller den kan tilberede seg selv. Øl er ikke en naturlig plante. Den består av en haug med ulike stoffer som er blandet sammen. De andre stoffene i Øl er ikke psykoaktive, men Alkohol er. Cannabis har flere psykoaktive stoffer og mange stoffer som ikke er psykoaktive men som virker inn på rusen, og dette er en Cannabis diskusjon.
Egentlig så heter det THCV, men noen kaller det også THV. Det finnes også minimalt av THC (noen få prosent) i forhold til resten av planten som utgjør mer enn ca. 85%. Men ja, THC er stoffet det finnes mest av.
6776538[/snapback]
ArmenMinAU, da. Når du linker til noe som svar på en påstand kan du ta deg bryet med å dokumentere sammenhengen. Det var det ikke her:
When it comes to violence, all alcohol is not created equal: Beer is four times more likely to be consumed in a potentially hazardous way than liquor and wine combined, according to researcher Anita de Lucio-Brock of the Alcohol Related Injuries and Violence (ARIV) project.
Hva betyr det i klartekst: At øl oftere drikkes i settinger og mengder(!) som resulterer i vold. Det har ingenting med å ta seg en boks Carlsberg til pizzaen når man ser på Nytt på Nytt eller Skavlan å gjøre...
Geir :)
