Thomson DTH-212 sone fri kode
Det står:
1. Ensure the onscreen display shows the standard menu as shown after power on
2. Using your remote control, press the buttons 1, 6, 7, 1 and 9, in order, one at a time
3. A new menu should appear showing the currently selected region
4. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 0 button for multi-region playback
5. Power off your player
5. Power on your player
Men kommer ingen ny meny opp.
Noen som kan hjelpe?
:yes:
