Stian89 Skrevet 1. desember 2005 Del Skrevet 1. desember 2005 Hei, har installert Enemy Territory på ubuntu. Når jeg startet det ved å skrive et i terminalen, Blinker det en svart skjerm, og spillet avsluttes, Her er outputen: ET 2.55 linux-i386 May 27 2003 ----- FS_Startup ----- Current search path: /home/stian/.etwolf/etmain /usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files) /usr/local/games/enemy-territory/etmain/mp_bin.pk3 (4 files) /usr/local/games/enemy-territory/etmain ---------------------- 3729 files in pk3 files execing default.cfg couldn't exec language.cfg couldn't exec autoexec.cfg Hunk_Clear: reset the hunk ok ------- Input Initialization ------- Joystick is not active. ------------------------------------ Bypassing CD checks ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- ...loading libGL.so.1: Initializing OpenGL display ...setting mode 4: 800 600 Using XFree86-VidModeExtension Version 2.2 XF86DGA Mouse (Version 2.0) initialized XFree86-VidModeExtension Activated at 1280x800 Using 8/8/8 Color bits, 16 depth, 0 stencil display. GL_RENDERER: Mesa GLX Indirect *********************************************************** You are using software Mesa (no hardware acceleration)! Driver DLL used: libGL.so.1 If this is intentional, add "+set r_allowSoftwareGL 1" to the command line when starting the game. *********************************************************** ...WARNING: could not set the given mode (4) Initializing OpenGL display ...setting mode 3: 640 480 Using XFree86-VidModeExtension Version 2.2 XF86DGA Mouse (Version 2.0) initialized XFree86-VidModeExtension Activated at 1280x800 Received signal 11, exiting Noen som aner hva jeg kan gjøre? Lenke til kommentar
olear Skrevet 1. desember 2005 Del Skrevet 1. desember 2005 Feilmeldingen sier seg selv, du har ikke støtte for 3D. Lenke til kommentar
Stian89 Skrevet 1. desember 2005 Forfatter Del Skrevet 1. desember 2005 Har jo installert grafikk driverne jo..må vel ha jort noe kraftig feil Lenke til kommentar
Stian89 Skrevet 1. desember 2005 Forfatter Del Skrevet 1. desember 2005 Har fulgt driver installasjons guide til punkt og prikke, uten å få noen error meldinger, og etter at jeg gikk igjennom installasjonen, har det bl.a gått hakk-fritt å se film. Men det virker altså som at jeg ikke har drivere? Hvordan kan man "sjekke" om de fungerer som de skal. Må de evt "aktiveres" no sted? Lenke til kommentar
olefiver Skrevet 2. desember 2005 Del Skrevet 2. desember 2005 (endret) Har fulgt driver installasjons guide til punkt og prikke, uten å få noen error meldinger, og etter at jeg gikk igjennom installasjonen, har det bl.a gått hakk-fritt å se film. Men det virker altså som at jeg ikke har drivere? Hvordan kan man "sjekke" om de fungerer som de skal. Må de evt "aktiveres" no sted? 5236872[/snapback] Åssen kort er det?Det kan hjelpe om du poster xorg.conf EDIT: Hm, så nå du har en annen tråd der du spør hvordan å få opp mobility radeon 9200 på Ubuntu. Da er det vel ATI da ATI is not my forte. Men det vil sikkert hjelpe å få se xorg.conf. Følger jeg en guide og noe ikke funker, går jeg gjerne gjennom guiden et par ganger til... Endret 2. desember 2005 av olefiver Lenke til kommentar
Palme Skrevet 2. desember 2005 Del Skrevet 2. desember 2005 Du kan jo alltids prøve å: 1: åpne en terminal 2: ta backup av xorg.conf med å: sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf_backup 3: redigere xorg.conf sudo gedit /etc/X11/xorg.conf 4: sjekke om driveren som er valgt er "ati" eller "fglrx" (ser ca. slik ut:) Section "Device" Identifier "RADEON 9200 ATI (jall ball)" Driver "ati" BusID "PCI:1:0:0" EndSection 5: eventuelt prøve å skifte "ati" til "fglrx" 6: save and exit, trykk ctrl + alt + backspace Lenke til kommentar
