IDE-kabling mellom HK og CD-ROM og HD
FranzJosef
På de kablene som fulgte med hovedkortet mitt var det merket hovedkort på den som er lengst fra de 2 andre, den i midten er merket slave og den på andre enden er merket master.
Tror egentlig ikke dette har så mye så si på nye hovedkort. Har kjørt master på den i midten også uten problemer. Det var nok viktigere for noen år siden.
mvh.
Valentino
Googlet litt og fant noe på Storagereview.com
Connector Assignments and Color Coding: For the first time, the 80-conductor cable defines specific roles for each of the connectors on the cable; the older cable did not. Color coding of the connectors is used to make it easier to determine which connector goes with each device:
Blue: The blue connector attaches to the host (motherboard or controller).
Gray: The gray connector is in the middle of the cable, and goes to any slave (device 1) drive if present on the channel.
Black: The black connector is at the opposite end from the host connector and goes to the master drive (device 0), or a single drive if only one is used.
There are a couple of reasons why this coding was done. The main one is the issue mentioned in the discussion of the 40-conductor cable: it is not a good idea to connect a single drive to the middle connector on a ribbon cable, because the "stub" of left-over, unconnected cable causes signaling problems. With Ultra DMA this "stub" connection is not just "not recommended", it is illegal: a single device must be at the end of the cable. The other reason is that since these cables support cable select inherently, the position of each drive on the cable matters if cable select is being used. With these two needs combined, it just made sense to design the cable so that drive positioning was explicitly clear.
Om dette er en kilde man kan stole på skal jeg ikke si, men om noen finner en eller annen offisiell side for dette hadde det vært bra.
mvh.
Valentino
Kansje man skal tro at det går an med begge deler
Som vil være feil. med 80-leders kabel er det klart definert hvor master/singel skal være og hvor en evt. slave skal være. Mange leverandører av kabler har i tillegg merket kabelen med Master og slave ved henholdsvis ytterste (master) og mellomste kontakt.
