hvordan innstallere codecs på linux?
sudo apt-get install gstreamer0.8-plugins gstreamer0.8-plugins-multiverse gstreamer0.8-ffmpeg
Reading package lists... Done
Building dependency tree... Done
Package gstreamer0.8-plugins is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package gstreamer0.8-plugins has no installation candidate
kan det vøre feilen? kom i terminal tingen
Endret av norma_saw
Du må legge til multiverse også for å få den, hvis du ikke får det til, kan du gjøre det manuelt "sudo gedit /etc/apt/sources.list", den skal se nøyaktig slik ut:
# deb cdrom:[ubuntu 5.10 _Breezy Badger_ - Release i386 (20051012)]/ breezy main restricted
deb http://no.archive.ubuntu.com/ubuntu breezy main restricted
deb-src http://no.archive.ubuntu.com/ubuntu breezy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://no.archive.ubuntu.com/ubuntu breezy-updates main restricted
deb-src http://no.archive.ubuntu.com/ubuntu breezy-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://no.archive.ubuntu.com/ubuntu breezy universe
deb-src http://no.archive.ubuntu.com/ubuntu breezy universe
deb http://archive.ubuntu.com/ubuntu breezy multiverse
deb-src http://archive.ubuntu.com/ubuntu breezy multiverse
deb http://security.ubuntu.com/ubuntu breezy-security main restricted
deb-src http://security.ubuntu.com/ubuntu breezy-security main restricted
deb http://security.ubuntu.com/ubuntu breezy-security universe
deb-src http://security.ubuntu.com/ubuntu breezy-security universe
deb cdrom:[ubuntu 5.04 _Hoary Hedgehog_ - Release i386 (20050407)]/ hoary main restricted
## Uncomment the following two lines to fetch updated software from the network
deb http://no.archive.ubuntu.com/ubuntu hoary main restricted
deb-src http://no.archive.ubuntu.com/ubuntu hoary main restricted
## Uncomment the following two lines to fetch major bug fix updates produced
## after the final release of the distribution.
deb http://no.archive.ubuntu.com/ubuntu hoary-updates main restricted
deb-src http://no.archive.ubuntu.com/ubuntu hoary-updates main restricted
## repository.
## team.
deb http://no.archive.ubuntu.com/ubuntu hoary universe
# deb-src http://no.archive.ubuntu.com/ubuntu hoary universe
# deb http://security.ubuntu.com/ubuntu hoary-security main restricted
deb-src http://security.ubuntu.com/ubuntu hoary-security main restricted
deb http://security.ubuntu.com/ubuntu hoary-security universe
deb-src http://security.ubuntu.com/ubuntu hoary-security universe
sånn er min... hva må jeg gjære?
Installere multimediacodecs fra terminal i ubuntu hoary:
sudo cp /etc/apt/sources.list /etc/apt/sources.list_backup
bytt ut til:
deb http://us.archive.ubuntu.com/ubuntu hoary main restricted
deb-src http://us.archive.ubuntu.com/ubuntu hoary main restricted
deb http://us.archive.ubuntu.com/ubuntu hoary-updates main restricted
deb-src http://us.archive.ubuntu.com/ubuntu hoary-updates main restricted
## repository.
## team.
deb http://us.archive.ubuntu.com/ubuntu hoary universe
deb-src http://us.archive.ubuntu.com/ubuntu hoary universe
deb http://archive.ubuntu.com/ubuntu hoary multiverse
deb-src http://archive.ubuntu.com/ubuntu hoary multiverse
deb http://archive.ubuntu.com/ubuntu hoary-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu hoary-backports main restricted universe multiverse
oppdater ved hjelp av «sudo apt-get update» og installer:
sudo apt-get install gstreamer0.8-lame
sudo apt-get install gstreamer0.8-ffmpeg
sudo apt-get install w32codecs
sudo apt-get install libdivx4linux
sudo apt-get install lame
sudo apt-get install sox
sudo apt-get install ffmpeg
sudo apt-get install mjpegtools
sudo apt-get install vorbis-tools
gst-register-0.8
(alt er henta og modifisert fra ubuntuguide.org (ikke oppdatert til breezy pga sjukdom hos forfatteren).)
edit: det finnes likevell en ubuntuguide for breezy, den finner du her: http://ubuntuguide.squarecows.com/
Endret av dabear
  • 2 uker senere...
