Spragleknas Skrevet 17. november 2007 Forfatter Rapporter Del Skrevet 17. november 2007 Var som f at jeg stresset med å legge inn RC2 i går da Hvorfor la du inn RC2? RC3 var jo siste RC før final? ANYWAYS: Litt om MPII Announcement: MediaPortal II Written by infinityloop, on 16-11-2007 10:05 About a year ago some of the team members came together to discuss the future of MediaPortal. We evaluated the current situation and realized that we where running into problems. Over the last few years MediaPortal has grown and grown and we've reached a point where it is getting harder and harder to get MediaPortal stable and add new features to MediaPortal. This means release schedules kept moving and developers where spending more time fixing bugs then actually adding new features or enhancing existing features. Another trend we see is that the HTPC community has been changing. When we started developing MP a few years ago, we had this idea of a stand-alone PC in your living room holding all your media and playing it back on your TV. But today we're moving to a networked enviroment where you want to watch your media anywhere. In the living room, kitchen, bedroom, on your xbox360 but also remotely for example on your ipod video, zune or via the internet. It became clear that MediaPortal as it is today is not ready for the future and that something had to be done. So some members of the MediaPortal Team started thinking about a new generation of MediaPortal, called MediaPortal II. At the time I'm writing this MediaPortal II is still in a very early stage and not as feature rich as Mediaportal I. We will soon release an alpha release of Mediaportal II (codename Infinity) to the public to play with and offcourse to receive feedback and suggestions. With the release of Infinity (the alpha version of MediaPortal II) we will also present a roadmap for MediaPortal II. This roadmap which will show what features will be added in the upcoming versions and whats the planned release date for each version. What is MediaPortal II? With MediaPortal II we have decided to start from scratch to get a better design and architecture. Architecture The biggest problem we have with MediaPortal I is that the architecture is not flexible enough. Because of this many features get hardcoded and behaviour is hard to change. Developing plugins for MP-1 required great knowledge of the entire MP code. Our main goals for MediaPortal II are: stable & flexible and yet easy to understand. This means that the for endusers, skinners and plugin developers it should be possible to change anything they want while keeping things simple for beginners. We want MP-II to be very easy to use and configure, even for people who never seen it before. some examples of what MediaPortal II should be able to do * menu customizations: end users, plugin developers and skinners can create, change and modify menus * skin customizations: a skin can be easily customized by using themes * metadata customizations: an end user can easily change whats shown onscreen * auto updating: an end user should be able to select, download, install new plugins from within MediaPortal II using a nice GUI Another concept we introduced in MP-II is that its build around (internal) services. The core implements all features as services. These services can be used by plugin developers and they even can enhance or replace those services with more advanced versions. They can also add there own services which can then be used by other plugins. We also have a message broker in MP-II. A plugin can subscribe to messages send by the core to do some action but it can also create and send its own messages to others Expandability With MediaPortal II we are going a new way. The main application will only provide basic functionality. But because of the new design, community plugin authors will have much more freedom and power for their cool features. MediaPortal II also contains an inbuild version of the MPI (MediaPortal Installer) which will allow the user to browse the online repository, download, install and configure available plugins and skins without leaving MediaPortal II. This means that because MediaPortal II will be and stay a slim application, it will be much more