Blokkerte pakker, tar internett trafikk?
Jeg har en Dlink router, hvor loggen hele tiden blir oppdatert med informasjon om blokkerte pakker fra diverse ip-adresser, men på samme port.
Her en loggen:
[iNFO] Thu Dec 29 19:53:09 2005 Blocked incoming UDP packet from 83.204.89.113:1116 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:09 2005 Blocked incoming UDP packet from 83.208.41.191:3236 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:09 2005 Blocked incoming UDP packet from 84.181.154.80:62604 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 81.205.104.235:2067 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming TCP packet from 84.227.114.250:4512 to 10.0.0.2:135
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 84.131.111.161:62863 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 81.205.104.235:2067 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 83.204.89.113:1116 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 201.3.49.194:10538 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 81.205.104.235:2067 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 84.181.154.80:62604 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 84.170.97.245:2203 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 84.181.154.80:62604 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 84.157.59.251:32826 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 82.242.153.71:2255 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 83.204.89.113:1116 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 82.242.153.71:2255 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:08 2005 Blocked incoming UDP packet from 84.170.97.245:2203 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 85.201.97.55:1810 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 82.242.153.71:2255 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 85.201.97.55:1810 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 85.201.97.55:1810 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 84.135.198.184:1924 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 140.115.202.98:17849 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 84.131.111.161:62863 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:07 2005 Blocked incoming UDP packet from 84.170.97.245:2203 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 84.157.59.251:32826 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 84.157.59.251:32826 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 222.243.203.82:53807 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 84.135.198.184:1924 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 70.174.115.119:3359 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 70.174.115.119:3359 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 70.174.115.119:3359 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:06 2005 Previous message repeated 2 times
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 68.142.232.33:27243 to 10.0.0.2:52493
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 84.131.111.161:62863 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 84.25.104.227:4287 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 85.72.17.33:2194 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:06 2005 Blocked incoming UDP packet from 84.107.150.61:1029 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.173.76.222:1095 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.135.198.184:1924 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 66.36.150.52:9810 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.156.98.187:1056 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.156.125.74:1109 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.25.104.227:4287 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.156.98.187:1056 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.156.98.187:1056 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.156.125.74:1109 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.131.111.161:62863 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.107.150.61:1029 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 85.248.125.63:63506 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.107.150.61:1029 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.156.125.74:1109 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 82.124.245.130:4460 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 85.248.125.63:54079 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.25.104.227:4287 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 82.124.245.130:4460 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 84.131.111.161:62863 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:05 2005 Blocked incoming UDP packet from 222.75.162.18:15632 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 84.102.178.147:3266 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 80.216.247.1:3983 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 82.124.245.130:4460 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 85.248.125.63:57305 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 84.155.183.96:61058 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 84.156.125.74:1109 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 85.72.17.33:2194 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:04 2005 Blocked incoming UDP packet from 84.155.183.96:61058 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 83.205.230.254:2216 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 85.72.17.33:2194 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 84.173.76.222:1095 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 84.102.178.147:3266 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 83.205.230.254:2216 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 68.60.108.171:35339 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 83.205.230.254:2216 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 84.102.178.147:3266 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 84.59.229.54:1363 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:03 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:53:03 2005 Dropped TCP packet with invalid flags 0x11 from 192.168.0.20:15600 to 83.227.159.140:63363
