jossa Skrevet 2. januar 2006 Del Skrevet 2. januar 2006 hei.. har oppgradert fra et gammelt system til et Litt nyere men brukt system.. kjøpte i samme slengen en 250gb disk.. å mistenker den er problemet... da systemet raportere at den er i pio mode å resten i dma... men kan man oppgradere HK no mere? har nyeste softwaren på bios tror jeg (ifølge asus sine søppel sider) hoff.. ALT går tregt + jeg hadde enorme problemer med bare å få instalert.. (vet ikke om det har samenheng men musa slutter og funger etter en dag ca.. usb mx510 HJELP!! (advarsel, mye tekst er en dump fra cpu-z) CPUID Output ------------------------------------------------------------------------------ Number of CPUs 1 Name AMD Athlon XP Code name Thoroughbred Specification AMD Athlon XP2400+ Family/Model/Stepping 681 Extended Family/Model 7/8 Package Socket A Core Stepping B0 Technology 0.13µ Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE Features Clock Speed 2014.8 MHz Clock multiplier x15.0 Front Side Bus Frequency 134.3 MHz Bus Speed 268.6 MHz Stock frequency 2000 MHz P-Rating 2400+ L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size L2 Speed 2014.8 MHz (Full) L2 Location On Chip L2 Data Prefetch Logic yes L2 Bus Width 64 bits eax ebx ecx edx Function 00000000 00000001 68747541 444d4163 69746e65 Function 00000001 00000681 00000000 00000000 0383f9ff Function 80000000 80000008 68747541 444d4163 69746e65 Function 80000001 00000781 00000000 00000000 c1c3f9ff Function 80000002 20444d41 6c687441 54286e6f 5820294d Function 80000003 30343250 00002b30 00000000 00000000 Function 80000004 00000000 00000000 00000000 00000000 Function 80000005 0408ff08 ff20ff10 40020140 40020140 Function 80000006 00000000 41004100 01008140 00000000 Function 80000007 00000000 00000000 00000000 00000001 Function 80000008 00002022 00000000 00000000 00000000 edx eax MSR C0010015 00000000 080B1008 MSR C001001B 00000000 6003D22F MSR C001001E 00000000 0000011D Chipset ------------------------------------------------------------------------------ Northbridge ALI AliMagiK1 rev. 04 Southbridge ALI M1533 rev. 00 Graphic Interface AGP AGP Revision 2.0 AGP Transfert Rate 4x AGP SBA supported, enabled AGP Aperture 128 MBytes Memory Type DDR Memory Size 512 MBytes Memory Frequency 134.3 MHz (1:1) CAS# 2.5 RAS# to CAS# 3 RAS# Precharge 3 Memory SPD ------------------------------------------------------------------------------ No SPD information available Monitoring ------------------------------------------------------------------------------ Sensor Chip Winbond W83782D PCI Device List ------------------------------------------------------------------------------ Host Bridge bus 0 (0x00), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x10B9 Model ID 0x1647 Revision ID 0x04 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xF0000000 Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 Capabilities AGP Capability Version 2.0 Status enabled Transfer rate 4x (max 4x) Queue lenght 1 (max 28) Dump 00 01 02 03 04 05 06 07 08 09 0A 0B 02 A4 20 00 17 02 00 1B 04 03 00 00 Power Management Capability Version 1.0 Dump 00 01 02 03 04 05 06 07 01 00 01 00 00 00 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 B9 10 47 16 17 00 10 A2 04 00 00 06 00 00 00 00 10 08 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 40 11 2F 0F 03 0C 10 04 2F 00 20 04 00 00 20 20 00 50 01 00 00 00 34 10 04 2F 00 00 00 00 00 20 20 FF 60 D1 8C 30 F5 00 AC 00 00 03 AC AE 91 40 26 19 05 70 00 00 95 95 00 00 04 00 40 62 96 24 04 10 03 02 80 31 07 53 B7 31 07 10 E1 00 01 00 00 00 00 00 00 90 55 00 55 81 00 00 00 00 08 00 00 00 F0 FE 00 00 A0 30 40 00 00 01 00 01 00 00 00 00 00 00 00 00 00 B0 02 A4 20 00 17 02 00 1B 04 03 00 00 09 50 04 00 C0 00 00 13 10 02 00 00 F0 80 68 00 C0 00 81 0C F0 D0 07 80 75 7C 00 B0 7B 15 00 00 00 C0 80 82 80 00 E0 00 4C 23 3A 40 00 B7 7E 00 06 18 00 A5 15 00 00 F0 00 80 AE 2E 00 60 00 60 00 00 01 47 00 00 00 00 PCI to PCI Bridge bus 0 (0x00), device 1 (0x01), function 0 (0x00) Common header Vendor ID 0x10B9 Model ID 0x5247 Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x01 PCI header Primary bus 0x00 Secondary bus 0x01 Int. Line 0x00 Int. Pin 0x00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 B9 10 47 52 17 00 00 04 00 00 04 06 