Den store Mediaportal-tråden - 1.2.3 sluppet 13.04.2012
Spragleknas
Etter nok en reinstallasjon, denne gangen med Microsoft SQL, så ser det ut som om guiden fungerer, men nå vil den ikke starte avspillingen
2008-11-14 12:51:14.748666 [Debug][MPMain]: Window: TvPlugin.TVHome init
2008-11-14 12:51:14.769666 [info.][MPMain]: Recorder: stop
2008-11-14 12:51:15.174666 [info.][CommandProcessor]: Commandprocessor: Stopping all tuners
2008-11-14 12:51:15.174666 [info.][CommandProcessor]: Commandprocessor: Stopped
2008-11-14 12:51:15.273666 [info.][MPMain]: ChannelNavigator::Reload()
2008-11-14 12:51:15.274666 [info.][MPMain]: get channels from database
2008-11-14 12:51:15.289666 [info.][MPMain]: found:27 tv channels
2008-11-14 12:51:15.290666 [info.][MPMain]: TvNotify:OnNotifiesChanged
2008-11-14 12:51:15.290666 [info.][MPMain]: Checking if radio group for all radio channels exists
2008-11-14 12:51:15.307666 [info.][MPMain]: Done.
2008-11-14 12:51:15.307666 [info.][MPMain]: get all groups from database
2008-11-14 12:51:15.324666 [info.][MPMain]: loaded 1 tv groups
2008-11-14 12:51:15.326666 [info.][MPMain]: tv home init:TVSunnmøre
2008-11-14 12:51:15.327666 [info.][MPMain]: tv home init:TVSunnmøre done
2008-11-14 12:51:18.289666 [Debug][MPMain]: miniguide: domodal
2008-11-14 12:51:18.290666 [Debug][MPMain]: WindowManager: route TvPlugin.TVHome:1->TvPlugin.TvMiniGuide:3009
2008-11-14 12:51:18.301666 [Debug][MPMain]: Window: TvPlugin.TvMiniGuide init
2008-11-14 12:51:18.303666 [Debug][MPMain]: miniguide: onpageload
2008-11-14 12:51:18.305666 [Debug][MPMain]: miniguide: all controls are reset after 2ms
2008-11-14 12:51:18.324666 [Debug][MPMain]: miniguide: GetChannelListByGroup caching channels from db.
2008-11-14 12:51:18.433666 [Debug][MPMain]: miniguide: FillChannelList - channel states returned : 19 - 69 ms
2008-11-14 12:51:18.440666 [Debug][MPMain]: miniguide: state check + filling completed after 69ms
2008-11-14 12:51:18.446666 [Debug][MPMain]: miniguide: FillGroupList finished after 0ms
2008-11-14 12:51:24.770666 [Debug][MPMain]: miniguide: close()
2008-11-14 12:51:24.771666 [Debug][MPMain]: miniguide: OnPageDestroy
2008-11-14 12:51:24.771666 [Debug][MPMain]: Window: TvPlugin.TvMiniGuide deinit
2008-11-14 12:51:24.779666 [Debug][MPMain]: TextureManager: CleanupThumbs()
2008-11-14 12:51:24.780666 [Debug][MPMain]: WindowManager: unroute to TvPlugin.TvMiniGuide:3009->TvPlugin.TVHome:1
2008-11-14 12:51:24.782666 [Debug][MPMain]: miniguide: closed
2008-11-14 12:51:24.810666 [Debug][MPMain]: miniguide: close()
2008-11-14 12:51:24.810666 [Debug][MPMain]: miniguide: OnPageDestroy
2008-11-14 12:51:24.811666 [Debug][MPMain]: Window: TvPlugin.TvMiniGuide deinit
2008-11-14 12:51:24.811666 [Debug][MPMain]: TextureManager: CleanupThumbs()
2008-11-14 12:51:24.812666 [Debug][MPMain]: miniguide: closed
2008-11-14 12:51:24.818666 [info.][MPMain]: TVHome.ViewChannelAndCheck(): View channel=NRK1 Møre og Romsdal
Og der fryser hele programmet.
Har skrudd av firewall på både klient og server.
Jeg får ikke my youtube plugin till å virke, noen tips her?
Har lagt inn plugin i riktig mappe, får søkt og får opp treff, men det stopper opp når jeg prøver å spille av.
Bruker ffdshow som jeg trodde skulle ta seg av riktig codec, men får likevel feilmelding om at den ikke kan spille av filen.
