transcode, plug-in initialization failed
Litt dårlig tid, men skynder meg å slenge inn et problem:
root@ubuntu:/media/hda5# transcode -i bc.avi -y ffmpeg --export_prof dvd-pal --export_asr 3 -o movie -D0 -s2 -m movie.ac3 -J modfps=clonetype=3 --export_fps 25.00
transcode v1.0.1 (C) 2001-2003 Thomas Oestreich, 2003-2004 T. Bitterberg
libdvdread: Encrypted DVD support unavailable.
**  No css library available. See             **
**  /usr/share/doc/libdvdread3/README.Debian  **
**  for more information.                     **
libdvdread: Can't open file VIDEO_TS.IFO.
[transcode] (probe) suggested AV correction -D 0 (0 ms) | AV 0 ms | 0 ms
[transcode] auto-probing source bc.avi (ok)
[transcode] V: import format    | XviD RIFF data, AVI (V=ffmpeg|A=mp3)
[transcode] V: import frame     | 576x320  1.80:1
XXX: zoom=yes pre_clip=no
[transcode] V: zoom             | 720x576  1.25:1 (Lanczos3)
[transcode] V: bits/pixel       | 0.181
[transcode] V: decoding fps,frc | 23.976,1
[transcode] V: Y'CbCr           | YV12/I420
[transcode] A: import format    | 0x55    MPEG layer-3 [48000,16,2]  117 kbps
[transcode] A: export format    | 0x55    MPEG layer-3 [48000,16,2]  128 kbps
[transcode] V: encoding fps,frc | 25.000,3
[transcode] A: bytes per frame  | 7680 (7680.000000)
[transcode] A: adjustment       | 0@1000
[transcode] A: rescale stream   | 2.000
[transcode] V: IA32/AMD64 accel | sse2 (sse2 sse mmxext mmx asm C)
tc_memcpy: using sse for memcpy
[transcode] V: video buffer     | 10 @ 720x576
[transcode] warning : /usr/lib/transcode/import_ffmpeg.so: undefined symbol: dts_init
Loading video import module failed
Did you enable this module when you ran configure?
[transcode] failed to init import modules
[transcode] critical: plug-in initialization failed
Feilen er siste linje. Noen tips? :hrm:
jeg hadde ikke libdvdcss inne, men installerte libdvdcss2. Akkurat samme feilmelding?
jeg hadde tenkt å installere transcode fra kildekode, men det funka selvsagt ikke
ERROR: requirement failed: cannot link against libavcodec
libavcodec can be found in the following packages:
 FFMpeg  http://www.ffmpeg.org/
ERROR: option '--enable-libjpeg' failed: cannot compile jpeglib.h
jpeglib.h can be found in the following packages:
 jpeg  ftp://ftp.uu.net/graphics/jpeg/
ERROR: option '--enable-libjpeg' failed: cannot link against libjpeg
libjpeg can be found in the following packages:
Jeg har installert ffmpeg, libavcodec51,mpeg2dec, libmpeg2 og libmp3lame0.
Endret av hockey500
