trenger info ang da09225r12u
RiFkinD
jeg har en Shuttle SN95G5 med standarvifta : da09225r12u i. denne syns jeg bråker veldig mye plus at cpu min blir liggende på høy tempratur.
Vurderer å bytte ut denne viften, men kan ikke finn noe om støynivået til viften jeg har i, eller hvor mye luft den flytter. Hvis noen har peiling på hvor jeg kan finne det, slik at jeg kan få en bedre vifte enn det jeg har, så hadde det vært kjempeflott
REF: http://global.shuttle.com/Product/Barebone/SN95G5.asp
As mentioned, the XPC SN95G5 features a new 92mm Smart Fan, which moves (50CFM) a great volume of air. This fan features a 4-pin header, i.e PWM spec, and be linearly controlled in BIOS, which means that "fan cycling" is a thing of the past.
Bruker du denne?
Surely, by now, everyone is aware of Cool'n'Quiet, but for the record, here is a quick summary:
Cool'n'Quiet dynamically varies the CPU clock speed and voltage so that it is not under heavy load, the power draw and heat disspation is minimal, but makes the full power of the CPU available instantly whenever the load goes up.
To enable CnQ, one has to have a CnQ supported motherboard, then download and install the CPU driver from AMD's web site and set the Power Option Properties in Windows to Minimal Power Management. There are several versions of the CPU driver, for various operating systems.
AMD Athlon™ 64 Processor Driver for Windows XP and Windows Server 2003 Version (exe) 1.2.2.2 - Allows the system to automatically adjust the CPU speed, voltage and power combination that match the instantaneous user performance need. Download this Setup Installation program (EXE) to automatically update all the files necessary for installation. This package is recommended for users whom desire a graphical user interface for installation. This .EXE driver is a user friendly localized software installation of the driver designed for end-users. This driver supports AMD Athlon 64 processor on Windows XP SP2 and Windows 2003 SP1. Driver for XP: http://www.amd.com/us-en/assets/content_ty...ties/amdcpu.exe
Vifta bør vel blåse luft ut bak.
Bruker du denne?
Ja, den bruker jeg. hva betyr 50 cfm?
fins ingen info på hvor mye bråk den lager?
Endret av RiFkinD
hva betyr 50 cfm?
kan jeg regne fra cfm over til m²? eller hva står det for?
Har ikke funnet andre data på denne viften når jeg Gogglet litt rundt.
cfm = cubic feet per minute
50 cfm = 1.42 cubic meter per minute (m3/min) = 85 cubic meter per hour (m3/h)
Ser fra både Microplex.no og andre sider at en vifte på 92x92x25mm med ca. 50cfm / 85m3/h luftmengde ligger med ett dB-tall på rundt 32-33dB, noe som i utgangspunktet er lite støy. Støyen er også avhengig av hvor mye motstand vifta og luften møter og utformingen på disse rillene i din kjøler kan også lage lyd.
Ser fra tester av dette kabinettet at vifta sjeldent går med full hastighet, dette selvfølgelig avhengig av prosessor og bruk. Ville sjekket kontaktflatene mellom kjøler og prosessor og påsett at det er optimal kontakt, med kun bruk av ett tynt lag med kjølepasta.
cpu min ligger på 38 grader idle, ved ved 50% vifte og oppover
Synes ikke akkurat 38°C er varmt på idle da. Min P4 3.0GHz/PC800 har siste 5 dager ett gjennomsnitt på 39°C, med maks på 57°C. Tviler på at du får til en bedre kjøling i kabinettet ditt. Støyen kan jeg ikke uttale meg om.
Skal du kjøpe deg noe ny vifte ville jeg sett på en av disse, noe økning i både dB og volum:
http://www.microplex.no/product.aspx?pid=3412NGH&mcat=c359
http://www.microplex.no/product.aspx?pid=3412NGHH&mcat=c359
Husk at 10dB økning er det samme som dobling av støynivået.
REF: http://www.silentpcreview.com/modules.php?...rtid=121&page=1
Endret av Pingla
