A/D-konvertere på lydkort
Er i utgangspunktet interessert i lydkortene EMU1820 eller EMU1820m, men de har forskjellige AD- og DA-konvertere.
Ser like ut, men 1820m har altså sync.kort og en annen A/D- og D/A-konverter:
1820 har: A/D: Texas Instruments PCM1804 og D/A: Cirrus Logic CS4392
mens
1820m har: A/D: AKM AK 5394A og D/A: Cirrus Logic CS4398
Hvem har best konvertere av disse to? Jeg er ute etter kvalitetsmessig lyd og vil ha bra konvertering begge veier.
De resulterer iallfall i disse spesifikasjonene her (www.procom.no):
1820
* Premium 24-bit/192kHz converters - 112dB signal-to-noise ratio for pristine recording and playback of your tracks
* Sample Rates: 44.1, 48, 96, 192kHz from internal crystal or externally supplied clock (no sample rate conversion)
Analog Line Inputs (6)
* Type: servo-balanced, DC-coupled, low-noise input circuitry
* Level (software selectable):
o Professional: +4dBu nominal, 20dBu maximum (balanced)
o Consumer: -10dBV nominal, 6dBV maximum (unbalanced)
* Frequency Response: +0.0/-0.2dB, 20Hz - 20kHz
* THD+N (1kHz at -1dBFS): -102dB (.0008%)
* SNR (A-weighted): 111dB
* Dynamic Range (1kHz, A-weighted): 112dB
* Stereo Crosstalk (1kHz at -1dBFS): < -115dB
* Common-Mode Rejection (60Hz): > 40dB
Analog Line Outputs (8)
* Type: balanced, low-noise, 3-pole low-pass differential filter
* Frequency Response: +0.0/-0.8dB, 20Hz - 20kHz
* THD+N (1kHz signal at -1dBFS): -98dB (.0013%)
* SNR (A-weighted): 112dB
Synchronization
* Internal crystal sync at 44.1, 48, 96, 192kHz
* External sample rate sync
o ADAT
o S/PDIF (opt. or coax)
Retail Box Contents
* E-MU® 1010 PCI card
* E-MU AudioDock M
* EDI (E-MU Digital Interface) cable (3 meters)
* Mini-DIN MIDI adapter cable
* Headphone splitter cable
* PC power cable
* Quick Start guide
* Operation Manual on CD-ROM
* Creative Professional Software CD-ROM
o Windows 2000 and XP Drivers
o E-MU PatchMix DSP
o E-MU E-DSP FX Library
* E-MU Production Tools Software Bundle CD-ROM
o Cakewalk SONAR LE
o Steinberg Cubase LE
o Ableton Live Lite 4 for E-MU
o Steinberg Wavelab Lite
o IK Multimedia AmpliTube LE
o IK Multimedia T-RackS EQ
o Minnetonka diskWelder BRONZE
o SFX Machine LT
o E-MU Proteus X LE (over 1000 sounds included)
1820m
* Frequency Response: +/- .05dB, 20Hz - 20kHz
* THD+N (1kHz at -1dBFS): -110dB (.0003%)
* SNR (A-weighted): 120dB
* Dynamic Range (1kHz, A-weighted): 120dB
* Frequency Response: 0.0/-.35dB, 20Hz - 20kHz
* THD+N (1kHz at -1dBFS): -105dB (.0006%)
Synchronization
o ADAT
o Word clock (75 ohm termination, switchable)
* SMPTE LTC Timecode
o Converts between longitudinal time code (LTC) to MIDI time code (MTC)
o Regen, stripe, and conversion modes
o 24, 25, 30 drop, 30 non-drop frames/sec
o Compatible with 29.97 fps timecode
o Input level: 0.5 - 4V p-p
o Output levels: +4dBu, -10dBV (software selectable)
o Input Impedance: 10K ohms
M er best. Og dyrest. Om det er verdt det er opp til deg.
Jeg bruker 1212M, er veldig fornøyd. Men når du først tenker å bruke la oss si 6000kr på 1820M, ville jeg kanskje vurdert et firewire eller USB2-basert kort, siden dette er mer fleksibelt med tanke på bytte av PC og bruk i felten med bærbare maskiner.
Vel, jeg er enig med deg angående fleksibiliteten, men tenker fortsatt å satse på stasjonert. Utgangspunktet mitt var å få tak i et rent PCI-kort som var bra på lyd. Men jeg fant ikke noe som hadde bra nok utvalg i lydutganger m.m. (trengte muligheten for XLR-tilkobling) Antok også at det er bedre med preamp i en outbreakbox enn på PCI-kortet (hvis det finnes) Er det noe bruk for sync.kortet som er på m-modellene (får tak i 1820m til underkant av 4000NOK)?
Hvor mange inn/ut trenger du?
XLR-tilkobling er ikke alltid et must. E-mu 1212m har 2 inn og 2 ut på TRS, og disse pluggene har like mange tråder som XLR (3), og man får kjøpt TRS til XLR-kabler på alle musikkforretninger.
Angående preamp, så får man ikke kjøpt PCI-kort med preamper direkte på kortet, de tar for mye plass. Så evt. mikrofoner til 1212m må mates gjennom en ekstern mic-forsterker.
Sync-kortet er bare for word-clock, og du trenger det bare hvis du har flere digitale enheter som skal jobbe samtidig, eller hvis du vil drive d/a-convertere med klokkesignal fra lydkortet (noe som gir bedre resultat hvis convertere i f.eks en ekstern opptaker har en mindre bra klokkekilde innebygd). De fleste hjemmebrukere får ikke bruk for dette.
  • 2 uker senere...
Det varierer hvor mange inn/ut jeg trenger, alt fra 2 til 6.
Det sier seg selv at XLR-tilkobling gir mindre signalforstyrrelser og dermed bedre lyd. E-mu 1212m virker også grei, men jeg savner MIDI-kontaktene.
Dessuten er det greit å kunne justere volum på monitor eller head-set på break-out boksen. Trenger også bra pre-preamp. Har senere planer om å investere i et par mikker. AD- og DA-konverterne er hovedgrunnen til at jeg satser på 1820m, de skal visst være bra.
Jeg skal bruke flere digitale enheter og trenger muligens sync-kortet med word-clock. Jeg har et digitalt piano som jeg bruker å skrive inn noter med, spille osv.
og det er svært viktig at lyden kommer samtidig.
"De fleste hjemmebrukere får ikke bruk for dette. "
Jeg jobber som musiker og kan vel ikke karakteriseres som vanlig hjemmebruker av lydkort. :hrm:
Endret av 7r
Jeg er også musiker, og har ennå ikke hatt bruk for word clock... Er jeg ikke avansert nok for deg? :-p
1212M har midi-inn og ut, men hvis du har planer om mikrofoner er det bedre å gå for 1820M. 1212M og 1820M benytter samme convertere.
Det digitale pianoet klarer seg lenge med MIDI.
