<Andtho/> Skrevet 25. november 2005 Del Skrevet 25. november 2005 (endret) Nytt oppsett: CPU: Manufacturer: AMD Family: AMD Athlon 64 3700+ Architecture: 32-bit Internal Clock: 2.2 GHz @ 2.4 Ghz Internal Clock Maximum: 3.7 GHz Socket Designation: Socket 939 Type: Central External Clock 220Mhz Skjermkort: Nvidia Geforce 6800 GS Manufacturer: Nvidia Total Local Video Memory: 256 MB Total Local Texture Memory: 256 MB VGA memory Clock 1.1Ghz VGA core clock 11.3Mhz Hovedkort: Supported Slot Types: ISA, PCI, Manufacturer: Asustec computer inc Model: A8N-E BIOS Version: ACPI BIOS revision 1008 BIOS Release Date: 22.08.05 BIOS Properties: Plug and Play, Flash OS: Operating System: Microsoft Windows XP Version: 5.1.2600 Service Pack: Service Pack 2 Windows Environment: 32-bit Locale: NO Desktop Width: 1280 px Desktop Height: 1024 px Desktop BPP: 32 b Minne er foreløpig det samme som på det gamle oppsettet, men regner med at det kommer to 512 brikker til snart.. Edit: Dette er det gamle oppsettet: CPU: Manufacturer: AMD Family: AMD Athlon XP 2200+ Architecture: 32-bit Internal Clock: 1.8 GHz Internal Clock Maximum: 1.8 GHz External Clock: 133.0 MHz Socket Designation: Socket A Type: Central Skjermkort: RADEON 9800 SERIES Manufacturer: ATI Technologies Inc. Total Local Video Memory: 256 MB Total Local Texture Memory: 256 MB Total AGP Memory: 128 MB Minne: Memory Slot 1/2 Installed Enabled Size: 512 MB Form Factor: DIMM Frequency: 333.0 MHz Slot: A0 Enabled Size: 512 MB Total Bit Width: 64 b Data Bit Width: 0 b Memory Slot 2/2 Installed Enabled Size: 512 MB Form Factor: DIMM Frequency: 400.0 MHz Slot: A1 Enabled Size: 512 MB Total Bit Width: 64 b Data Bit Width: 0 b Hovedkort: Supported Slot Types: ISA, PCI, AGP Manufacturer: Gigabyte Technology Co., Ltd. Model: GA-7VM400M BIOS Vendor Award: Software International, Inc. BIOS Version GBT - 42302e31 BIOS Release Date: 09/08/04 BIOS Properties: Plug and Play, Flash, AGP Revision: 3.5 Rate: 4x, 8x (8x enabled) Available Rate: 0x0000000c Selected Rate: 0x00000008 Aperture Size: 0 B Sideband Addressing supported (enabled) Fast Write: not supported OS: Operating System: Microsoft Windows XP Version: 5.1.2600 Service Pack: Service Pack 2 Windows Environment: 32-bit Locale: NO Desktop Width: 1280 px Desktop Height: 1024 px Desktop BPP: 32 b Noen som kan hjelpe med å overklokke CPUen min? Når jeg går inn på BIOS via DEL ved oppstart finner jeg ingen av de tingene som står rundt om på nettet, der man skrur opp multiplier osv.. Har Nyeste BIOS til CPUen.. Hva kan jeg gjøre eller prøve? Mvh. AnDtHo Endret 3. januar 2006 av AnDtHo Lenke til kommentar
eternal Skrevet 26. november 2005 Del Skrevet 26. november 2005 Vet at noen gigabyte kort har en tastekombinasjon for å få tilgang til advanced settings. Forsøkt manualen? MP/FSB settings pleier å ligge under Advanced Chipset Settings elns. Når du kommer inn i bios får du opp en del valg. Under disse igjen ligger selve instillingene. Lenke til kommentar
<Andtho/> Skrevet 26. november 2005 Forfatter Del Skrevet 26. november 2005 Vet at noen gigabyte kort har en tastekombinasjon for å få tilgang til advanced settings. Forsøkt manualen? MP/FSB settings pleier å ligge under Advanced Chipset Settings elns. Når du kommer inn i bios får du opp en del valg. Under disse igjen ligger selve instillingene. 5209131[/snapback] Fullgte ikke med noen manual på hovedkortet, bare en på selve pcen samlet.. Jeg har vært inne på BIOS og funnet Vcore osv, men jeg får ikke muligheten til å stille noe på det.. Var også bare to valgmuligheter på Hastighet, jeg kunne ikke stille noe der helle.. Skal ta et bilde av det, så er det lettere å skjønne hva jeg mener.. Lenke til kommentar
eternal Skrevet 26. november 2005 Del Skrevet 26. november 2005 (endret) best det ja. ofte man må velge user defined eller manual på sånne instillinger som du nevner der. Da "åpner" det seg opp dvs felter som var skygget ut blir hvit/gul og man kan justere. Endret 26. november 2005 av eternal Lenke til kommentar
<Andtho/> Skrevet 26. november 2005 Forfatter Del Skrevet 26. november 2005 Sånn ser menyen hvor Vcore og ligende ligger, jeg har prøvd å bytte til enabled øverst der for å åpne muligheten for å forandre på noe, jeg lagrer og går ut.. Men neste gang jeg kommer inn igjen står den like fordømt på "Disabled".. Her er menyen for frequency og voltage control, her er det fint lite jeg kan gjøre om på.. Finn ingen FSB multiplier feks.. På CPU clock har jeg bare muligheten til å bytte mellom 133 og 166Mhz og på DRAM clock har jeg bare to valgmuligheter også.. Men dette er standard innstillinger, blir ikke mye overklokking av dette.. Hva gjør jeg? Lenke til kommentar
