Noen som kan forklare hvordan jeg far ASSOCIATORS OF til og fungere i VB(6)?
btw, her er koden min... :
(Forst finner den alle Lyd kort pa PC'en, dereter prover den og finne alle Driverne til diss)
   Dim strBuffer As String, Sound_Devices As Object, SD As Object
   strBuffer = ""
   'Set the Operating System object
   Set Sound_Devices = WMI.Instance("Win32_SoundDevice")
   strBuffer = "Total: " & Sound_Devices.Count & " Audio devices."
   For Each SD In Sound_Devices
       Dim Driver2 As Object, Drivers As Object, Driver As Object, strQuery As String
       strQuery = "ASSOCIATORS OF {Win32_SoundDevice.DeviceID=""" & SD.DeviceID & """}"
       Debug.Print strQuery
       Set Drivers = WMI.Query(strQuery)
       Debug.Print Drivers.Count
       For Each Driver2 In Drivers
           'Set Driver = Driver2
           Debug.Print Driver2.Description
       Next
       Dim lError As Long, sDescription As String
       If Not SD.lasterrorcode = vbNull Then lError = SD.lasterrorcode
       If Not SD.errordescription = vbNull Then sDescription = SD.errordescription
       If sDescription = "" Then sDescription = "No Error"
       strBuffer = strBuffer & vbNewLine & vbNewLine & _
           SD.Caption & " ( " & SD.Status & " )" & vbNewLine & _
           "( " & SD.PNPDeviceID & " ) " & vbNewLine & _
           SD.Manufacturer & vbNewLine & _
           lError & ": " & sDescription & vbNewLine & _
           "Installed: " & ConvertDate(SD.InstallDate) & vbNewLine
       Debug.Print strBuffer
   Next
   Set SD = Nothing
   Set Sound_Devices = Nothing
jeg far bare feilmelding Invalid Object Path??