00 00 01 00 10 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 20 22 20 00 E6 60 E7 70 E7 F0 EF 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 USB Controller (OHCI) bus 0 (0x00), device 2 (0x02), function 0 (0x00) Common header Vendor ID 0x10B9 Model ID 0x5237 Revision ID 0x03 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x08 Latency 0x20 Header 0x00 PCI header Address 0 (memory) 0xE5800000 Subvendor ID 0x10B9 Subsystem ID 0x5237 Int. Line 0x0A Int. Pin 0x01 Capabilities Power Management Capability Version 1.1 Dump 00 01 02 03 04 05 06 07 01 00 02 00 00 00 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 B9 10 37 52 17 00 90 02 03 10 03 0C 08 20 00 00 10 00 00 80 E5 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 B9 10 37 52 30 00 00 00 00 60 00 00 00 00 00 00 00 0A 01 00 50 40 00 00 1F 00 22 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 IDE Controller bus 0 (0x00), device 4 (0x04), function 0 (0x00) Common header Vendor ID 0x10B9 Model ID 0x5229 Revision ID 0xC4 PI 0xFA SubClass 0x01 BaseClass 0x01 Cache Line 0x00 Latency 0x20 Header 0x00 PCI header Address 4 (port) 0x0000D400 Subvendor ID 0x1043 Subsystem ID 0x8053 Int. Line 0xFF Int. Pin 0x01 Capabilities Power Management Capability Version 1.1 Dump 00 01 02 03 04 05 06 07 01 00 02 00 00 00 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 B9 10 29 52 05 00 90 02 C4 FA 01 01 00 20 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 01 D4 00 00 00 00 00 00 00 00 00 00 43 10 53 80 30 00 00 00 00 60 00 00 00 00 00 00 00 FF 01 02 04 40 00 00 00 7A 00 00 00 00 30 00 20 C9 00 80 BA 3A 50 02 00 00 8B 55 05 04 29 01 00 00 32 00 00 31 31 60 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 USB Controller (OHCI) bus 0 (0x00), device 6 (0x06), function 0 (0x00) Common header Vendor ID 0x10B9 Model ID 0x5237 Revision ID 0x03 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x08 Latency 0x20 Header 0x00 PCI header Address 0 (memory) 0xE4800000 Subvendor ID 0x10B9 Subsystem ID 0x5237 Int. Line 0x0B Int. Pin 0x01 Capabilities Power Management Capability Version 1.1 Dump 00 01 02 03 04 05 06 07 01 00 02 00 00 00 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 B9 10 37 52 17 00 90 02 03 10 03 0C 08 20 00 00 10 00 00 80 E4 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 B9 10 37 52 30 00 00 00 00 60 00 00 00 00 00 00 00 0B 01 00 50 40 00 00 1F 00 20 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI to ISA Bridge bus 0 (0x00), device 7 (0x07), function 0 (0x00) Common header Vendor ID 0x10B9 Model ID 0x1533 Revision ID 0x00 PI 0x00 SubClass 0x01 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Subvendor ID 0x10B9 Subsystem ID 0x1533 Int. Line 0x00 Int. Pin 0x00 Capabilities Power Management Capability Version 1.0 Dump 00 01 02 03 04 05 06 07 01 00 01 00 00 00 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 B9 10 33 15 0F 00 10 02 00 00 01 06 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 B9 10 33 15 30 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 40 03 21 0B C5 1D 01 00 00 02 60 19 00 00 00 FD 37 50 00 00 00 00 02 00 02 00 7E 00 00 00 00 00 00 00 60 00 18 00 00 00 00 00 00 00 00 00 00 00 60 00 00 70 12 00 03 00 43 1F 01 4C 40 00 00 00 00 C0 80 90 80 A1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Audio device bus 0 (0x00), device 9 (0x09), function 0 (0x00) Common header Vendor ID 0x1102 Model ID 0x0002 Revision ID 0x08 PI 0x00 SubClass 0x01 BaseClass 0x04 Cache Line 0x00 Latency 0x20 Header 0x80 PCI header Address 0 (port) 0x0000B800 Subvendor ID 0x1102 Subsystem ID 0x8023 Int. Line 0x07 Int. Pin 0x01 Capabilities Power Management Capability Version 1.0 Dump 00 01 02 03 04 05 06 07 01 00 01 06 00 00 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 02 11 02 00 05 00 90 02 08 00 01 04 00 20 80 00 10 01 B8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 11 23 80 30 00 00 00 00 DC 00 00 00 00 00 00 00 07 01 02 14 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 06 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Input Device bus 0 (0x00), device 9 (0x09), function 1 (0x01) Common header Vendor ID 0x1102 Model ID 0x7002 Revision ID 0x08 PI 0x00 SubClass 0x80 BaseClass 0x09 Cache Line 0x00 Latency 0x20 Header 0x80 PCI header Address 0 (port) 0x0000B400 Subvendor ID 0x1102 Subsystem ID 0x0020 Int. Line 0x00 Int. Pin 0x00 Capabilities Power Management Capability Version 1.0 Dump 00 01 02 03 04 05 06 07 01 00 01 06 00 00 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 02 11 02 70 05 00 90 02 08 00 80 09 00 20 80 00 10 01 B4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 11 20 00 30 00 00 00 00 DC 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 06 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Ethernet Controller bus 0 (0x00), device 13 (0x0D), function 0 (0x00) Common header Vendor ID 0x10EC Model ID 0x8139 Revision ID 0x10 PI 0x00 SubClass 0x00 BaseClass 0x02 Cache Line 0x00 Latency 0x20 Header 0x00 PCI header Address 0 (port) 0x0000B000 Address 1 (memory) 0xE3800000 Subvendor ID 0x10EC Subsystem ID 0x8139 Int. Line 0x09 Int. Pin 0x01 Capabilities Power Management Capability Version 1.1 Dump 00 01 02 03 04 05 06 07 01 00 C2 F7 00 01 00 00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 EC 10 39 81 05 00 90 02 10 00 00 02 00 20 00 00 10 01 B0 00 00 00 00 80 E3 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81 30 00 00 00 00 50 00 00 00 00 00 00 00 09 01 20 40 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Bridge device bus 0 (0x00), device 17 (0x11), function 0 (0x00) Common header Vendor ID 0x10B9 Model ID 0x7101 Revision ID 0x00 PI 0x00 SubClass 0x80 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 B9 10 01 71 00 00 00 02 00 00 80 06 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 40 00 00 00 00 20 01 0C DA 0D 20 00 00 00 00 50 00 00 00 00 00 00 00 00 00 DF 0F 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 FF FF CF 0D 70 FF 87 00 00 00 00 00 08 F7 77 00 00 28 00 00 00 80 3E 01 13 1B 00 20 00 00 0B 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 A0 00 00 00 04 00 00 00 00 00 00 00 00 04 E4 00 00 B0 00 04 00 00 04 00 00 00 00 04 00 00 00 00 00 40 C0 10 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 D0 00 46 00 00 00 00 00 00 00 00 00 00 32 70 00 00 E0 00 E4 00 E8 01 00 01 00 00 00 00 00 00 00 00 00 F0 01 00 20 6E 00 00 00 00 00 00 00 00 00 00 00 00 VGA Controller bus 1 (0x01), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0253 Revision ID 0xA3 PI 0x00 SubClass 0x00 BaseClass 0x03 Cache Line 0x00 Latency 0xF8 Header 0x00 PCI header Address 0 (memory) 0xE6000000 Address 1 (memory) 0xE8000000 Address 2 (memory) 0xE7800000 Subvendor ID 0x1043 Subsystem ID 0x8043 Int. Line 0x03 Int. Pin 0x01 Capabilities Power Management Capability Version 1.1 Dump 00 01 02 03 04 05 06 07 01 44 02 00 00 00 00 00 AGP Capability Version 2.0 Status enabled Transfer rate 4x (max 4x) Queue lenght 1 (max 32) Dump 00 01 02 03 04 05 06 07 08 09 0A 0B 02 00 20 00 17 02 00 1F 04 03 00 1B Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 DE 10 53 02 07 00 B0 02 A3 00 00 03 00 F8 00 00 10 00 00 00 E6 08 00 00 E8 08 00 80 E7 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 80 30 00 00 00 00 60 00 00 00 00 00 00 00 03 01 05 01 40 43 10 43 80 02 00 20 00 17 02 00 1F 04 03 00 1B 50 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00 60 01 44 02 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DMI ------------------------------------------------------------------------------ DMI BIOS -------- vendor Award Software, Inc. version ASUS A7A266 ACPI BIOS Revision 1012 date 04/30/2003 DMI System Information ---------------------- manufacturer System Manufacturer product System Name version System Version serial EVAL UUID 00000000-00000000-00000000-00000000 DMI Baseboard ------------- vendor ASUSTeK Computer INC. model A7A266 revision REV 1.xx serial xxxxxxxxxxx DMI System Enclosure -------------------- manufacturer Chassis Manufacture chassis type Tower chassis serial EVAL DMI Processor ------------- manufacturer AuthenticAMD model AMD Athlon Processor clock speed 1800.0MHz FSB speed 133.0MHz multiplier 13.5x DMI Memory Controller --------------------- correction unknown Max module size 1024MBytes DMI Memory Module ----------------- designation DIMM 1 DMI Memory Module ----------------- designation DIMM 2 DMI Memory Module ----------------- designation DIMM 3 DMI Memory Module ----------------- designation DDR 1 DMI Memory Module ----------------- designation DDR 2 size 