stable then MediaPortal I is. Community Plugins will be playing an much more important part in the MediaPortal II. This also means that because we will have less bug hunting to do for the main application, we will have more time on our hands for support. Configuration: MediaPortal II will allow the user to do as much configuration as possible inside the main application. For advanced settings like creating new views and changing the menu, you will have an external configuration tool available. The great thing about this external tool is that it will be completely localized. Skinengine: In the very early stages we have been evaluating WPF/XAML for the skinengine. WPF/XAML is a great technology allowing for fanastic graphics gui's. However when playing with it we discovered that WPF/XAML is missing some key features needed for building a media center. So we developed our own new DirectX based skinengine, which uses the same architecture as XAML/WPF and is easy to understand for skinners. Since one of the design goals of MP-II is flexibility we have the option to replace the skinengine with a WPF/XAML engine when WPF/XAML has matured and can be used for building media center type of applications. LIST OF SKINENGINE FEATURES * complete separation between GUI and code * databinding * commands * styles and templates * 2D and 3D * animations * flexible and easily expandable * supports vertex and pixel shaders * supports use of scripts * supports themes Current Feature List: * UPnP: o MP-II contains an internal UPnP server o MP-II can control & render media from any other UPnP server * Picture in Picture (PIP) * Intelligent Zoom * My Pictures * My Movies (+DVD) * My Music * Settings * Extensions installer for skins, plugins ect. (known as MPI) * Core: o new skinengine (see feature list above) o Customizable menus o customizable views o general media manager o general database manager o Message broker As you can see there is no Tv or Radio yet. Infinity will be an alpha release which is not feature complete. Of course those missing features will be added in the next version (codename Haïti). We have created a new forum thread and are looking forward to your comments and thoughts. Note: The announcement of MediaPortal 2 does not mean that the current Version is now dead and abandoned. We will post news about the future of "the old lady" and the TV-Server very soon. Kilde: http://www.team-mediaportal.com/news/globa...iaportal_2.html Lenke til kommentar
DrErling Skrevet 17. november 2007 Rapporter Del Skrevet 17. november 2007 Var som f at jeg stresset med å legge inn RC2 i går da Hvorfor la du inn RC2? RC3 var jo siste RC før final? Hmm, ved nærmere ettersyn var det RC3. Samma det :-) Blir kult med II'en! Lenke til kommentar
joffe11 Skrevet 21. november 2007 Rapporter Del Skrevet 21. november 2007 Hei Jeg bruker Media Player Classic som avspiller i mediaportal. Noen som vet hvordan jeg kan få stillt inn den slik at den som standard lukker seg automatisk når filen er ferdigspilt. Lenke til kommentar
Admin'c Skrevet 21. november 2007 Rapporter Del Skrevet 21. november 2007 *hate folk som ikke googler* http://wiki.framasoft.info/DocumentationMe...sic/CommandLine Lenke til kommentar
joffe11 Skrevet 21. november 2007 Rapporter Del Skrevet 21. november 2007 (endret) må være slitsomt å hate folk for så lite. Har faktisk prøvd å google, men fant ikke noe. Forstår ikke helt hvordan jeg skal benytte Commandline sammen med MP. Noen som kan hjelpe. Kommandoen er tydeligvis /shutdown for at den automatisk skal stenges etter filmen er ferdig. Endret 22. november 2007 av joffe11 Lenke til kommentar
Admin'c Skrevet 22. november 2007 Rapporter Del Skrevet 22. november 2007 i configen til mediaportal (eget ikon for å starte den) så kan du sette commandline options eller no til external player Lenke til kommentar
