en mann Skrevet 3. september 2002 Del Skrevet 3. september 2002 Jeg vet ikke hva det er, og fant 123+1923801283019283 treff på forum og google. Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/
Lch Skrevet 3. september 2002 Del Skrevet 3. september 2002 Kanskje noen burde skrive en artikkel om googling? :wink: Et lite hint er at OpenGL skrives ofte i ett ord (det skal vel skrives slik). http://www.opengl.org/users/about/ "What is OpenGL * OpenGL is a cross-platform standard for 3D rendering and 3D hardware acceleration. The software runtime library ships with all Windows, MacOS, Linux and Unix systems. * OpenGL delivers fast and complete 3D hardware acceleration Today's applications and games manipulate massive amounts of data in real-time by using OpenGL hardware accelerated geometry, real-time lighting, clipping, transformations and rendering * OpenGL makes real-time 3D effects possible OpenGL hardware acceleration adds detail & special effects to images without compromising performance. Examples include real-time fog, anti-aliasing, volume shadows, bump mapping, motion blur, transparency, reflections, 3D textures, volume rendering and more * OpenGL is designed to support future innovations in software and hardware, The extension mechanism in OpenGL can expose radically new hardware/software features that simply never existed when OpenGL was originally conceived. So you can be confident that you will continue to get the best possible performance from your applications and games as hardware technology advances * OpenGL is on every platform Ever wished that great Unix application would move to Windows or a great Windows game to Linux. Since OpenGL is fully cross-platform, it is realtively easy to port games or applications from one platform to be moved to another. This greatly expands the wealth of applications and games that support OpenGL. * OpenGL is stable. High End 3D workstation & supercomputuer users have been enjoying OpenGL since 1992. Today, OpenGL is also the most popular and powerful 3D solution for Windows, Mac and Linux-based computers, for professional and consumer use. Why you need OpenGL Games: OpenGL is the essential 3D library that lets you harness the power of hardware acceleration to thrust games into the realm of professional-quality rendering, texture-mapping and special effects. Almost all of the leading games (e.g. Quake III, Half-Life, MDK2, Baldurs Gate, Decent 3, Madden NFL 2001 etc.) require OpenGL for hardware acceleration. Professional 3D graphics & effects: OpenGL is the 3D power behind all of the incredible 3D graphics & effects you see on TV and at the movies. (think Star Wars). Hardware that uses OpenGL makes possible the compelling 2D and 3D graphics in broadcasting, CAD/CAM/CAE, entertainment, medical imaging and virtual reality. All leading 3D modeling, rendering & animation and visualization software use OpenGL. Leading PC, workstation and supercomputer vendors like SGI, Cray Research, Compaq, Fujitsu, Hewlett-Packard, Hitachi, IBM, Intel, Microsoft, Mitsubishi, NEC, Samsung, Siemens-Nixdorf, Sony and Sun Microsystems have adopted OpenGL as a strategic open standard for high performance 2D and 3D graphics." http://mediagods.com/glossary/What_is_Open_GL.html "Originally developed by Sun Microsystems, OpenGL is a widely adopted standard for developing portable, interactive 2D and 3D graphics applications. Introduced in 1992, OpenGL has become the industry's most widely used and supported 2D and 3D graphics application programming interface (API) for a variety of computer platforms." Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365788
LeD Skrevet 3. september 2002 Del Skrevet 3. september 2002 Litt kortere fortalt er OpenGL et 3D-bibliotek. Et bibliotek i programmeringssammenheng er en samling av nyttige og mye brukte funksjoner. Når man skal skrive et program med 3D-grafikk, kan man altså bruke ferdiglagede funksjoner fra OpenGL for å tegne og manipulere 3D-objekter på skjermen. 3D-grafikk brukes jo mye i spill for tiden, men kan også brukes til mer "nyttige" ting. Visualisering av modeller av bygninger f.eks. En konkurrent til OpenGL er Microsofts Direct3D, som er en del av DirectX. En fordel med OpenGL er at det støtter også andre operativsystemer enn Windows. LeD Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365864
Jannis-15 Skrevet 3. september 2002 Del Skrevet 3. september 2002 vil dette si at mitt kort (se sig) ikke støtter D3D i Linux? Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365940
Goldfish Skrevet 3. september 2002 Del Skrevet 3. september 2002 Gjør nok ikke det, men spiller ikke noen særlig rolle. Enkelte spill støtter kun D3D, men da lages det antageligvis ingen Linux port. Dessuten er OpenGL bedre! Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365960
pegg Skrevet 3. september 2002 Del Skrevet 3. september 2002 kan vel bruke direct 3d i linux via wineX Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365967
Jannis-15 Skrevet 3. september 2002 Del Skrevet 3. september 2002 anbefaler dere linux eller windows når jeg skal spille mye? har hørt at linux yter bedre, men dette hjelper jo ikke mye om det ikke er noen spill som støtter linux.. eller? beklager at jeg går litt bort ifra temaet her.. :smile: Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365970
alfern Skrevet 3. september 2002 Del Skrevet 3. september 2002 Dersom du satser paa aa spille mye, burde du nok velge Windows. Det er ikke mange spill som er laget for Linux. Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365990
LeD Skrevet 3. september 2002 Del Skrevet 3. september 2002 Quote: Den 2002-09-03 21:29, pegg skrev:kan vel bruke direct 3d i linux via wineX Det kan man nok. Men dersom man skal lage programmer med 3D i Linux, kan man vel ikke benytte Direct3D-biblioteket. Å lage programmer for Windows og deretter kjøre dem i andre operativsystemer ved hjelp av emulatorer eller halvveis implementasjoner av Microsofts APIer er ikke en veldig god løsning. Med f.eks. OpenGL kan programmer og spill mye lettere portes til ulike operativsystemer. LeD Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-365996
LeD Skrevet 3. september 2002 Del Skrevet 3. september 2002 Quote: Den 2002-09-03 21:45, alfern skrev:Dersom du satser paa aa spille mye, burde du nok velge Windows. Det er ikke mange spill som er laget for Linux. Man kan da få både i pose og sekk. :smile: Bruk Windows til spill og moro, og Linux til seriøse ting. LeD Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-366001
Ptomania Skrevet 3. september 2002 Del Skrevet 3. september 2002 Ehm.. En liten oppklaring.. openGL funker i linux..!! Nividia har egne 3d-drivere NVDriver som må kompileres for at det skal funke.. Jeg har gjort det og det funker glimm.. Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-366078
LeD Skrevet 3. september 2002 Del Skrevet 3. september 2002 Quote: Den 2002-09-03 22:20, Ptomania skrev:Ehm.. En liten oppklaring.. openGL funker i linux..!! Har noen påstått noe annet? LeD Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-366097
Ptomania Skrevet 3. september 2002 Del Skrevet 3. september 2002 he.. leste feil :smile: *skamme seg* Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-366101
en mann Skrevet 7. september 2002 Forfatter Del Skrevet 7. september 2002 Takker takker. NÅ vet jeg hva OpenGl betyr... Dere er gode lærere. Lenke til kommentar https://www.diskusjon.no/topic/50873-hva-er-open-gl/#findComment-371229
