teaspoon Skrevet 22. august 2006 Del Skrevet 22. august 2006 Hei, kan du poste HW specs her og din MediaPortal.log, eventuelt error.log til MediaPortal Pastebin og link tilbake her? Roy 6715226[/snapback] HK: PC Partner 648Max CPU 2Ghz Intel P4 512MB Ram Ati Rage 128 Pro AIW skjermkort. Skjermkortet er gammelt og slitt, men tror ikke det er det som er problemet, da det funket fint intill jeg "addet" filmene. loggen: 20.08.2006 15:44:18 Main: MediaPortal is starting up20.08.2006 15:44:18 Main: Assembly creation time: 03.07.2006 13:23:06 (UTC) 20.08.2006 15:44:18 Main: Set current directory to: C:\Programfiler\Team MediaPortal\MediaPortal 20.08.2006 15:44:18 Main: Verifying DirectX 9 20.08.2006 15:44:18 Main: Verifying Windows Media Player 20.08.2006 15:44:18 Main: Windows Media Player version 11,0,5358,4827 installed 20.08.2006 15:44:18 Application Version: 0.2.0.0 20.08.2006 15:44:18 Main: Checking for running MediaPortal instance 20.08.2006 15:44:18 Main: Deleting old log\capture.log 20.08.2006 15:44:18 Main: Checking skin version 20.08.2006 15:44:18 Load key mapping from keymap.xml 20.08.2006 15:44:18 Main: Init playlist player 20.08.2006 15:44:18 Main: Creating the WINLIRC device 20.08.2006 15:44:18 Initialising WinLirc... 20.08.2006 15:44:18 WinLirc window not found, starting WinLirc 20.08.2006 15:44:18 Winlirc process not found 20.08.2006 15:44:18 Main: Creating the WINLIRC device done 20.08.2006 15:44:18 Main: Init players 20.08.2006 15:44:18 Main: Initializing DirectX 20.08.2006 15:44:19 D3D: Starting fullscreen 20.08.2006 15:44:19 D3D: Client size: 1024x768 - Screen: 1024x768 20.08.2006 15:44:19 MAP: using default mappings for DirectInput 20.08.2006 15:44:21 Windowmanager:closing current window 20.08.2006 15:44:21 texturemanager:dispose() 20.08.2006 15:44:21 TexturePacker:Dispose() 20.08.2006 15:44:21 Load key mapping from keymap.xml 20.08.2006 15:44:22 load localized strings from:language\Norwegian\strings.xml Som sagt så fryser maskina under loadinga, og jeg må restarte manuelt. Lenke til kommentar
Spragleknas Skrevet 22. august 2006 Forfatter Del Skrevet 22. august 2006 Jeg har problemer med å spille av divX-filmer, det skjer ingenting når jeg prøver å starte dem, har kun klart å spillt av én film, å det var vel vanlig avi. Er det en spesiell plugin jeg trenger? Har installert VLC fra før av. 6719334[/snapback] Hei! Du må ha DivX dekodere. Anbeflaer denne pakken: http://www.filesharingplace.com/downloads/..._codec_pack.php Lenke til kommentar
ronilse Skrevet 22. august 2006 Del Skrevet 22. august 2006 20.08.2006 15:44:22 load localized strings from:language\Norwegian\strings.xml ^ Er det der maskinen stopper? Har du prøvd å avinstallere MediaPortal (ta backup av mappa først), slett MP folderen, installere på nytt og da fått samme feilen? Roy Lenke til kommentar
knutinh Skrevet 22. august 2006 Del Skrevet 22. august 2006 Er han fyren som har vært involvert i å oversette språk til norsk her? Jeg ser gjerne at "sanger" i Min musikk/visninger blir erstattet med "folder visning" eller noe lignende. Det er veldig lite intuitivt at den eneste måten å vise katalogstrukturen som på disk er kalt "sanger". mvh Knut Lenke til kommentar