Var forresten ikke jeg som spurte etter hjelp til backup av epg delen:)
Hmmm
Trodde ikke jeg skulle si dette, men nå vurderer jeg og gå tilbake til vista igjenn...
Får ikke til dette med HD i xp...
Jeg får kjørt Blueray filmer uten problem og har prøvd både power dvd 7, coreavc og ffdshow codecs...
Men HD tv, neida det fungerer ikke...
Noen gode tips før jeg bytter over?
Synes dette er veldig rart. Kan du starte en tråd i MP forum med HW og SW detaljer + logger?
Evt gjøre det samme her?
Noen andre enn meg som sliter med rett tid på EPGen for tida?
På alle mine kanaler har "Ingen T-guide data tilgjengelig" på "nå"
Og på f.eks. TV2, står det "Neste: Den syvende himmel" og det må vel være en 3-4 timer feil?
Fii +1 time selv nå. Skal sjekke det.
EDIT: Viste seg at tidkorrigering var aktivert (dog h=0, m=o). Skrudde det av og alt var OK.
Endret av Spragleknas
Heisann
Jeg sliter nå med disse HD kanalene jeg...
Jeg kjører win xp med et firedtv-s2 kort med cam og Canal Digital Familie abb...
Men når jeg søker inn kanaler så tar den ikke inn HD kanalene...
Jeg har aktivert cam og aktivert DVB-S2 tuning.
Jeg har scannet Thor 3/5 0,8W men finner ikke fler thor satelitter...
Noen som kan hjelpe meg med hva som hindrer meg i og se HDtv?
Mvh
Kjell
Endret av kjeb
heisann
Skal kjøpe rikstv nå og ser etter hva slags utstyr jeg trenger, har en htpc ved den ene tvn og en ny er på vei til den andre samt jeg har en laptop som jeg ser på i sengen av og til.
Så til planen, jeg tenker å kjøpe tre dvb-t kort og så dele med tvserveren til mediaportal. Og da kommer spørsmålene
Støtter mediaportal sin tvserver dette?
Trenger jeg et stk dekoderkort til hvert tvkort om de står i samme pc? (evt kan jeg klare meg med et fire/floppydtvkort og to billige dvb-t kort?)
Ser at noen nevner at jeg kan klare meg med færre kort siden rikstv sender tre kanaler pr frekvens, stemmer dette?
htpcen som skal dele har 4*2.4@3ghz så det burde vel holde en stund til dekoding og enkoding?
Transponderlisten til RiksTV ser ut som noe ala dette:
NRK2
NRK3
(Og regner med at NRK Midtnytt og NRK tegnspråk også hører hjemme her)
TV2
TV2Zebra
TV2Film
Discovery
Animal Planet
TV2 Nyhetskanalen
TVNorge
SportN
National Geographic
FEM
BBC World News
TVSunnmøre (lokaltv)
TV3
Viasat 4
Disney Channel
Og merkelig nok også disse:
NRK1, 2 og 3
Jeg har bare testet med to HTPCer, så vet ikke om det fungerer på flere (dette kommer ann på hvor mange kanaler tv-kortet kan decode har selv floppyDTV, og denne klarer som sagt minst to)
Dette betyr at du kan sitte og se nrk1 på ei maskin samtidig som du ser nrk2 på ei anna med bare ett kort.
Men om du ønsker å se på NRK1 og TV2 samtidig må du ha to kort.
Ett kort kan dekode x antall kanaler på en transponder (--- linjene skiller transponderene fra hverandre) om gangen. Der x er det antallet kanaler ett kort kan dekode, FloppyDTV kan ihvertfall dekode to kanaler samtidig utfra det jeg har testet. Du kan f.eks sitte og se på NRK1 og NRK2 på to forskjellige TVer med ett kort, men om du ønsker å se på NRK1 og TV2 samtidig må du ha to kort.
For å kunne se på f.eks NRK1, TV2, TVNorge og TV3 samtidig, så må du ha 4 firedtv kort og 3 dekoderkort. (NRK trenger ikke dekoderkort)
Endret av zicoz
  • 2 uker senere...
Og da er rc4 instalert...
Men jeg får fremdeles ikke inn hd-kanalene til Canal Digital...
Jeg har søkt inn Thor 3/5 og nærmere googling viser at de skal ligge der...
Jeg har som tidligere aktivert cam og dvb s2 tuning uten at jeg får søkt inn noen HD kanaler...
Noen som kan hjelpe meg på vei? *hjelp*
-Kjell
Endret av kjeb