[iNFO] Thu Dec 29 19:53:02 2005 Blocked incoming UDP packet from 83.205.230.254:2216 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:02 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:02 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:02 2005 Unable to send email (send status 2)
[WARN] Thu Dec 29 19:53:02 2005 SMTP client failed to send email
[WARN] Thu Dec 29 19:53:02 2005 SMTP failed during sender/recipient dialog
[iNFO] Thu Dec 29 19:53:02 2005 Blocked incoming UDP packet from 85.140.44.87:8738 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:53:02 2005 Blocked incoming UDP packet from 84.59.229.54:1363 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:02 2005 Blocked incoming UDP packet from 84.102.178.147:3266 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:02 2005 Blocked incoming UDP packet from 84.59.229.54:1363 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 85.75.22.179:64764 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 68.60.108.171:36092 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 68.60.108.171:39269 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 85.75.22.179:64764 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 68.60.108.171:40424 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 84.146.125.31:1268 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 80.201.109.51:3307 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 84.146.125.31:1268 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:01 2005 Blocked incoming UDP packet from 80.216.247.1:3983 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:00 2005 Blocked incoming UDP packet from 84.146.125.31:1268 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:53:00 2005 Blocked incoming UDP packet from 80.201.109.51:3307 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:53:00 2005 Blocked incoming UDP packet from 203.218.78.138:18807 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:53:00 2005 Blocked incoming UDP packet from 84.146.12.242:63892 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:00 2005 Dropped TCP packet with invalid flags 0x18 from 82.160.73.70:2200 to 10.0.0.2:15600
[iNFO] Thu Dec 29 19:53:00 2005 Dropped TCP packet with invalid flags 0x18 from 65.189.250.195:60339 to 10.0.0.2:15310
[iNFO] Thu Dec 29 19:53:00 2005 Blocked incoming UDP packet from 80.201.109.51:3307 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:00 2005 Blocked incoming UDP packet from 85.75.22.179:64764 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:53:00 2005 Blocked incoming UDP packet from 84.146.12.242:63892 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.44.244.217:63877 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.44.244.217:63877 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 60.20.55.183:16362 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.48.161.214:49807 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.44.244.217:63877 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.48.161.214:49777 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 212.10.139.185:1125 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.61.24.86:15006 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.48.161.214:49758 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:59 2005 Blocked incoming UDP packet from 84.61.24.86:15006 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 217.13.7.140:53 to 10.0.0.2:26540
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 84.61.24.86:15006 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 82.203.170.145:1687 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 84.146.12.242:63892 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 84.44.244.217:63877 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 212.10.139.185:1125 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 80.216.247.1:3983 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 219.130.67.238:15002 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:58 2005 Blocked incoming UDP packet from 82.203.170.145:1687 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:57 2005 Blocked incoming UDP packet from 84.73.126.67:1322 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:57 2005 Blocked incoming UDP packet from 218.249.213.50:21196 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:57 2005 Blocked incoming UDP packet from 82.203.170.145:1687 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:57 2005 Blocked incoming UDP packet from 219.137.41.78:22864 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:57 2005 Blocked incoming UDP packet from 82.121.95.97:3248 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:57 2005 Blocked incoming UDP packet from 84.73.126.67:1322 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:56 2005 Blocked incoming UDP packet from 82.121.95.97:3248 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:56 2005 Blocked incoming UDP packet from 84.73.126.67:1322 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:56 2005 Blocked incoming UDP packet from 83.148.67.90:2556 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:56 2005 Blocked incoming UDP packet from 84.134.198.118:61042 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:56 2005 Blocked incoming UDP packet from 82.121.95.97:3248 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:56 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:56 2005 Blocked incoming UDP packet from 84.134.198.118:61042 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 82.207.235.84:62861 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 212.71.186.225:13254 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 82.207.235.84:62861 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 84.134.198.118:61042 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 82.207.235.84:62861 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:55 2005 Blocked incoming UDP packet from 218.160.94.50:10633 to 10.0.0.2:11374
[iNFO] Thu Dec 29 19:52:54 2005 Blocked incoming UDP packet from 84.0.3.191:4503 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 200.232.184.188:50511 to 10.0.0.2:26540