pompen75 Skrevet 24. november 2007 Rapporter Del Skrevet 24. november 2007 (endret) Problemet er nå heldigvis løst. se løsning i post 1125 i denne tråden. Skyldtes feil med mitt onboard lydkort. Trenger litt hjelp jeg. Jeg har fiklet med mediaportal i en hel uke. Det har alt jeg trenger av funksjoner osv. Men, det er så ustabilt. Jeg har kjøpt meg et Technotrend S2-3200 og det fungerer knall med det medfølgende programmet. Jeg har de siste drivere til skjermkort lydkort osv. Bruker siste versjon av mediaportal. Og oppsettet mitt er stabilt ellers. Ikke noen problemer med spilling, se på film osv ellers. Det som skjer er at jeg får utført en opperasjon i mediaportal helt fint. For eksempel å se på tv i mediaportal, cam osv fungerer helt fint. Men, hvis jeg heller skal se på film i stedet så henger det seg. Eller hvis jeg ser på film først og så vil se på tv da henger det seg. Eller om jeg avslutter mediaportal får så å starte på nytt så henger det seg i oppstarten. Hvis jeg for eksempel bare ser en video og avslutter mediaportal. Så får jeg ikke avsluttet Windows på vanlig måte. Den henger seg. Maskinen kan også henge seg i mediaportal når jeg blar i menyen. Musen fortsetter å virke, men ingen programmer virker og etter å ha trykket nok ganger på musen så slutter også den å virke. Jeg har en fresh installasjon av xp. Og har bare lagt inn ffdshow som kodek. Mediaportal var også ustabilt før jeg installerte tv kortet. Så det kan ikke være grunnen. Er det noen som har noen tips her til meg. Specs på maskinen er som følger. AMD Athlon 64 X2 3800+ 2.0 GHz BOXED Corsair Value S. PC3200 DDR 2 gig ram Samsung SpinPoint P120S 250GB SATA2 Gainward GeForce 7900GT 256MB DDR3 PCI-E MSI K8N SLI-FI, nF4 SLI, S-939, PCI-E Sony DVD-brenner DWQ120AB2 IDE OEM Black Sony Floppy Drive, 3,5" 1,44MB Silver Cooler Master Centurion 5 Black/Silver Hiper Powersupply ATX 580W, HPU-4K580 Endret 25. november 2007 av pompen75 Lenke til kommentar
Spragleknas Skrevet 24. november 2007 Forfatter Rapporter Del Skrevet 24. november 2007 Det du bør gjøre er å slrive dette på MP forumet (på Engelsk ) Husk å legge ved specs OG logger funnet under \mediaportal\logs\ (elns) MP er ikke ustabilt... vel.. ike mer enn en hvilken som helst XP inst. Lenke til kommentar
pompen75 Skrevet 24. november 2007 Rapporter Del Skrevet 24. november 2007 Prøvde meg her inne først. Da min skriftlige engelsk er meget dårlig. Jeg har i hele dag kjørt prime95 uten å få feil enda. Så jeg tror jeg kan utelukke hardware feil. Så detta er merklige greier. Jeg er fortsatt mottagelige for tips. Har også skjekket divx med test tool. Og ingen feil der heller. Lenke til kommentar
Zappza Skrevet 24. november 2007 Rapporter Del Skrevet 24. november 2007 Prøvde meg her inne først. Da min skriftlige engelsk er meget dårlig. Jeg har i hele dag kjørt prime95 uten å få feil enda. Så jeg tror jeg kan utelukke hardware feil. Så detta er merklige greier. Jeg er fortsatt mottagelige for tips. Har også skjekket divx med test tool. Og ingen feil der heller. Under har du teksten din på engelsk. Litt mer specs forresten, trenger å vite nøyaktig hvilken versjon du har av MP, i tillegg til alle addons du har installert. Ta også å finn frem loggen til MP. Er bare å kjøre "MediaPortal Debug Tool" så får du lagret alt av debugs og logger i en *.zip fil. Hi! I need some help here. I have been configuring MP for about a week now, I have all functions I could ever dream of. If only it wasn't so unstable.... I have recently bought a Technotrend S2-3200 and it works perfect with the bundled application. I have the latest drivers for my graphics card, soundcard and so on, I also use the lastest version of MP. My setup is stable in everything else, I have no problems with gaming, watching movies and such. What happens is the following. I can do one thing in MP befor things start to go bad, for example: I can watch TV just fine, but if I try to watch a movie afterwords, MP freezes. Or if I watch a movie first, and then try to watch TV. If I exit MP after I have done one thing, it freezes while loading. After that Windows freezes too. I can move my pointer, but nothing is reacting, and after a while the pointer freezes too. Some times even MP freezes while I'm browsing the menus there. I have a fresh install of Windows XP, and I have only installed ffdshow as my codecs. MP was unstable before I installed my TV card too, so that can't be the reason. Anybody here that can help me? My specs are the following: AMD Athlon 64 X2 3800+ 2.0 GHz BOXED Corsair Value S. PC3200 DDR 2 gig ram Samsung SpinPoint P120S 250GB SATA2 Gainward GeForce 7900GT 256MB DDR3 PCI-E MSI K8N SLI-FI, nF4 SLI, S-939, PCI-E Sony DVD-brenner DWQ120AB2 IDE OEM Black Sony Floppy Drive, 3,5" 1,44MB Silver Cooler Master Centurion 5 Black/Silver Hiper Powersupply ATX 580W, HPU-4K580 Lenke til kommentar
