Show Off! Vis oss ditt interface.
Lettere oppdatert (Fubar og action bars)
Klikk for å se/fjerne innholdet nedenfor
Raid Frames (eldre screen)
Hva ser best ut?
8727437[/snapback]
Første! :dribble:
Sende, eller liste hva du bruker?
Første! :dribble:
8729523[/snapback]
Samme som tidligere i tråden:
28.05.2007 11:36 <DIR> .
28.05.2007 11:36 <DIR> ..
27.05.2007 00:05 <DIR> ArkInventory
26.05.2007 13:45 <DIR> Bartender3
26.05.2007 13:36 <DIR> Blizzard_AuctionUI
26.05.2007 13:36 <DIR> Blizzard_BattlefieldMinimap
26.05.2007 13:36 <DIR> Blizzard_BindingUI
26.05.2007 13:36 <DIR> Blizzard_CombatText
26.05.2007 13:36 <DIR> Blizzard_CraftUI
26.05.2007 13:36 <DIR> Blizzard_GMSurveyUI
26.05.2007 13:36 <DIR> Blizzard_InspectUI
26.05.2007 13:36 <DIR> Blizzard_ItemSocketingUI
26.05.2007 13:36 <DIR> Blizzard_MacroUI
26.05.2007 13:36 <DIR> Blizzard_RaidUI
26.05.2007 13:36 <DIR> Blizzard_TalentUI
26.05.2007 13:36 <DIR> Blizzard_TradeSkillUI
26.05.2007 13:36 <DIR> Blizzard_TrainerUI
26.05.2007 14:13 <DIR> Cartographer
01.01.2007 19:19 <DIR> CECB_Debuffs
24.12.2006 02:17 <DIR> CECB_Options
12.01.2007 14:53 <DIR> CECB_PvEModule
02.02.2007 21:01 <DIR> CECB_PvPModule
05.03.2007 13:21 <DIR> CEnemyCastBar
12.02.2007 05:00 <DIR> ClearFont
26.05.2007 18:55 <DIR> Click2Cast
26.05.2007 18:55 <DIR> ColaLight
26.05.2007 13:45 <DIR> eePanels
26.05.2007 13:45 <DIR> ElkBuffBars
26.05.2007 13:45 <DIR> EnhancedColourPicker
26.05.2007 13:45 <DIR> FishingAce
26.05.2007 15:35 <DIR> FramesResized
26.05.2007 18:58 <DIR> FuBar
26.05.2007 18:58 <DIR> FuBar_ClockFu
26.05.2007 18:58 <DIR> FuBar_MailFu
26.05.2007 18:58 <DIR> FuBar_MoneyFu
26.05.2007 18:58 <DIR> FuBar_PerformanceFu
27.05.2007 00:05 <DIR> FuBar_TopScoreFu
26.05.2007 18:58 <DIR> FuBar_VolumeFu
26.05.2007 14:13 <DIR> InFlight
26.05.2007 14:13 <DIR> InFlight_Load
06.03.2007 02:06 <DIR> ItsPolyquip
28.05.2007 11:36 0 maplist.txt
25.05.2007 17:27 <DIR> OmniCC
26.05.2007 13:45 <DIR> PitBull
26.05.2007 13:46 <DIR> Prat
26.05.2007 13:45 <DIR> Quartz
26.05.2007 15:37 <DIR> RatingBuster
26.05.2007 14:24 <DIR> sct
26.05.2007 14:24 <DIR> sct_options
26.05.2007 15:42 <DIR> simpleMinimap
26.05.2007 18:58 <DIR> Violation
26.05.2007 13:45 <DIR> XLoot
26.05.2007 13:45 <DIR> XLootGroup
26.05.2007 13:45 <DIR> XPBarNone
1 fil(er) 0 byte
53 mappe® 132ÿ828ÿ655ÿ616 byte ledig
I tillegg til cycircled og cycircled_vol
min for øyeblikket, sitter å funderer på om jeg skal hive innpå noe mer, burde vertfall gjort noe med chatframes.. forminske, flytte, elns
*bilde*
8730042[/snapback]
Hvordan fikk du den fete skriften?
8730197[/snapback]
lasta ned fra deviantart.com, bytta ut adventure skriften i pitbull unitframes'n:)
*bilde*
8730042[/snapback]
8730197[/snapback]
8730836[/snapback]
Mulig å forklare for en som meg? :p
*bilde*
8730042[/snapback]
8730197[/snapback]
8730836[/snapback]
8731356[/snapback]
Eller bare uploade AG_UnitFrame mappa di, så vi andre kan nyte den og
:wee:
Hva ser best ut?
8727437[/snapback]
Hvilken mod viser raidet ditt på den måten?
8728819[/snapback]
PerfectRaid..
Fra wowinterface.com
8729515[/snapback]
Takk for svar, jeg finner dog ikke utav hvordan jeg farger healthbaren til folk på grunnlag av hvilken klasse de er.. ser ingenting om det i PerfectRaid options menu.
Hva ser best ut?
8727437[/snapback]
8728819[/snapback]
PerfectRaid..
8729515[/snapback]
8732772[/snapback]
/perfectraid - Trykk på "raid frames tab'en - merk den gruppa som er der (default er at den lister opp classnames - Trykk edit - huk av color bars by class (og show group number er min preferanse) - Trykk save..
Voila!