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 84.0.3.191:4503 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 84.0.3.191:4503 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 82.251.35.166:4190 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 82.251.35.166:4190 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 201.224.119.38:12619 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:53 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:52 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:52 2005 Blocked incoming UDP packet from 70.105.141.111:2333 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:52 2005 Blocked incoming UDP packet from 84.54.209.97:3044 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:52 2005 Blocked incoming UDP packet from 84.113.49.90:1156 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:52 2005 Blocked incoming UDP packet from 83.148.67.90:2556 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:52 2005 Dropped TCP packet with invalid flags 0x11 from 63.245.92.214:61431 to 10.0.0.2:15310
[iNFO] Thu Dec 29 19:52:52 2005 Blocked incoming UDP packet from 84.175.40.56:33772 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:51 2005 Blocked incoming UDP packet from 84.175.40.56:33805 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:51 2005 Blocked incoming UDP packet from 83.148.67.90:2556 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:51 2005 Blocked incoming UDP packet from 84.54.209.97:3044 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:51 2005 Blocked incoming UDP packet from 84.175.40.56:33863 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:51 2005 Blocked incoming UDP packet from 82.251.35.166:4190 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:51 2005 Blocked incoming UDP packet from 84.134.102.87:1185 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:50 2005 Blocked incoming UDP packet from 84.134.102.87:1185 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:50 2005 Blocked incoming UDP packet from 84.134.102.87:1185 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:50 2005 Blocked incoming UDP packet from 83.223.172.108:1178 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:50 2005 Blocked incoming UDP packet from 83.223.172.108:1178 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:50 2005 Blocked incoming UDP packet from 84.9.87.201:7711 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:50 2005 Blocked incoming UDP packet from 83.223.172.108:1178 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:50 2005 Blocked incoming UDP packet from 83.223.172.108:1178 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:49 2005 Blocked incoming UDP packet from 84.155.45.210:61656 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:49 2005 Blocked incoming UDP packet from 84.155.45.210:61656 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:49 2005 Blocked incoming UDP packet from 84.155.45.210:61656 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:49 2005 Blocked incoming UDP packet from 24.42.253.48:1085 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:49 2005 Dropped TCP packet with invalid flags 0x11 from 83.31.104.36:4623 to 10.0.0.2:15600
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 84.154.104.79:21939 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 84.154.104.79:21939 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 84.154.104.79:21939 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 84.144.144.190:62453 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 84.144.144.190:62453 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 219.130.67.238:15002 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 83.213.121.30:1078 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 84.144.144.190:62453 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:48 2005 Blocked incoming UDP packet from 219.128.200.58:20887 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 83.213.121.30:1078 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 70.105.141.111:2333 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 82.17.159.110:1405 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 24.42.253.48:1085 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 72.228.39.167:35074 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 218.19.194.75:1501 to 10.0.0.2:11753
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 218.92.191.178:57789 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:47 2005 Blocked incoming UDP packet from 24.42.253.48:1085 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:46 2005 Blocked incoming UDP packet from 70.105.141.111:2333 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:46 2005 Blocked incoming UDP packet from 72.228.39.167:35074 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:46 2005 Blocked incoming UDP packet from 222.182.103.45:19866 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:46 2005 Blocked incoming UDP packet from 72.228.39.167:35074 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:46 2005 Blocked incoming UDP packet from 82.17.159.110:1405 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:46 2005 Blocked incoming UDP packet from 84.6.23.210:2157 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 81.248.121.242:1198 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 82.17.159.110:1405 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 81.248.121.242:1198 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 83.248.129.34:1636 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 84.140.207.68:1077 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 83.248.129.34:1636 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 84.6.23.210:2157 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 84.6.23.210:2157 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 84.140.207.68:1077 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 81.248.121.242:1198 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 83.248.129.34:1636 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:45 2005 Blocked incoming UDP packet from 84.140.207.68:1077 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:44 2005 Blocked incoming UDP packet from 61.228.148.4:30672 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:44 2005 Blocked incoming UDP packet from 221.11.110.61:18763 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:44 2005 Log viewed by IP address 192.168.0.80
[iNFO] Thu Dec 29 19:52:44 2005 Blocked incoming UDP packet from 218.14.146.117:3360 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:44 2005 Blocked incoming UDP packet from 217.80.159.241:1310 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:44 2005 Blocked incoming UDP packet from 217.80.159.241:1310 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:43 2005 Blocked incoming UDP packet from 217.80.159.241:1310 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:43 2005 Blocked incoming UDP packet from 87.219.13.23:17820 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:43 2005 Blocked incoming UDP packet from 83.55.118.82:19420 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:42 2005 Blocked incoming UDP packet from 83.8.6.88:1601 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:42 2005 Blocked incoming UDP packet from 84.128.72.164:24048 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:41 2005 Blocked incoming UDP packet from 84.128.72.164:23992 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:41 2005 Blocked incoming UDP packet from 84.128.72.164:23986 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:41 2005 Blocked incoming UDP packet from 84.128.72.164:23975 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:41 2005 Dropped TCP packet with invalid flags 0x11 from 83.17.252.210:3838 to 10.0.0.2:15310
[iNFO] Thu Dec 29 19:52:41 2005 Blocked incoming UDP packet from 83.8.6.88:1601 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:41 2005 Blocked incoming UDP packet from 83.8.6.88:1601 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:41 2005 Blocked incoming UDP packet from 219.156.201.222:15036 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:40 2005 Blocked incoming UDP packet from 218.250.80.87:12088 to 10.0.0.2:11374
[iNFO] Thu Dec 29 19:52:38 2005 Blocked incoming UDP packet from 222.67.88.176:17319 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:38 2005 Blocked incoming UDP packet from 218.103.134.25:16235 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:38 2005 Blocked incoming UDP packet from 71.81.44.121:22633 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:38 2005 Dropped TCP packet with invalid flags 0x11 from 83.85.22.169:6881 to 10.0.0.2:32958
[iNFO] Thu Dec 29 19:52:37 2005 Blocked incoming UDP packet from 222.69.29.252:1578 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:37 2005 Blocked incoming UDP packet from 84.6.141.147:14311 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:37 2005 Blocked incoming UDP packet from 81.104.139.85:1228 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 81.104.139.85:1228 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 81.104.139.85:1228 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 81.235.208.55:1945 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 84.6.141.147:14309 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 84.6.141.147:14309 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 84.6.141.147:14309 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 84.248.238.206:4556 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:36 2005 Blocked incoming UDP packet from 84.248.238.206:4556 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:35 2005 Blocked incoming UDP packet from 84.248.238.206:4556 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:35 2005 Blocked incoming UDP packet from 86.192.236.156:1728 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:34 2005 Blocked incoming UDP packet from 86.192.236.156:1728 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:34 2005 Blocked incoming UDP packet from 86.192.236.156:1728 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:34 2005 Blocked incoming UDP packet from 220.112.112.70:1492 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:34 2005 Blocked incoming UDP packet from 84.61.184.193:1190 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:34 2005 Blocked incoming UDP packet from 84.61.184.193:1190 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:34 2005 Blocked incoming UDP packet from 222.76.248.18:28752 to 10.0.0.2:13187
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 213.226.208.22:1273 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 83.248.129.34:1636 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 83.248.129.34:1636 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.158.126.81:1264 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.60.98.45:1783 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.158.126.81:1264 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.60.98.45:1783 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 213.226.208.22:1273 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.61.150.207:32899 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.60.98.45:1783 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 83.248.129.34:1636 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 80.144.84.31:29633 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.61.150.207:32899 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 213.226.208.22:1273 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:33 2005 Blocked incoming UDP packet from 84.158.126.81:1264 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:32 2005 Dropped TCP packet with invalid flags 0x18 from 81.196.99.131:1215 to 10.0.0.2:15600
[iNFO] Thu Dec 29 19:52:32 2005 Blocked incoming UDP packet from 62.59.125.49:16560 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:32 2005 Blocked incoming UDP packet from 84.173.3.243:61162 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:32 2005 Blocked incoming UDP packet from 84.173.3.243:61162 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:32 2005 Blocked incoming UDP packet from 84.61.150.207:32899 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:32 2005 Sending log email as log is full
[iNFO] Thu Dec 29 19:52:32 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:32 2005 Blocked incoming UDP packet from 84.173.3.243:61162 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:32 2005 Blocked incoming UDP packet from 212.242.130.125:26285 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 84.185.75.104:3398 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 84.185.75.104:3398 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 84.178.198.101:61564 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 86.197.73.166:2274 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 80.144.84.31:29633 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 84.178.198.101:61564 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:31 2005 Previous message repeated 2 times
