pgdx Skrevet 16. desember 2005 Del Skrevet 16. desember 2005 Litt feilledende tittel, men hadde ikke plass til å skrive så mye mer. Det er så at når jeg er logget inn i KDE og ikke bruker maskinen på noen timer, så har maskinen en tendens til ikke å skru på igjen skjermen. Det er ikke skrudd på noe strømsparing. I følge /var/log/messages: Dec 16 16:10:58 localhost kernel: [4294732.407000] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0. Dec 16 16:10:58 localhost kernel: [4294732.407000] agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode Dec 16 16:10:58 localhost kernel: [4294732.407000] agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode Dec 16 16:10:58 localhost kernel: [4294732.412000] [drm] Loading R200 Microcode Dec 16 16:14:45 localhost ivman: Ivman started in system mode Dec 16 16:18:08 localhost gconfd (drange-7930): starting (version 2.12.0), pid 7930 user 'drange' Dec 16 16:18:08 localhost gconfd (drange-7932): starting (version 2.12.0), pid 7932 user 'drange' Dec 16 16:18:08 localhost gconfd (drange-7932): Failed to get lock for daemon, exiting: Failed to lock '/tmp/gconfd-drange/lock/ior': probably another process has the lock, or your operating system has NFS file locking misconfigured (Resource temporarily unavailable) Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0 Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readonly:/usr/share/gconf/local.mandatory" to a read-only configuration source at position 1 Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readwrite:/home/drange/.gconf" to a writable configuration source at position 2 Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 3 Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readonly:/usr/share/gconf/local.defaults" to a read-only configuration source at position 4 Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readonly:/usr/share/gconf/cdd.defaults" to a read-only configuration source at position 5 Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readonly:/usr/share/gconf/debian.defaults" to a read-only configuration source at position 6 Dec 16 16:18:09 localhost gconfd (drange-7930): Resolved address "xml:readonly:/var/lib/gconf/defaults" to a read-only configuration source at position 7 Dec 16 16:19:07 localhost exiting on signal 15 Dec 16 16:19:09 localhost syslogd 1.4.1#17ubuntu3: restart. Dec 16 16:39:09 localhost -- MARK -- Dec 16 16:59:09 localhost -- MARK -- Dec 16 17:19:10 localhost -- MARK -- Dec 16 17:31:09 localhost gconfd (drange-7930): GConf server is not in use, shutting down. Dec 16 17:31:09 localhost gconfd (drange-7930): Exiting Dec 16 17:59:10 localhost -- MARK -- Dec 16 18:19:10 localhost -- MARK -- Dec 16 18:39:10 localhost -- MARK -- Dec 16 18:59:10 localhost -- MARK -- Dec 16 19:19:10 localhost -- MARK -- Dec 16 19:39:10 localhost -- MARK -- Dec 16 19:59:10 localhost -- MARK -- Dec 16 20:19:10 localhost -- MARK -- Dec 16 20:39:10 localhost -- MARK -- Dec 16 20:59:10 localhost -- MARK -- Dec 16 21:19:11 localhost -- MARK -- Dec 16 21:39:11 localhost -- MARK -- Dec 16 21:40:38 localhost syslogd 1.4.1#17ubuntu3: restart. Dec 16 21:40:38 localhost kernel: Inspecting /boot/System.map-2.6.12-10-386 Dec 16 21:40:39 localhost kernel: Loaded 29010 symbols from /boot/System.map-2.6.12-10-386. Dec 16 21:40:39 localhost kernel: Symbols match kernel version 2.6.12. Jeg sovnet vel tydeligvis i femtiden i dag, og klokken 21.40 måtte jeg ta en hard reboot av maskinen ved hjelp av svenskeknappen. Jeg rebootet ikke klokken 16.19, så hvorfor syslogd gjorde det, vet jeg ikke. Noen som har noen råd? Lenke til kommentar
pgdx Skrevet 17. desember 2005 Forfatter Del Skrevet 17. desember 2005 Vil legge til at skjermen ikke slår seg på om jeg trykker ctrl-alt-backspace, ctrl-alt-1→6 osv. Lenke til kommentar
pgdx Skrevet 19. desember 2005 Forfatter Del Skrevet 19. desember 2005 Barnaby The Bear's my name, never call me Jack or James, I will sing my way to fame, Barnaby the Bear's my name. Birds taught me to sind, when they took me to their king, first I had to fly, in the sky so high, so high so high si high, so - if yo want to sing this way, think of what you'd like to say, add a tune and you will see, just how easy it can be. Treacle pudding, fish and chips, fizzy drinks and liquorice, flowers, rivers, sand and sea, snowflake and the stars are free. La la la la la la la la la la la la la la la, so - Barnaby the Bear's my name, never call me Jack or James, I will sing my way to fame, Barnaby the Bear's my name. Lenke til kommentar