ronilse Skrevet 22. august 2006 Del Skrevet 22. august 2006 (endret) Er han fyren som har vært involvert i å oversette språk til norsk her? Jeg ser gjerne at "sanger" i Min musikk/visninger blir erstattet med "folder visning" eller noe lignende. Det er veldig lite intuitivt at den eneste måten å vise katalogstrukturen som på disk er kalt "sanger". mvh Knut 6723464[/snapback] Denne er allerede erstattet med "Vis alle". Glemte det, den skal være tilgjengelig fra oppdatering 0.2.0.5.... Roy Endret 22. august 2006 av ronilse Lenke til kommentar
knutinh Skrevet 22. august 2006 Del Skrevet 22. august 2006 Ellers hadde det vært kult om folk bosatt i bergen, trondheim og eidsvoll-området med fungerende DVB-T (digitalt bakkenett) hadde sjekket om frekvensene som ligger inne stemmer, evt oppgitt sine frekvenser slik at disse kunne legges inn i koden. Jo mer sømløst installasjonen funker jo morsommere er det å laste ned og installere open source. Jeg har bidratt med den som heter Oslo (trials) eller no sånt. Her går det to muxer på 722MHz og 770MHz. -k Lenke til kommentar
-=Petter=- Skrevet 22. august 2006 Del Skrevet 22. august 2006 Driver og skal ta opp, og tenkte jeg skulle si i fra om en skrive feil. i steden for halvtimer så står det 50 min, da man stiller inn... Kommer opp som halvtimer da man har gjort innstillingene... Men må si jeg savner og kunne sette opp manuelt hvor lenge man skal ta opp, i steden for forhåndslagrede tider på hver halvtime og oppover... Mvh Petter Lenke til kommentar
ronilse Skrevet 22. august 2006 Del Skrevet 22. august 2006 Ellers hadde det vært kult om folk bosatt i bergen, trondheim og eidsvoll-området med fungerende DVB-T (digitalt bakkenett) hadde sjekket om frekvensene som ligger inne stemmer, evt oppgitt sine frekvenser slik at disse kunne legges inn i koden. Jo mer sømløst installasjonen funker jo morsommere er det å laste ned og installere open source. Jeg har bidratt med den som heter Oslo (trials) eller no sånt. Her går det to muxer på 722MHz og 770MHz. -k 6723579[/snapback] Hei, De stemmer i allefall for oss som kan ta i mot i Østfold, og bildene fra NRK - TVN er helt nydelige, gleder meg til resten kommer opp. Roy Lenke til kommentar
ronilse Skrevet 22. august 2006 Del Skrevet 22. august 2006 Driver og skal ta opp, og tenkte jeg skulle si i fra om en skrive feil. i steden for halvtimer så står det 50 min, da man stiller inn... Kommer opp som halvtimer da man har gjort innstillingene... Men må si jeg savner og kunne sette opp manuelt hvor lenge man skal ta opp, i steden for forhåndslagrede tider på hver halvtime og oppover... Mvh Petter 6723750[/snapback] Hei, Det jobbes (diskuteres i teamet) nå med bedre alternativer for opptak, det vil nok ta litt tid før dette blir bestemt eller programert hvordan dette skal fungere, men det skal endres... Roy Lenke til kommentar
knutinh Skrevet 22. august 2006 Del Skrevet 22. august 2006 Hei, De stemmer i allefall for oss som kan ta i mot i Østfold, og bildene fra NRK - TVN er helt nydelige, gleder meg til resten kommer opp. Roy 6723751[/snapback] Har du prøvd deg på svenske sendinger? -k Lenke til kommentar
ronilse Skrevet 22. august 2006 Del Skrevet 22. august 2006 Har du prøvd deg på svenske sendinger? -k 6723811[/snapback] Ja, men må ha antenna ganske høyt (bare for test) for å få de inn - men det fungerer, har tenkt på en bedre antenne en den jeg kjøpte på Biltema og forsøke det. Roy Lenke til kommentar
Spragleknas Skrevet 22. august 2006 Forfatter Del Skrevet 22. august 2006 Ronlise: Bladd gjennom alle dine innlegg (alle er jo i denne tråden....) men finner ikke linken til den "norske" MP-tråden i MP-forumet. Har du linken? Lenke til kommentar
ronilse Skrevet 22. august 2006 Del Skrevet 22. august 2006 Ronlise: Bladd gjennom alle dine innlegg (alle er jo i denne tråden....) men finner ikke linken til den "norske" MP-tråden i MP-forumet. Har du linken? 6724501[/snapback] Hei, Tror ikke vi har det, bare å starte en Alle endringer blir som regel tatt, når jeg leser loggene bortover. Roy Lenke til kommentar
Spragleknas Skrevet 22. august 2006 Forfatter Del Skrevet 22. august 2006 Hmm... husker kanskje feil..... Roy, har du satt opp MyBlaster og fått det til å fungere? Lenke til kommentar
Spragleknas Skrevet 22. august 2006 Forfatter Del Skrevet 22. august 2006 Det er nå laget en tråd på Mediaportalforumet for oss skandinaver, den finner dere HER. Der finner man bl.a ikoner for TV- og radiokanaler , linker til bilder man kan benytte under MyWeather mm. 6470222[/snapback] Var denne jeg tenkte på Lenke til kommentar
ronilse Skrevet 22. august 2006 Del Skrevet 22. august 2006 Hmm... husker kanskje feil..... Roy, har du satt opp MyBlaster og fått det til å fungere? 6726405[/snapback] Hei, Nei, MyBlaster har jeg ikke testet enda, men den skal fungere bra etter det andre sier, pass på å ikke ha den i direkte sol lys når du trener den, og det den skal styre må være tett intill. PS. fint at du fant linken, hadde helt glemt den Roy Lenke til kommentar
-=Petter=- Skrevet 22. august 2006 Del Skrevet 22. august 2006 På fjernkontrollen min så har jeg noe som heter apilcation exit, som gjør at maskinen går ut av MP, stenger det helt... Er det mulig og gjøre slik at den bare minimerer det? Finner liksom ikke ut stort ved og titte i imon innstillingene... Og VFD får jeg ikke til og fungere slik at det viser relevant info for MP, slik som f.eks. Hva slags film, TV kanal eller musikk som spilles... MVH Petter Lenke til kommentar
ronilse Skrevet 23. august 2006 Del Skrevet 23. august 2006 På fjernkontrollen min så har jeg noe som heter apilcation exit, som gjør at maskinen går ut av MP, stenger det helt... Er det mulig og gjøre slik at den bare minimerer det?Finner liksom ikke ut stort ved og titte i imon innstillingene... Og VFD får jeg ikke til og fungere slik at det viser relevant info for MP, slik som f.eks. Hva slags film, TV kanal eller musikk som spilles... MVH Petter 6726642[/snapback] Hei, Har ikke testet ut dette, men det er en (også fler) tråd(er) på MP Forumet som her, se om du finner ut noe om din type der. Roy Lenke til kommentar
WebKnight Skrevet 25. august 2006 Del Skrevet 25. august 2006 (endret) Streamingproblemer. Har problemer med både MyMusicVideos og MyTrailers i MP. Problemet er at bildet hakker, det kan være at det hakker litt eller at bildet fryser i lang tid, mens lyden stort sett går greit. Har 20mb fra NGT og trådløs på MP PC'en (54mb) Når jeg overfører filer fra PC til PC over trådløs hjemme har jeg en hastighet på mellom 15 og 18 mb/s (målt med det geniale programmet NetMeter) så jeg tror ikke det er der feilen ligger. Streaming fra f.eks TV2 webTV går helt fint. Kan legge til at ved målinger på diverse "speedometer" og TPTest ligger jeg på mellom 10 - 13 mb/s på PC'en med MP. Noen som har formening om hva dette kan være? Endret 25. august 2006 av WebKnight Lenke til kommentar
Spragleknas Skrevet 25. august 2006 Forfatter Del Skrevet 25. august 2006 Er nok "ut" begrensninger fra Yahoo.... ikke din DL-hastighet, Lenke til kommentar
