nikrus Skrevet 4. desember 2005 Del Skrevet 4. desember 2005 Jeg så denne et sted og tenkte at det kunne vært kjekt å ta en titt! Og det var det! Tro meg! Her er det en liten innholdsfortegnelse Preparing Your System (1-8) Use 'whole system' performance benchmarks Tweak insurance part 1: backing up and editing the registry Tweak Insurance part 2: Creating a system restore point Saving your hard drive space from the system restore utility Tweak insurance part 3: Restoring BIOS defaults Tweak insurance part 4: Use hardware profiles to experiment with system settings. Editing BIOS settings Editing registry settings without restarting BIOS tweaks and Insight (9-13) Change memory Latency times Set the correct AGP mode Update your bios Disable unneeded ports Disable built-in features on your motherboard Overclocking your processor and memory (14-16) Overclocking the memory/front side bus Changing the CPU multiplier Modify Processor and memory voltage WindowsXP Software and Registry Performance Tweaks (17-46) Stop the 'last access update' stamp Disable the 8.3 naming convention Keep Windows operating data in main memory Obtain the newest drivers for your hardware Disable performance counters Move the page file from system drive Create a 'permanent' page file Optimize your page file size Defrag page file with PageDefrag utility Set priority for important programs Check your hard drives with scandisk Force XP to unload DLL files after closing a program Thaw out your desktop Speed up mouse movement, part 1 Speed up mouse movement, part 2 Create a RAID configuration Disable the themes service Remove the desktop picture Change to the NTFS file system Perform a manual Application and Boot file Defrag Disable the hibernation feature Disable automatic sensing on network cards Use the prefetch switch to load applications faster Verify DMA mode is set for all drives Do a windows repair install Stop hard disks spinning down Reduce recycling bin reserved space Enable write caching on hard disks Defragment your hard disk(s) Turn off the indexing service Graphics Performance Tweaks (47-55) 3d game benchmarks Change your Monitor's refresh rate (CRT monitors only) Fix the refresh rate for 3d games Enable AGP Master 1WS Write/Read Enable AGP Fast Write Set Video Memory Cache Mode Overclocking ATI video cards Overclocking Nvidia Video cards Disable VSYNC Network and Internet Performance Tweaks (56-66) Increase maximum number of simultaneous connection in Internet Explorer b' devices slow down 802.11g networks Proprietary modes for wireless networking Closer is better for wireless Enhance your Internet connection. Increase DNS cache size Disable DHCP with DSL connections Do not cache failed DNS entries Use CTRL+ENTER to speed up Internet address entering Get a faster network connection to Windows 9x/ME computers Remove the QoS Bandwidth Reserve Setting WindowsXP User Interface Shortcuts and Hints (67-78) Create shortcut keys Create a custom shortcuts toolbar Using ALT+TAB to switch between applications Add the address taskbar to desktop Disable error reporting Reduce menu delays Restore the Quick launch bar Increase desktop graphic performance Make 'my computer' open faster Remove the need to enter a password to login to XP (be careful!) Sort out spam Keyboard shortcuts using the Win Key (ÿ) Improving Windows XP boot speed (79-94) Disable floppy drive seek Set primary display adaptor Enable quick POST/memory test Eliminate unwanted programs from boot up Scan your PC for spyware and Adware Disable boot virus detection Change boot sequence. Disable the XP loading screen Eliminate unwanted fonts to increase boot speed Turn off bios disk detection Use the Bootvis utility Use the Intel application accelerator Disable unnecessary services Disable unneeded devices in device manager Disable auto detection for empty IDE slots Reduce wait time after XP boots Increasing XP shutdown speed (95-99) Increasing shutdown speed by reducing wait times part 1 Increasing shutdown speed by reducing wait times part 2 Increasing shutdown speed by reducing wait times part 3 Disable the Nvidia driver helper service Auto kill tasks on shutdown Hvis dette høres interresant ut så har du lenka her: http://anonym.to/?http://www.pcstats.com/a...?articleID=1590 Lenke til kommentar
Complexity Skrevet 4. desember 2005 Del Skrevet 4. desember 2005 Mye intresant å lære her ja... fin tråd Lenke til kommentar
nikrus Skrevet 4. desember 2005 Forfatter Del Skrevet 4. desember 2005 Takker Tenkte at jeg skulle "bidra" med litt kunnskap Lenke til kommentar