512MBytes (single bank) DMI Port Connector ------------------ designation PRIMARY IDE/HDD (internal) connector On Board IDE DMI Port Connector ------------------ designation SECONDARY IDE/HDD (internal) connector On Board IDE DMI Port Connector ------------------ designation FLOPPY (internal) connector On Board Floppy DMI Port Connector ------------------ designation USB1 (external) port type USB connector Access Bus (USB) DMI Port Connector ------------------ designation USB2 (external) port type USB connector Access Bus (USB) DMI Port Connector ------------------ designation PS/2 Keybaord (external) port type Keyboard Port connector PS/2 DMI Port Connector ------------------ designation PS/2 Mouse (external) port type Mouse Port connector PS/2 DMI Port Connector ------------------ designation Parallel Port (external) port type Parallel Port ECP/EPP connector DB-25 female DMI Port Connector ------------------ designation Serial Port 1 (external) port type Serial Port 16550 connector DB-9 male DMI Port Connector ------------------ designation Serial Port 2 (external) port type Serial Port 16550 connector DB-9 male DMI Port Connector ------------------ designation Joystick Port (external) port type Joystick Port connector DB-15 female DMI Port Connector ------------------ designation MIDI Port (external) port type MIDI Port connector DB-15 female DMI Port Connector ------------------ designation Line In Jack (external) port type Audio Port connector Mini Jack (headphones) DMI Port Connector ------------------ designation Video Port (external) port type Video Port connector Mini Jack (headphones) DMI Extension Slot ------------------ designation PCI 1 type PCI width 32 bits populated no DMI Extension Slot ------------------ designation PCI 2 type PCI width 32 bits populated no DMI Extension Slot ------------------ designation PCI 3 type PCI width 32 bits populated no DMI Extension Slot ------------------ designation PCI 4 type PCI width 32 bits populated yes DMI Extension Slot ------------------ designation PCI 5 type PCI width 32 bits populated yes DMI Extension Slot ------------------ designation AGP type PCI width 32 bits populated yes DMI Physical Memory Array ------------------------- location Motherboard usage System Memory correction None max capacity 512MBytes max# of devices 5 DMI Memory Device ----------------- designation DIMM 1 format DIMM type DRAM DMI Memory Device ----------------- designation DIMM 2 format DIMM type DRAM DMI Memory Device ----------------- designation DIMM 3 format DIMM type DRAM DMI Memory Device ----------------- designation DDR 1 format DIMM type DRAM DMI Memory Device ----------------- designation DDR 2 format DIMM type DRAM total width 72bits data width 64bits size 512MBytes Software ------------------------------------------------------------------------------ Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) DirectX Version 9.0c Lenke til kommentar https://www.diskusjon.no/topic/517938-pecen-er-generelt-sett-treg-tror-det-er-hk/
Zink Skrevet 2. januar 2006 Del Skrevet 2. januar 2006 Et søk Her viser at Western Digital-disker har et slikt problem på ditt brikkesett. Mulig det gjelder andre også. Hvis det stemmer kanskje WD eller ALi har noe til nedlasting? Lenke til kommentar https://www.diskusjon.no/topic/517938-pecen-er-generelt-sett-treg-tror-det-er-hk/#findComment-5373885
efikkan Skrevet 2. januar 2006 Del Skrevet 2. januar 2006 Prøv med en annen disk, så kan du eventuellt luke ut problemet. Lenke til kommentar https://www.diskusjon.no/topic/517938-pecen-er-generelt-sett-treg-tror-det-er-hk/#findComment-5373949
jossa Skrevet 3. januar 2006 Forfatter Del Skrevet 3. januar 2006 ah! takker.. skal prøve med det.. å så får man se! er det ingen som vet av noen oppdateringer fra ali? Lenke til kommentar https://www.diskusjon.no/topic/517938-pecen-er-generelt-sett-treg-tror-det-er-hk/#findComment-5377643
jossa Skrevet 12. januar 2006 Forfatter Del Skrevet 12. januar 2006 hmmm.. tror det kanseje er den ene 120gb disken som begyner og takke for seg å skru av.. så det kjøres kontinuelig backup på den nå å ser meg om etter en ny disk.. Lenke til kommentar https://www.diskusjon.no/topic/517938-pecen-er-generelt-sett-treg-tror-det-er-hk/#findComment-5426305
