Futurama "dramaet" fortsetter
Ser endelig ut som at ting og tang begynner å skje i Fox :)
LOS ANGELES, CA, United States (UPI) -- Fox TV`s Emmy-award winning cartoon series 'Futurama' may not be history after all, it was reported Wednesday.
Talks are reportedly under way at 20th Century Fox to revive the animated series set in the next millennium, Daily Variety reported.
'Futurama' -- from 'The Simpsons' Matt Groening and David X. Cohen -- won three Emmys in five seasons, including best animated series in 2002.
However, before anything could happen with 'Futurama,' Fox has to secure deals with its production team as well as voice stars Billy West, Katey Sagal and John DiMaggio.
http://smallscreen.monstersandcritics.com/article_1073509.php/`Futurama`_may_see_new_life_on_Fox
Litt mer:
http://www.filmfodder.com/scifi/archives/2...hawed_out.shtml
Får håpe at skuespillerene blir med på litt mer action fra år 3000 slik at vi igjen får enda mer kvalitetsinhold fra Matt Groening :)
:woot:
Stakk innom Can't get enough Futurama for å si om dem sa noe der:
Of course, Variety is usually very close to the sources, so there was a chance that a change to the status of Futurama had happened. However, this is only the case in a very limited way. The talk is still about the DVDs (not TV, for all we know) and it is still ongoing. The slight difference is that our sources at the top of the show's team tell us that they think there will be some sort of result soon. They seem to be carefully optimistic, but nothing is set in stone yet.
Ellers står det på imdb.com at dette, eller en film(?), er i produksjon, HER. Uten at imdb er en absolutt garantist.
Jeg har hele serien på DVD og etter å ha hørt gjennom alle DVD-kommentar sporene har jeg fått inntrykket av at alle skuespillerene syns Futurama var et knall show å jobbe på. De var like motvillige til å stoppe som X. Cohen og Groening.
Tror ikke det blir et problem å få med seg de kjære stemmene videre.
På en annen side vil jeg jo mye mer ha mer Futurama enn en serie om *gjesp* Milhouse!
5389363[/snapback]
Amen, Milhouse kan vi godt kaste til løvene(forsåvidt hele Simpsons hvis det står mellom det og Futurama). Ser fram til nye episoder av Futurama :)
