Ubuntu: "broken packages" problem
Idag tok eg frem Ubuntu 5.04 Hoary CD'en min og la inn Ubuntu igjen. Når det var gjort kjørte eg en dist-upgrade for å oppgradere til Breezy og alt såg ut til å gå bra. Men nå har eg store problem med å få installert ting. Nesten uansett hva eg prøver å legge inn får eg opp en eller annen feilmelding som den nedenfor:
$ sudo apt-get install flashplayer-mozilla
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 flashplayer-mozilla: Depends: gsfonts-x11 but it is not installable
E: Broken packages
min sources.list ser sånn ut
## Major bug fix updates produced after the final release of the
## distribution.
deb http://au.archive.ubuntu.com/ubuntu breezy-updates main restricted
deb-src http://au.archive.ubuntu.com/ubuntu breezy-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://archive.ubuntu.com/ubuntu breezy universe multiverse
deb-src http://archive.ubuntu.com/ubuntu breezy universe multiverse
## Security Updates
deb http://security.ubuntu.com/ubuntu breezy-security main restricted
deb-src http://security.ubuntu.com/ubuntu breezy-security main restricted
deb http://security.ubuntu.com/ubuntu breezy-security universe multiverse
deb-src http://security.ubuntu.com/ubuntu breezy-security universe multiverse
## Official backports
deb http://archive.ubuntu.com/ubuntu breezy-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu breezy-backports main restricted universe multiverse
deb http://ubuntu-backports.mirrormax.net/ breezy-extras main restricted universe multiverse
Hva gjør eg galt? :(
Vel, jeg valgte å laste ned breezy cd og legge inn fra den når jeg skulle opp ett hakk. Husker jeg prøvde update med fedora 1 en gang, det gikk ikke så bra, jeg fikk feilmeldinger overalt.
Har desverre ikke et konstruktivt forslag til problemet ditt, men en omvei er: Å laste ned breezy 5.10 cden og legge rett inn fra den, siden du nettop har lagt inn. Men det er jo en veldig kjedelig vei.
Hvis du klarer dette, vil jeg gjerne vite hva du har gjort, for jeg har en server med 5.04 som det ikke hadde gjort noe for meg å få oppdatert til 5.10.
