Merkelig melding ved opprettelse av map i Hammer
Meldingen som kommer opp (oppløsningsvarsel! )
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlbsp.exe
** Parameters: "C:\Programfiler\Valve\Steam\SteamApps\nilsree\counter-strike"
hlbsp v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
Zoner's Half-Life Compilation Tools -- Custom Build
Based on code modifications by Sean 'Zoner' Cavanaugh
Based on Valve's version, modified with permission.
Submit detailed bug reports to ([email protected])
----- BEGIN hlbsp -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlbsp.exe C:\Programfiler\Valve\Steam\SteamApps\nilsree\counter-strike
>> There was a problem compiling the map.
>> Check the file C:\Programfiler\Valve\Steam\SteamApps\nilsree\counter-strike.log for the cause.
----- END hlbsp -----
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlcsg.exe
** Parameters: "c:\aim_shed"
hlcsg v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
----- BEGIN hlcsg -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlcsg.exe c:\aim_shed
Entering c:\aim_shed.map
Current hlcsg Settings
Name | Setting | Default
threads [ 1 ] [ Varies ]
verbose [ off ] [ off ]
log [ on ] [ on ]
developer [ 0 ] [ 0 ]
chart [ off ] [ off ]
estimate [ off ] [ off ]
max texture memory [ 4194304 ] [ 4194304 ]
priority [ Normal ] [ Normal ]
noclip [ off ] [ off ]
null texture stripping[ on ] [ on ]
clipnode economy mode [ on ] [ on ]
onlyents [ off ] [ off ]
wadtextures [ on ] [ on ]
skyclip [ on ] [ on ]
hullfile [ None ] [ None ]
min surface area [ 0.500 ] [ 0.500 ]
brush union threshold [ 0.000 ] [ 0.000 ]
Using mapfile wad configuration
Wadinclude list :
[zhlt.wad]
0 brushes (totalling 0 sides) discarded from clipping hulls
CreateBrush:
70%...80%...90%... (0.02 seconds)
SetModelCenters:
10%...50%...60%... (0.00 seconds)
CSGBrush:
10%...20%...30%...40%...50%...60%...70%...80%...90%... (0.08 seconds)
Using Wadfile: \snarveier og lignende\counter-strike\halflife.wad
- Contains 6 used textures, 100.00 percent of map (3116 textures in wad)
Texture usage is at 0.16 mb (of 4.00 mb MAX)
0.22 seconds elapsed
----- END hlcsg -----
** Executing...
** Parameters: "c:\aim_shed" -nowadtextures
Unknown option "-nowadtextures"
-= hlbsp Options =-
-leakonly : Run BSP only enough to check for LEAKs
-subdivide # : Sets the face subdivide size
-maxnodesize # : Sets the maximum portal node size
-notjunc : Don't break edges on t-junctions (not for final runs)
-noclip : Don't process the clipping hull (not for final runs)
-nofill : Don't fill outside (will mask LEAKs) (not for final runs)
-texdata # : Alter maximum texture memory limit (in kb)
-chart : display bsp statitics
-low | -high : run program an altered priority level
-nolog : don't generate the compile logfiles
-threads # : manually specify the number of threads to run
-estimate : display estimated time during compile
-nonulltex : Don't strip NULL faces
-verbose : compile with verbose messages
-noinfo : Do not show tool configuration information
-dev # : compile with developer message
mapfile : The mapfile to compile
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlvis.exe
hlvis v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
----- BEGIN hlvis -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlvis.exe c:\aim_shed
Error: Portal file 'c:\aim_shed.prt' does not exist, cannot vis the map
----- END hlvis -----
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlrad.exe
hlrad v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
----- BEGIN hlrad -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlrad.exe c:\aim_shed
>> Check the file c:\aim_shed.log for the cause.
----- END hlrad -----
** Executing...
** Command: Copy File
** Parameters: "c:\aim_shed.bsp" "C:\Programfiler\Valve\Steam\SteamApps\nilsree\counter-strike\cstrike\maps\aim_shed.bsp"
** Executing...
** Parameters: "c:\aim_shed.pts" "C:\Programfiler\Valve\Steam\SteamApps\nilsree\counter-strike\cstrike\maps\aim_shed.pts"
The command failed. Windows reported the error:
"Systemet finner ikke angitt fil."
Noen som vet hvorfor?
prøv å post loggen på VERC Network Forums
sjekka for leaks? du har vel "Skybox" ?
c:\aim_shed ?
har du navnet "c:\aim_shed" som mapname?
prøv med aim_shed ? tviler på den liker :\ ( @ klikker ivertfall)
RMF Directory bør helst ligge i "mine dokumenter" eller noe sånt!
trykk "ALT+P" For å sjekke etter error
Map-->load pointfile så finner den leaks..om du bare får opp
"åpne" og ingen filer viser (mapnavnet) , så er det ingen leaks"
Edit: Post 666 :tease:
Endret av galaxee
