Noname Skrevet 9. desember 2005 Del Skrevet 9. desember 2005 hei jeg har satt opp instillingene som jeg fant på Dlink siden om gaming host.... men routeren blokkere og dropper pakkene, etter noe min så dropper alle spillerene som har joinet game mitt.... [iNFO] Fri Dec 09 03:16:23 2005 Blocked incoming UDP packet from 202.99.177.196:35008 to 10.0.0.2:1026 [iNFO] Fri Dec 09 03:16:23 2005 Previous message repeated 2 times [iNFO] Fri Dec 09 03:15:57 2005 Blocked incoming TCP packet from 80.212.27.173:36341 to 10.0.0.2:6882 [iNFO] Fri Dec 09 03:15:38 2005 Blocked incoming UDP packet from 220.168.158.11:52769 to 10.0.0.2:1030 [iNFO] Fri Dec 09 03:14:56 2005 Dropped TCP packet with invalid flags 0x4 from 217.210.79.20:2974 to 10.0.0.2:6882 [iNFO] Fri Dec 09 03:14:45 2005 Blocked incoming UDP packet from 221.10.158.140:42031 to 10.0.0.2:1027 [iNFO] Fri Dec 09 03:14:45 2005 Blocked incoming UDP packet from 221.10.158.140:42031 to 10.0.0.2:1026 [iNFO] Fri Dec 09 03:14:45 2005 Previous message repeated 2 times [iNFO] Fri Dec 09 03:14:21 2005 Blocked incoming TCP packet from 217.210.79.20:4178 to 10.0.0.2:6882 [iNFO] Fri Dec 09 03:14:21 2005 Previous message repeated 2 times [iNFO] Fri Dec 09 03:13:06 2005 Blocked incoming TCP packet from 86.132.147.213:4609 to 10.0.0.2:6882 [iNFO] Fri Dec 09 03:13:06 2005 Previous message repeated 1 time [iNFO] Fri Dec 09 03:12:20 2005 Blocked incoming TCP packet from 88.0.170.79:4358 to 10.0.0.2:135 [iNFO] Fri Dec 09 03:12:20 2005 Previous message repeated 1 time [iNFO] Fri Dec 09 03:09:46 2005 Blocked incoming TCP packet from 81.226.17.95:63409 to 10.0.0.2:6882 [iNFO] Fri Dec 09 03:09:46 2005 Previous message repeated 2 times [iNFO] Fri Dec 09 03:07:41 2005 Blocked incoming TCP packet from 193.215.138.124:3119 to 10.0.0.2:6882 ..... jeg bruker 2 router. En cisco router fra Nextgentel som jeg har åpnet alle porter til ip 10.0.0.2(Dlink) og fra der til maskinen min... jeg har prøvd å søke på nette men fant ikke noe ER det noen som kan hjelpe meg ? Lenke til kommentar
Noname Skrevet 9. desember 2005 Forfatter Del Skrevet 9. desember 2005 jeg glemte å si på cisco router har jeg åpnet alle porter som dette 10.0.0.2:1-5xxxx(max) husker ikke helt.... har det noe å si ? Lenke til kommentar
Elgvenn2 Skrevet 9. desember 2005 Del Skrevet 9. desember 2005 Du kan prøve å droppe brannmuren.... Lenke til kommentar
Noname Skrevet 9. desember 2005 Forfatter Del Skrevet 9. desember 2005 takk for at du prøvde.... men den er av.. Lenke til kommentar
Staal3 Skrevet 9. desember 2005 Del Skrevet 9. desember 2005 Hei Fant du det spillet du har satt opp i de som ligger ferdig oppsatt? For da er du sikker på og få åpnet de riktige portene. Jeg manglet den porten som de skulle komme inn på. Ved første forsøk. Jeg har samme router og har satt opp den til gaming host for Quake3 1.16 og det fungerer 100%. Send meg en PM om du ikke får det til. Så kan jeg hjelpe deg. Og samtidig få satt gaming portene til å få pri 1. Er et must om du skal få en del folk inne på serveren. mvh Ståle Lenke til kommentar
Noname Skrevet 9. desember 2005 Forfatter Del Skrevet 9. desember 2005 jeg teste port scan på port 6112, den var stengt.. men jeg har åpnet porten i router... nå sitter jeg helt fast.. er det noen sm vet `hvorfor ?? Lenke til kommentar
Staal3 Skrevet 13. desember 2005 Del Skrevet 13. desember 2005 jeg teste port scan på port 6112, den var stengt.. men jeg har åpnet porten i router... nå sitter jeg helt fast.. er det noen sm vet `hvorfor ?? 5273607[/snapback] Har du åpnet brannmuren på den PC som du skal kjøre som server?. Har du fulgt de opplysningene som jeg sendte deg på mail. Så skal det i vertfall ikke være routeren som stopper den porten. Så da er det din egen PC som er problemet. Er i vertfall 99% sikker på det. Har du scannet med serveren i gang og i fra hvilken PC? Ståle Lenke til kommentar
Noname Skrevet 28. desember 2005 Forfatter Del Skrevet 28. desember 2005 hei igjen.. jeg har forsatt samme problemet... har prøvd ¨å sla av brannmur... DMZ på.... men den blockkere forsatt... det funker helt fin med andre router... Lenke til kommentar