olear Skrevet 2. desember 2005 Del Skrevet 2. desember 2005 Hvis ikke ATI-driveren er installert så skal du fremdeles ha 3D (gjennom Radeon-driveren). Regner med at det er noe feil i xorg.conf. Lenke til kommentar
Stian89 Skrevet 2. desember 2005 Forfatter Del Skrevet 2. desember 2005 Her er xorg.conf fila mi, er det noe jeg kan gjøre for å få grafikk driverne til å fungere? Og av en eller annen grunn tror pcen at jeg har et 9000 kort, når jeg egentlig har et 9200 kort. # /etc/X11/xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" FontPath "/usr/share/X11/fonts/misc" FontPath "/usr/share/X11/fonts/cyrillic" FontPath "/usr/share/X11/fonts/100dpi/:unscaled" FontPath "/usr/share/X11/fonts/75dpi/:unscaled" FontPath "/usr/share/X11/fonts/Type1" FontPath "/usr/share/X11/fonts/CID" FontPath "/usr/share/X11/fonts/100dpi" FontPath "/usr/share/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load "GLcore" Load "i2c" Load "bitmap" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "InputDevice" Identifier "Synaptics Touchpad" Driver "synaptics" Option "SendCoreEvents" "true" Option "Device" "/dev/psaux" Option "Protocol" "auto-dev" Option "HorizScrollDelta" "0" EndSection Section "Device" Identifier "ATI Technologies, Inc. Radeon Mobility 9000 M9 (R250 Lf)" Driver "fglrx" BusID "PCI:1:0:0" EndSection Section "Monitor" Identifier "Generic Monitor" Option "DPMS" Modeline "1280x800@60" 83.91 1280 1312 1624 1656 800 816 824 841 EndSection Section "Screen" Identifier "Default Screen" Device "ATI Technologies, Inc. Radeon Mobility 9000 M9 (R250 Lf)" Monitor "Generic Monitor" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1280x800" EndSubSection SubSection "Display" Depth 4 Modes "1280x800" EndSubSection SubSection "Display" Depth 8 Modes "1280x800" EndSubSection SubSection "Display" Depth 15 Modes "1280x800" EndSubSection SubSection "Display" Depth 16 Modes "1280x800" EndSubSection SubSection "Display" Depth 24 Modes "1280x800" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" InputDevice "Synaptics Touchpad" EndSection Section "DRI" Mode 0666 EndSection Takker for all hjelp:) Lenke til kommentar
olear Skrevet 2. desember 2005 Del Skrevet 2. desember 2005 Ser ikke noe som er feil. Sikker på at driveren er rett installert? Hva om du skriver 'radeon' istedenfor 'fglrx'? 9000-9200 er basert på 8500, så om kortet ditt blir identifisert som en 9000 har ikke noe å si. Lenke til kommentar
Palme Skrevet 2. desember 2005 Del Skrevet 2. desember 2005 hva sier fgl_glxgears ? du skal vel ca. ha 400 - 500 visst alt er ok. Lenke til kommentar
Stian89 Skrevet 2. desember 2005 Forfatter Del Skrevet 2. desember 2005 prøvde med radeon istenfor fglrx, da greide ikke x å starte.. andre muligheter å prøve? Lenke til kommentar
Palme Skrevet 2. desember 2005 Del Skrevet 2. desember 2005 prøvde du fgl_glxgears ? Lenke til kommentar
Stian89 Skrevet 2. desember 2005 Forfatter Del Skrevet 2. desember 2005 Prøvde, men fikk dette resultatet: X Error of failed request: BadMatch (invalid parameter attributes) Major opcode of failed request: 143 (GLX) Minor opcode of failed request: 5 (X_GLXMakeCurrent) Serial number of failed request: 32 Current serial number in output stream: 32 Lenke til kommentar
comicz Skrevet 5. desember 2005 Del Skrevet 5. desember 2005 glxinfo | grep render Lenke til kommentar
