Gjøre spilleren regionfree SONY RDR HX 910
(I used a "4-Device Video Expert" - URC-4081, which I bought on EBay for less than $10, and had it shipped to me in Belgium. I have used the same technique with PDAWin's Universal Remote on an iPAQ Pocket PC for a Sony DVP-NS305 - so I am pretty certain that this method works for most Sony DVD players/writers - with any of the methods to send the "12345" sequence.)
When the "magic button" is referred to on other posts - I have replaced it by "SET" as that is the corresponding button on the One4All "Video Expert" and other less advanced One-For-All remotes.
Also, others write "until the rabbit comes out" - on the Video expert the LED blinks twice.
Prepare the Remote - One-For-All:
1. Select DVD button on remote
2. Hold SET (or magic) button until the LED blinks twice
("rabbit comes out")
3. Enter device code 0533
Next, you need to program buttons 1..5 with the following codes:
1 = 189, 2 = 255, 3 = 095, 4 = 221, 5 = 079
To program the buttons, do the following:
1. Hold SET button until the LED blinks twice
2. Press 994 (LED blinks twice)
3. Press (not hold) SET - LED blinks once
4. Enter the 3-digit code plus the button to assign it to:
1891 (this programs button 1 = 189)
LED blinks twice.
5. Repeat steps 1 to 4 for each of the remaining keys
(2->5), using 2552, 0953, 2214, 0795 in place of 1891.
Reprogram your DVD player/writer:
1. Remove disk and put player on standby
2. Press 1,2,3,4,5 (pause briefly between each button and
make sure LED of remote flashes) - on Sony
RDR-HX710 "TIMER OK" is displayed
on Sony DVP-NS305 "SUCCESS" is displayed (and player
starts up).
Your DVD player/writer should now accept DVDs from any region (I have tried with Region 1 & 2).
If it does not, then add this extra step (#3) to the "reprogram" process:
3. Press 1,2,3,4,5 - player shuts down and you're ready!
I have also seen some people suggest pressing 1122334455 (really make sure that the player/writer receives the necessary code), that did not work for me - I had to use 12345.
This should work for most of the DVP-NS### players and the RDR-GX### / RDR-HX### series of HDD/DVD writers.
Det er bekrefta av flere brukere at den funker på HX910 også, men husk at garantien sliter du vel med hvis du gjør dette...
