Problem med eit enkelt OpenGL oppsett i Dev cpp
#include <GL/glut.h>
void display()
    glClear(GL_COLOR_BUFFER_BIT);
    glBegin(GL_POLYGON);
    glVertex2f(-0.5, -0,5);
    glVertex2f(-0.5, 0,5);
    glVertex2f(0.5, 0,5);
    glVertex2f(0.5, -0,5);
    glEnd();
    glFlush();
using namespace std;
int main(int argc, char** argv)
    glutInit(&argc, argv);
    glutCreateWindow("simple");
    glutDisplayFunc(display);
    glutMainLoop();
    return 0;
Feilmeldinga til compileren eg får er:
C:\Dev-Cpp\include\GL\gl.h In function `void display()':
1072 C:\Dev-Cpp\include\GL\gl.h too many arguments to function `void glVertex2f(GLfloat, GLfloat)'
Nokre smarte personer her som kan hjelpa meg?
Endret av siDDIs
Kor gjer eg det?
gl.h er jo ein standard klasse som eg bruker
5258029[/snapback]
se på det kompileren sier:
se på koden du har:
koden din tilsier at deklarasjonen i gl.h burde vært:
void glVertex2f(GLfloat, GLfloat, GLfloat)
altså glVertex2f(0.5, -0, 5)
ah, eg ser det nå, typisk tabbe feil :p
Men nå sliter eg med nye feilmeldinger.
Compiler: Default compiler
Executing g++.exe...
g++.exe "C:\Dev-Cpp\simple.cpp" -o "C:\Dev-Cpp\simple.exe"
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x1c):simple.cpp: undefined reference to `__glutInitWithExit'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x37):simple.cpp: undefined reference to `__glutCreateWindowWithExit'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x53):simple.cpp: undefined reference to `__glutCreateMenuWithExit'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x68):simple.cpp: undefined reference to `_imp__glClear'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x76):simple.cpp: undefined reference to `_imp__glBegin'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x8e):simple.cpp: undefined reference to `_imp__glVertex2f'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0xa6):simple.cpp: undefined reference to `_imp__glVertex2f'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0xbe):simple.cpp: undefined reference to `_imp__glVertex2f'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0xd6):simple.cpp: undefined reference to `_imp__glVertex2f'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0xdd):simple.cpp: undefined reference to `_imp__glEnd'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0xe4):simple.cpp: undefined reference to `_imp__glFlush'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x13c):simple.cpp: undefined reference to `glutDisplayFunc'
C:\DOCUME~1\OLAVGJ~1\LOCALS~1\Temp/ccQ1aaaa.o(.text+0x141):simple.cpp: undefined reference to `glutMainLoop'
collect2: ld returned 1 exit status
Execution terminated
for å gjøre det enkelt for deg, så mener jeg dev cpp har noe alá "File -> New Project" .. og videre "OpenGL Application" ..    der den er satt opp til å kalle GCC (MinGW) med de riktige kompiler- og linker-parameterene for OpenGL-programmering
5258065[/snapback]
Tja, eg kom over denna sida http://www.zeuscmd.com/tutorials/opengl/02...Environment.php
og greide å få det til korrekt med å følge eksempelet der.
Men takk for hjelpa. Sjølv synes eg det var utroleg tungt å få OpenGL oppe og klart til å kompileras. Teite bøker som ikkje bruker tid på å nevne sånne ting :nei:
Men men, er godt på veg i boka mi nå :)
