Problem med vpn-server
simrem
Hei.
Prøver å sette opp vpn-server med OpenSWAN, l2tpd og pppd, men får litt problemer med å koble meg til.
All programvare ser ut som å fungere.
Har brukt guiden på http://megaz.arbuz.com/archives/2005/01/28/linux-vpn-guide/
men når jeg prøver å logge meg på logger linux dette...
Dec 20 21:48:57 anonym pluto[1596]: packet from 195.159.177.236:500: ignoring Vendor ID payload [MS NT5 ISAKMPOAKLEY 00000004]
Dec 20 21:48:57 anonym pluto[1596]: packet from 195.159.177.236:500: ignoring Vendor ID payload [FRAGMENTATION]
Dec 20 21:48:57 anonym pluto[1596]: packet from 195.159.177.236:500: received Vendor ID payload [draft-ietf-ipsec-nat-t-ike-02_n] method set to=106
Dec 20 21:48:57 anonym pluto[1596]: packet from 195.159.177.236:500: ignoring Vendor ID payload [Vid-Initial-Contact]
Dec 20 21:48:57 anonym pluto[1596]: packet from 195.159.177.236:500: initial Main Mode message received on 192.168.1.100:500 but no connection has been authorized
Hva har jeg gjort galt?
kan legge til litt til info...
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address              Foreign Address            State
tcp        0      0 *:32769                    *:*                        LISTEN
tcp        0      0 *:netbios-ssn              *:*                        LISTEN
tcp        0      0 *:sunrpc                    *:*                        LISTEN
tcp        0      0 *:10000                    *:*                        LISTEN
tcp        0      0 localhost.localdomain:ipp  *:*                        LISTEN
tcp        0      0 localhost.localdomain:5335  *:*                        LISTEN
tcp        0      0 *:smtp                      *:*                        LISTEN
tcp        0      0 *:microsoft-ds              *:*                        LISTEN
tcp        0      0 *:imap                      *:*                        LISTEN
tcp        0      0 *:http                      *:*                        LISTEN
tcp        0      0 *:ssh                      *:*                        LISTEN
tcp        0      0 *:https                    *:*                        LISTEN
udp        0      0 *:32768                    *:*
udp        0      0 localhost.localdomain:32776 *:*
udp        0      0 192.168.1.100:netbios-ns    *:*
udp        0      0 *:netbios-ns                *:*
udp        0      0 192.168.1.100:netbios-dgm  *:*
udp        0      0 *:netbios-dgm              *:*
udp        0      0 *:10000                    *:*
udp        0      0 localhost.localdomain:4500  *:*
udp        0      0 192.168.1.100:4500          *:*
udp        0      0 *:l2tp                      *:*
udp        0      0 *:972                      *:*
udp        0      0 *:5353                      *:*
udp        0      0 *:sunrpc                    *:*
udp        0      0 localhost.locald:isakmp    *:*
udp        0      0 192.168.1.100:isakmp        *:*
udp        0      0 *:ipp                      *:*
Active UNIX domain sockets (only servers)
Proto RefCnt Flags      Type      State        I-Node Path
unix  2      [ ACC ]    STREAM    LISTENING    6139  @/tmp/hald-local/dbus-PZRtUPkKuo
unix  2      [ ACC ]    STREAM    LISTENING    5840  /tmp/.font-unix/fs7100
unix  2      [ ACC ]    STREAM    LISTENING    5615  /var/run/dovecot-login/default
unix  2      [ ACC ]    STREAM    LISTENING    5717  /dev/gpmctl
unix  2      [ ACC ]    STREAM    LISTENING    5937  /var/run/dbus/system_bus_socket
unix  2      [ ACC ]    STREAM    LISTENING    5009  /var/run/pluto/pluto.ctl
