Sette opp vncserver - LØST
Bare glem det, jeg fikk opp port 9500 på ett eller annet vis :dontgetit:
Jeg prøver å sette opp VNC her, men får noen feilmeldinger underveis:
hakon@ubuntu:~$ hakon@ubuntu:~$ vncserver -httpport 22 -depth 8
Couldn't start Xtightvnc; trying default font path.
Please set correct fontPath in the vncserver script.
Couldn't start Xtightvnc process.
25/11/05 18:27:37 Xvnc version 3.3.tight1.2.9
25/11/05 18:27:37 Copyright (C) 1999 AT&T Laboratories Cambridge.
25/11/05 18:27:37 Copyright (C) 2000-2002 Constantin Kaplinsky.
25/11/05 18:27:37 All Rights Reserved.
25/11/05 18:27:37 See http://www.uk.research.att.com/vnc for information on VNC
25/11/05 18:27:37 See http://www.tightvnc.com for TightVNC-specific information
25/11/05 18:27:37 Desktop name 'X' (ubuntu:1)
25/11/05 18:27:37 Protocol version supported 3.3
25/11/05 18:27:37 Listening for VNC connections on TCP port 5901
Font directory '/usr/X11R6/lib/X11/fonts/Type1/' not found - ignoring
Font directory '/usr/X11R6/lib/X11/fonts/Speedo/' not found - ignoring
Font directory '/usr/X11R6/lib/X11/fonts/misc/' not found - ignoring
Font directory '/usr/X11R6/lib/X11/fonts/75dpi/' not found - ignoring
Font directory '/usr/X11R6/lib/X11/fonts/100dpi/' not found - ignoring
Fatal server error:
could not open default font 'fixed'
25/11/05 18:27:38 Xvnc version 3.3.tight1.2.9
25/11/05 18:27:38 Copyright (C) 1999 AT&T Laboratories Cambridge.
25/11/05 18:27:38 Copyright (C) 2000-2002 Constantin Kaplinsky.
25/11/05 18:27:38 All Rights Reserved.
25/11/05 18:27:38 See http://www.uk.research.att.com/vnc for information on VNC
25/11/05 18:27:38 See http://www.tightvnc.com for TightVNC-specific information
25/11/05 18:27:38 Desktop name 'X' (ubuntu:1)
25/11/05 18:27:38 Protocol version supported 3.3
25/11/05 18:27:38 Listening for VNC connections on TCP port 5901
Fatal server error:
her var det veldig mye font-feil, men det er ikke så farlig, for "vncviewer localhost" eller "vncviewer 192.168.1.199" funker fint. jeg skulle bare ha endra listening port fra 5901 til en annen port jeg har åpen. Den vrange rutern min nekter å la seg åpne, men jeg har port 22 og 80 åpne fra før. Kan jeg få brukt dem?
da funker ikke vncviewer localhost:22, og det står jo at den lytter på port 5901 fortsatt. da funker selvsagt heller ikke vncviewer ******.homeip.net:22, da bare står den og jobber, men hvis jeg bytter ut
......:22
med
....:5901
nekter den meg tilkobling med en gang.
Det jeg syns er rart er at vncviewer localhost:5901 ikke funker når det er port 5901 den lytter på. fjerner jeg porten i den koden funker det, men betyr det at den bruker en annen port? vncviewer localhost:5900 funker, men da lytter den vel ikke på port 5901? :hmm: vncviewer ****.homeip.net:5900 funker ikke. Alt i alt er jeg ganske forvirra her. Og hvordan kan jeg stoppe vncservern? den går videre selv om jeg lukker terminalvinduet.
hadde jeg fått nytta ut listening port 5901 med 22 eller 80 kan jeg ikke skjønne annet enn at det burde funke glatt. Noen forslag?
EDIT: Ubuntu er distroen :)
Endret av hockey500