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 86.197.73.166:2274 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:31 2005 Blocked incoming UDP packet from 84.185.75.104:3398 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:30 2005 Blocked incoming UDP packet from 86.197.73.166:2274 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:30 2005 Blocked incoming UDP packet from 218.160.48.28:21235 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:29 2005 Blocked incoming UDP packet from 84.147.99.16:1152 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:29 2005 Blocked incoming UDP packet from 68.198.253.73:6881 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:29 2005 Blocked incoming UDP packet from 84.147.99.16:1152 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:29 2005 Blocked incoming UDP packet from 80.144.84.31:29633 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:29 2005 Blocked incoming UDP packet from 82.227.225.217:1063 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:29 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:29 2005 Blocked incoming UDP packet from 82.227.225.217:1063 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:28 2005 Blocked incoming UDP packet from 59.105.128.119:9115 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:28 2005 Blocked incoming UDP packet from 82.227.225.217:1063 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:28 2005 Blocked incoming UDP packet from 84.147.99.16:1152 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:28 2005 Blocked incoming UDP packet from 81.235.208.55:1945 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:27 2005 Blocked incoming UDP packet from 83.11.222.206:9764 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:27 2005 Blocked incoming UDP packet from 84.176.123.20:63437 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:27 2005 Blocked incoming UDP packet from 84.176.123.20:63437 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:27 2005 Blocked incoming UDP packet from 84.176.123.20:63437 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:27 2005 Blocked incoming UDP packet from 84.176.123.20:63437 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:27 2005 Blocked incoming UDP packet from 62.178.87.38:1147 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 80.55.165.182:15730 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 84.177.182.175:64487 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 62.178.87.38:1147 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 62.178.87.38:1147 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 219.133.100.60:64007 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 87.123.114.228:60657 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 84.177.182.175:64487 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 84.177.182.175:64487 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 82.227.225.217:1063 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 81.38.221.133:9862 to 10.0.0.2:10459
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 207.38.8.29:4031 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 207.38.8.29:3962 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 207.38.8.29:4199 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 207.38.8.29:3975 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 87.123.114.228:60657 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 87.123.114.228:60657 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:26 2005 Blocked incoming UDP packet from 82.23.221.161:27755 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 87.123.114.228:60657 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 211.50.122.230:1214 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 211.50.122.230:1214 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 211.50.122.230:1214 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 220.191.47.15:1063 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 66.98.85.182:10678 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 84.177.182.175:64487 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 86.139.218.194:2513 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:25 2005 Blocked incoming UDP packet from 86.139.218.194:2513 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:25 2005 Dropped TCP packet with invalid flags 0x11 from 201.35.149.21:60217 to 10.0.0.2:15600
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 86.139.218.194:2513 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 84.57.70.34:17243 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 84.57.70.34:17243 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 83.223.172.108:1178 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 83.223.172.108:1178 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 84.177.82.86:3141 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 84.177.82.86:3141 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:24 2005 Blocked incoming UDP packet from 84.57.70.34:17243 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:23 2005 Blocked incoming UDP packet from 83.223.172.108:1178 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:23 2005 Dropped TCP packet with invalid flags 0x11 from 83.135.161.143:50001 to 10.0.0.2:48167
[iNFO] Thu Dec 29 19:52:23 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:23 2005 Blocked incoming UDP packet from 84.177.82.86:3141 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:23 2005 Blocked incoming UDP packet from 84.177.82.86:3141 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 218.14.252.93:13333 to 10.0.0.2:14938
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 83.201.224.82:2420 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 69.168.195.68:7740 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 71.247.159.172:1531 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 71.247.159.172:1531 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 83.131.21.149:3059 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 219.95.57.97:23230 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 81.5.162.237:48775 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:22 2005 Blocked incoming UDP packet from 81.5.162.237:48775 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 84.135.133.231:62444 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:21 2005 Allowed configuration authentication by IP address 192.168.0.80
