Hva er SNMP og WFM I forhold til Nettverkskort?
Skal kjøpe meg 2 nye nettverkskort og har krav om at de må støtte Wake on lan, ha PXE BootProm og være 10/100 kompatible. Har funnet 2 typer på komplett sine sider, Cnet og SMC. Begge har dette, men det står at SMC kortet har "Fjernkontrollering av PC gjennom WFM tjenste" Hva er egentlig det?
Sendte mail om dette til salgsavdelingen hos komplett, men fikk ikke noe svar på det.
Betyr det at man kan fjernstyre pc på en eller annen måte? Det er jo det jeg er ute etter her. Å kunne ha mulighet til å starte opp pc/server uten å være hjemme, samt å kunne sette i dvalemodus/skru av.
Hadde ønsket å kunne fått sendt bestillingen på dette idag.
Kjetil.
Fant dette:
Wired for Management (WfM)
Over the last several years, the PC industry has rallied around the Wired for Management (WfM) initiative. This has resulted in millions of PCs enabled with built-in features that offer valuable manageability functionality, including instrumentation, use of the network as a boot device, remote wake-up, and power management. These standards-based features have also been embraced and supported by numerous suppliers of manageability software and operating systems.
The Microsoft Windows* Logo Program System and Device Requirements 2.0 has been released, and addresses the essential manageability elements of WfM. PCs that successfully complete the tests in the current version of the Microsoft Windows XP Hardware Compatibility Test Kit (HCT), version 10.0 or greater, should represent the same levels of built-in manageability features as WfM-enabled PCs.
To assist Information Technology professionals in identifying WfM-enabled PC models, Intel has maintained a listing of PC models that successfully passed the tests in our Toolkit. Since most major OEMs are targeting Windows XP and many have already satisfied these requirements, there is no longer a need for a separate WfM self-test or for a separate listing of WfM-enabled systems. Even a business not migrating to Windows XP may consult Microsoft's list to determine and evaluate the capabilities of particular PC models.
The WfM Self-Test ToolKit is no longer supported and PC manufacturers should reference the "Designed for Windows XP" logo program for the Microsoft Windows XP HCT for testing tools.
The listing of WfM-enabled systems was "frozen" on December 7th 2001. If the systems that you are looking for do not appear on that list you may want to search for systems on the Microsoft Windows Hardware Compatibility List (HCL) that have the Designed for Windows XP Logo and are Windows Logo Program V2.0 Compliant* which should represent the same levels of built-in manageability features as WfM 2.0 enabled PCs.
Quote:
Den 2002-09-08 13:10, tilstad skrev:
Okey, så det at det SMC kortet er administrerbart via WFM er jo på ingen måte noe +...det er jo egentlig en selvfølge når det har wakeonlan.
Men noen som vet hva SNMP er da?
Simple Network Managment Protocol evnt.
Security's Not My Problem.
Hva med å begynne å søke litt på internett _før_ du spør spørsmål i forumet?, google har nok av treff.
Okey..det ble Smc kortene. Hadde vel valgt 3Com om jeg faktisk skulle brukt dette til noe annet enn å teste det ut og for å ha litt gøy. Kan ikke kjøpe så dyr hardware når man har 7 maskiner å holde styr på og de kun er til hobbybruk.
JOda Google ovverasker stadig med informasjon..ser at jeg nok ville hatt utbytte av å oftere ty til Google. Har vel hatt en tendens til å se på sidene til fabrikanten av et produkt, men de er gjerne de som forteller minst om hva de egentlig leverer av teknologi utover termer og forkortelser .
Takk for svar.
Kjetil
