Amriden Skrevet 29. november 2005 Del Skrevet 29. november 2005 (endret) Hva er egentlig forskjellen? Kort A Kort B Endret 30. november 2005 av Amriden Lenke til kommentar
Amriden Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 Virkelig ingen som vet? Må da være en grunn til prisforskjellen på 120,- Lenke til kommentar
Thombr86 Skrevet 30. november 2005 Del Skrevet 30. november 2005 DVI-I er kombinert, altså du kan sette på en overgang og hente ut analogt signal... DVI-D er ren digital, kan ikke bruke overgang... Det er iallefall min erfaring... Lenke til kommentar
PerB Skrevet 30. november 2005 Del Skrevet 30. november 2005 Funnet på nettet (google): DVI connection can be one of three types - DVI-I, DVI-D or DVI-A. DVI-I: DVI-I contains both the digital and analog connections, (DVI-D + DVI-A) , it's essentially a combination of DVI-D and DVI-A cables within one cable. DVI-D: DVI-D (like DFP or P&D-D (EVC)) is a digital only connection. If both devices being connected support a Digital DVI connection (DVI-I or DVI-D compatible) and are compatible in resolutions, refresh rates and sync, using a DVI-D cable will ensure that you are using a digital connection rather than an analog connection, without playing around with settings to assure this. DVI-A: DVI-A is really rare. Why use a DVI connector when you can use a cheaper VGA connector? see DVI-I P&D-A (EVC) is more common with projectors, and you should go to your projector manufacturer for recommendations. Dual Link: Dual T.D.M.S. (transition minimized differential signaling) "links". DVI can have up to two TMDS links. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels per second. Dual-link connections provide bandwidth for resolutions up to 2048 x 1536p. Single Link: Single T.D.M.S. link. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels per second. Bandwidth for a single-link connection supports resolutions of over 1920 x 1080 at 60 Hz (HDTV). Dual link vs Single Link: Don't believe the "hype" some websites are using about dual link cables being superior to single link cables. A single link cable is 100% as good as a dual link cable for single link equipment which covers about 99.5% of current equipment, including HDTV's, Projectors, Plasma Screens, and High Definition Set top Boxes. A better quality cable is a better quality cable, and single and dual link has nothing to do with quality. On the other hand, if both devices being connected support Dual links, then a dual link cable is the proper cable for the application, and you will have the capability of much greater resolutions and refresh rates. A properly designed Dual link cable should have no negative effects when used with single link equipment. Lenke til kommentar
JoKr Skrevet 30. november 2005 Del Skrevet 30. november 2005 (endret) Jupps, enig meg ham over - DVI-I bærer både digitale og analoge signaler - hvis DVI-I er en fordel hvis du vil ha muligheten til å koble til gamle skjermer som ikke støtter DVI-D. Men i dette tilfellet er det jo bortkastet - ettersom det allikvel er en 15pin VGA kontakt på - med mindre du vil kjøre en dual screenløsning med 2 stk skjermer som skal kjøre på analoge signaler. edit: han over var p.t. : BrAtTeRn Endret 30. november 2005 av JoKr Lenke til kommentar
MCPC.no Skrevet 30. november 2005 Del Skrevet 30. november 2005 Det spørs om ikke hele DVI-D og DVI-I er en skrivefeil. Forskjellen på de to kortene er i hvert fall at det ene har 128MB minne, mens det andre har 256MB minne... Lenke til kommentar
spaakh Skrevet 30. november 2005 Del Skrevet 30. november 2005 (endret) sakset fra wipipedia.org: DVI-D (digital only)DVI-A (analog only) DVI-I (digital and analog) Det vil vel i praksis si at man ikke kan koble til analoge skjermer på en DVI-D utgang (i motsetning til DVI-I). edit: whops, litt sen der ja Endret 30. november 2005 av spaakh Lenke til kommentar
Amriden Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 Takk for svar. Da blei det litt enklere her. Ram mengden har ikke noe å si for meg, skal stå i en HTPC som det helt sikkert ikke skal spilles på. Lenke til kommentar