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 83.131.21.149:3059 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 71.247.159.172:1531 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 84.157.0.61:63034 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 84.135.133.231:62444 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 83.131.21.149:3059 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:21 2005 Blocked incoming UDP packet from 84.135.133.231:62444 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:20 2005 Blocked incoming UDP packet from 83.201.224.82:2420 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:20 2005 Blocked incoming UDP packet from 59.104.5.181:26432 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:20 2005 Dropped TCP packet with invalid flags 0x18 from 65.189.250.195:60339 to 10.0.0.2:15310
[iNFO] Thu Dec 29 19:52:20 2005 Blocked incoming UDP packet from 83.201.224.82:2420 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:20 2005 Blocked incoming UDP packet from 71.82.76.25:1219 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:20 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:19 2005 Blocked incoming UDP packet from 83.201.224.82:2420 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:19 2005 Blocked incoming UDP packet from 85.124.12.47:19562 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:19 2005 Blocked incoming UDP packet from 85.124.12.47:19562 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:19 2005 Blocked incoming UDP packet from 195.210.197.91:18837 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:19 2005 Blocked incoming UDP packet from 71.82.76.25:1219 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:19 2005 Blocked incoming UDP packet from 85.124.12.47:19562 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:18 2005 Blocked incoming UDP packet from 71.82.76.25:1219 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:18 2005 Blocked incoming UDP packet from 222.65.135.218:17758 to 10.0.0.2:11563
[iNFO] Thu Dec 29 19:52:18 2005 Blocked incoming UDP packet from 61.46.156.23:33762 to 10.0.0.2:11374
[iNFO] Thu Dec 29 19:52:18 2005 Blocked incoming UDP packet from 87.231.14.7:3133 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:18 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:18 2005 Blocked incoming UDP packet from 87.231.14.7:3133 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:18 2005 Unable to send email (send status 2)
[WARN] Thu Dec 29 19:52:18 2005 SMTP client failed to send email
[WARN] Thu Dec 29 19:52:18 2005 SMTP failed during sender/recipient dialog
[iNFO] Thu Dec 29 19:52:18 2005 Dropped ICMP packet from 201.9.65.144 to 10.0.0.2 as unable handle packet header
[iNFO] Thu Dec 29 19:52:17 2005 Dropped TCP packet with invalid flags 0x15 from 201.9.65.144:35834 to 10.0.0.2:50192
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 87.231.14.7:3133 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 64.229.92.19:9755 to 10.0.0.2:27245
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 80.185.179.149:1177 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 80.185.179.149:1177 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 80.36.112.103:20994 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 84.162.78.248:2497 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 80.185.179.149:1177 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 80.185.179.149:1177 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:17 2005 Blocked incoming UDP packet from 84.157.63.64:64109 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 84.157.63.64:64109 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 84.162.78.248:2497 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 80.36.112.103:20994 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 80.36.112.103:20994 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 84.157.63.64:64109 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 81.235.208.55:1945 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 80.36.112.103:20994 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:16 2005 Blocked incoming UDP packet from 84.162.78.248:2497 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 84.145.251.182:3408 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 84.162.78.248:2497 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 84.145.251.182:3408 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 84.141.225.155:4558 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 82.158.108.75:3704 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 82.158.108.75:3704 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 84.145.251.182:3408 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:15 2005 Blocked incoming UDP packet from 219.146.94.130:62517 to 10.0.0.2:13187
[iNFO] Thu Dec 29 19:52:14 2005 Blocked incoming UDP packet from 82.158.108.75:3704 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:14 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:14 2005 Blocked incoming UDP packet from 84.97.172.232:16575 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:14 2005 Blocked incoming UDP packet from 82.158.108.75:3704 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:14 2005 Blocked incoming UDP packet from 84.183.108.156:3086 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:14 2005 Blocked incoming UDP packet from 84.145.251.182:3408 to 10.0.0.2:32869
[iNFO] Thu Dec 29 19:52:14 2005 Blocked incoming UDP packet from 81.13.226.29:60757 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:13 2005 Blocked incoming UDP packet from 81.13.226.29:60757 to 10.0.0.2:45077
[iNFO] Thu Dec 29 19:52:13 2005 Dropped TCP packet with invalid flags 0x18 from 82.160.73.70:2200 to 10.0.0.2:15600
[iNFO] Thu Dec 29 19:52:13 2005 Blocked incoming UDP packet from 86.202.228.254:1472 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:13 2005 Blocked incoming UDP packet from 84.183.108.156:3086 to 10.0.0.2:32504
[iNFO] Thu Dec 29 19:52:13 2005 Blocked incoming UDP packet from 84.183.108.156:3086 to 10.0.0.2:36133
[iNFO] Thu Dec 29 19:52:13 2005 Blocked incoming UDP packet from 81.210.34.17:8650 to 10.0.0.2:27245
Jeg har ikke klart å finne noe informasjon om disse portene. Har en mistanke om at denne trafikken eter den totale mengden båndbredde, siden jeg har problemer med ip-telefoni (les https://www.diskusjon.no/index.php?showtopic=508949&hl= )
Takker for all hjelp.