ronilse Skrevet 24. november 2007 Rapporter Del Skrevet 24. november 2007 Trenger litt hjelp jeg. Jeg har fiklet med mediaportal i en hel uke. Det har alt jeg trenger av funksjoner osv. Men, det er så ustabilt. AMD Athlon 64 X2 3800+ 2.0 GHz BOXED Corsair Value S. PC3200 DDR 2 gig ram Samsung SpinPoint P120S 250GB SATA2 Gainward GeForce 7900GT 256MB DDR3 PCI-E MSI K8N SLI-FI, nF4 SLI, S-939, PCI-E Sony DVD-brenner DWQ120AB2 IDE OEM Black Sony Floppy Drive, 3,5" 1,44MB Silver Cooler Master Centurion 5 Black/Silver Hiper Powersupply ATX 580W, HPU-4K580 Hei, Hvis du laster opp mediaportal.log til MediaPortal Pastebin etter at du har testet å gå fra visning av film til visning av TV og feil oppstått, så skal jeg ta en titt på den.. Roy Lenke til kommentar
Athikez Skrevet 24. november 2007 Rapporter Del Skrevet 24. november 2007 Lurer på om mediaportal fungerer under Vista? Lenke til kommentar
ronilse Skrevet 24. november 2007 Rapporter Del Skrevet 24. november 2007 Lurer på om mediaportal fungerer under Vista? Hei, Ja MediaPortal fungerer under vista, du må slå av UAC i Kontrollpanelet -> Brukerkontoer -> Aktivere/deaktivere Brukerkontroll(deaktiver, restart vista, installer MP) Roy Lenke til kommentar
Athikez Skrevet 24. november 2007 Rapporter Del Skrevet 24. november 2007 Lurer på om mediaportal fungerer under Vista? Hei, Ja MediaPortal fungerer under vista, du må slå av UAC i Kontrollpanelet -> Brukerkontoer -> Aktivere/deaktivere Brukerkontroll(deaktiver, restart vista, installer MP) Roy Okey.. Har tenkt å innstaler vista etterhvert pga DX10 Skal bare vente på skjermkort 8800gt Lenke til kommentar
Spragleknas Skrevet 24. november 2007 Forfatter Rapporter Del Skrevet 24. november 2007 Ref. innlegg #1112 Flott ronilse! Til dere som ikke vet det: Roy (ronilse) er testperson for MP. Dere kan dermed vektlege hans innlegg i særs grad. Lenke til kommentar
pompen75 Skrevet 25. november 2007 Rapporter Del Skrevet 25. november 2007 Takk for Tilbudet Ronlise. Problemet er bare at jeg skjønte ikke en dritt av hvordan jeg lastet opp til pastebin. Men, jeg har fått testet litt mer i natten som gikk. Det jeg har funnet ut er følgende. Alt er som sagt ok når jeg ser på feks en film fil. Cpu usage er da veldig liten. Feilen oppstår når jeg trykker på exit eller stopper filen med stopp knappen. Da farer pluteslig cpu usage opp til 100% på kjærne 0. Og det er system under prosesser som bruker de 50%. Hvis jeg da setter affinitet til 1 på meidaportal får jeg avsluttet mediaportal. Men, så med en gang fryser system. Ingen bevegelse i task mangar. Men, musen får jeg flyttet på. Et trykk på knappen og den fryser også. Eneste løsning er da å slå av og på pc. Jeg legger ut filene jeg har klart å produsere her jeg. I tilfelle noen kan hjelpe meg. MediaPortalLogs.zip Lenke til kommentar
pompen75 Skrevet 25. november 2007 Rapporter Del Skrevet 25. november 2007 Her er alle filene i log mappen min MediaPortal.zip Lenke til kommentar
ronilse Skrevet 25. november 2007 Rapporter Del Skrevet 25. november 2007 (endret) Hei, Pastebin: Åpne mediaportal.log i notisblokken(notepad), merk alt -> kopier og lim inn i pastebin + kode og post. Angående loggen din: - Hvilken codecs har du lagt inn for avspilling av .avi's(jeg bruker ffdshow)? - Har du installert alle oppdateringene fra Windows Update(helst også de som er listet her)? - Deaktivert i MediaPortal Configuration -> Television -> Program Guide -> Grab EPG? - Hvis ingen av de over hjelper deaktiver WebEPG(virker som det er denne som av en eller annen grunn henger i følge loggen) - Kjører MediaPortal på den primære skjermen? Edit: glemte noe Roy Endret 25. november 2007 av ronilse Lenke til kommentar
pompen75 Skrevet 25. november 2007 Rapporter Del Skrevet 25. november 2007 Ja jeg har oppdatert alt. Deaktivert web grabber plugginen nå. Samme resultat. Men, nå ser loggen anderledes ut. Den har sett slik ut som denne før også. Har nå bare en skjerm koblet til. Hadde all support vært like rask som du. Takk for all hjelp hittentil Configuration.zip Lenke til kommentar