Det er klart at innkommende pakker, uønskede eller ei, tar opp båndbredde. Men jeg tviler på at det er årsaken til dine problemer med IP-telefoni.
Begrunnelsen min er todelt: For det første dreier dette seg om innkommende trafikk. Og du har høyst sannsynlig et internettabonnement som gir deg rikelig med båndbredde inn (altså download mer enn et par hundre kbit/s). Siden pakkene blokkeres blir det ikke sendt noe svar til avsenderen og dette belaster altså ikke båndbredden din ut selv om den ikke er så stor.
For det andre er faktisk ikke den loggede trafikken veldig stor. Det utsnittet du har limt inn viser blokkerte pakker på litt under et minutt. Nå har jeg ikke tatt meg tid til å telle antall pakker i loggen, men det er praktisk talt ingenting å snakke om båndbreddemessig.
Jeg kjenner heller ikke igjen portnummerene i farten, men ser ikke bort i fra at det kan dreie seg om fildelingsprogrammer - at du har kjørt slike programmer i lokalnettverket den siste uka, eller at en person som har hatt IP-adressen din før deg har gjort det.
Forøvrig er det alltid lurt å kjøre diverse anti-spyware programmer, særlig hvis du mistenker uønsket aktivitet i nettverket.
Nå har ikke jeg satt av "Dropped Packages" på min log men du sier da at alt kommer på samme port . Jeg ser da at det er snakk om ganske så mange porter .
Hvilken ISP har du og hvilken leverandør av Iptelefon ? Og i samme slengen spør jeg om du bruker mye P2P/BT ?
Denne loggen blir oppdatert konstant med nye oppføringer om blokkerte porter, sjekker jeg loggen nå er den full igjen med oppføringer fra de siste 5 minuttene. Vi prøvde å koble fra alle klienter i huset, vente 10min, for så å koble til igjen å så sjekke loggen. Det var fremdeles like mange, og like ofte, og på samme port, som var oppført i loggen.
Vi har NGT ~ 2500/600, og Telio VoIP.
Jeg skal ta å få sendt alle logger generet til meg selv, så kan dere så hvilket omfang det er snakk om.
Om du slår av alt utstyr i 10 minutter så vil ikke det ha noe å si. De pakkene som kommer inn blir jo allerede blokkert, det vil si av avsenderen bør skjønne at det ikke er noen tilstede som vil "snakke" med ham. Siden de allikevel fortsetter å komme, så sier det seg selv at avsenderen ikke bryr seg katta om hvorvidt du ønsker trafikken.
Fildelingsklienter har en tendens til å huske andre fildeleres IP-adresser i lang, lang tid. Det er derfor godt mulig, faktisk mest sannsynlig, at dette dreier seg om p2p-trafikk som ønsker å komme i kontakt med de fildelingsprogrammene som en annen bruker av samme IP-adresse har hatt gående.
Med mindre du har en statisk public IP-adresse hos NGT (og har hatt den lenge), så er jeg ganske sikker på at dette er resttrafikk etter tidligere p2p-fildeling.
Vet du hva? Hvis du ikke har statisk IP-adresse, prøv dette: Sjekk din public IP-adresse (f.eks. www.minip.no), disconnect/logg av NGT, vent litt, og logg på igjen. Sjekk adressen på nytt for å forsikre deg om at du har fått en ny. Hvis de samme avsenderadressene sender pakker til de samme portene dine, da har du grunn til å tro at det er noe muffens med en eller flere av maskinene dine (les: spyware).
En annen ting: Jeg kikket litt nærmere i loggen du postet først. Jeg ser at det ble blokkert en utgående (ødelagt) pakke fra 192.168.0.20:15600 i ditt lokale nettverk. Det er også flere blokkerte (ødelagte) innkommende pakker til port 15600. Jeg sier ikke at det er noen sammenheng, eller grunn til bekymring, men jeg ville ha tatt en grundig spywaresjekk av 192.168.0.20 i nettverket ditt.