eternal Skrevet 26. november 2005 Del Skrevet 26. november 2005 Fant manual til HKet ditt http://www.dalco.com/PDFs/70873_manual.pdf På side 32 ser jeg at du har Frequency/coltage setting i biosen din. Her inne finner du det du er ute etter. Ganske dekkende den manualen så du finner sikkert mye inni der. Lenke til kommentar
<Andtho/> Skrevet 26. november 2005 Forfatter Del Skrevet 26. november 2005 (endret) Fant manual til HKet ditt http://www.dalco.com/PDFs/70873_manual.pdf På side 32 ser jeg at du har Frequency/coltage setting i biosen din. Her inne finner du det du er ute etter. Ganske dekkende den manualen så du finner sikkert mye inni der. 5210128[/snapback] Okey, takk! Lette litt selv, men fant ingenting fornuftig.. Edit: På nettet altså! hehe.. Linken du ga meg hjalp meg MYE!! :!: Endret 26. november 2005 av AnDtHo Lenke til kommentar
<Andtho/> Skrevet 26. november 2005 Forfatter Del Skrevet 26. november 2005 (endret) Etter å ha lest igjennom manualen viste det seg at det følger med at program for overklokking på HKet mitt.. Det var ikke med når jeg kjøpte pcen.. La inn det nå, funker som bare det! :dribble Edit: Programmet heter Easytune og er kompatibelt på nesten alle AMD kort, greit å vite for andre som sliter med samme problemet.. Klokker nå 2010.27Mhz og det er stabilt, skal forske litt mer senere.. Endret 26. november 2005 av AnDtHo Lenke til kommentar
<Andtho/> Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 Vel.. Da har det dukket opp et annet problem.. Jeg kan stille opp Mhz på CPU klokka, men jeg kan ikke juster verken Vcore eller Multiplier.. Hmm.. merkelig.. Noen som vet hvorfor? Lenke til kommentar
eternal Skrevet 30. november 2005 Del Skrevet 30. november 2005 snakker du om easytune programmet eller? er vanlig at man må i bios for å stille inn vcore ihvertfall. og et tips... når du har nådd maks overklokk i det tune programmet ditt, så lagrer du endringene i bios. du kan også se om du når lengre med bios enn programmet. Lenke til kommentar
<Andtho/> Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 snakker du om easytune programmet eller? er vanlig at man må i bios for å stille inn vcore ihvertfall. og et tips... når du har nådd maks overklokk i det tune programmet ditt, så lagrer du endringene i bios. du kan også se om du når lengre med bios enn programmet. 5231075[/snapback] Stemmer det.. Men pcen blir veldig ustabil over 1950Mhz med det programmet.. Kjipe greier egentlig.. Vet om folk som klokker stabile 2200Mhz med omtrent samme pc-oppsett.. CPUen blir ikke varm heller.. Rundt 35 grader uansett hva jeg gjør.. Har fått åpnet "case" i BIOS Der hvor det står "case opened: NO" på bildet, der står det nå "YES".. Men finner likevel ikke noe sted hvor jeg kan stille multiplier eller Vcore.. I easytune er multiplier låst på 12.5.. Lenke til kommentar
eternal Skrevet 30. november 2005 Del Skrevet 30. november 2005 (endret) du er inne på pc heath status menyen. denne inneholder bare måleverdier på temperatur og spenninger. hvis du skal justere parameterne som justerer vcore, vmem osv gir det utslag her inne. tenk på det som et integrert multimeter og termometer. i manualen ser jeg det står frequency/voltage control. der inne gjør du selve valgene om å justere spenningene. Endret 30. november 2005 av eternal Lenke til kommentar
<Andtho/> Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 (endret) du er inne på pc heath status menyen. denne inneholder bare måleverdier på temperatur og spenninger. hvis du skal justere parameterne som justerer vcore, vmem osv gir det utslag her inne. tenk på det som et integrert multimeter og termometer. i manualen ser jeg det står frequency/voltage control. der inne gjør du selve valgene om å justere spenningene. 5231287[/snapback] Nope! Er fortsatt samme driten som før.. Har bare noen forhåndsprogrammerte innstillinger å velge mellom.. Kan jo sjekke igjen for sikkerhets skyld.. :!: Endret 30. november 2005 av AnDtHo Lenke til kommentar
<Andtho/> Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 (endret) Denne menyen dukket opp etter ny flash av bios.. Her er det helle ingen mulighet for å justere Vcore eller multiplier.. Frequency/voltage control er det samme som bildet over her.. Endret 30. november 2005 av AnDtHo Lenke til kommentar
eternal Skrevet 30. november 2005 Del Skrevet 30. november 2005 Står i manualen: FAQ question 1: I cannot see some options that were included in previous BIOS after updating BIOS. Why? Some advanced options are hidden in new bios version. Please press CTRL and F1 keys after entering BIOS menu and you will be able to see these options. Lenke til kommentar
eternal Skrevet 30. november 2005 Del Skrevet 30. november 2005 prøv å få DRAM CAS latency ned på 2 bank interleave la stå på 4. trp tras trcd så lav som mulig. men cas er viktigst. dram command rate ned i 1 viktig! agp fastwrite AV! er et par der jeg ikke husker på strak arm da det ikke er likt i alle bioser. men se her for forklaring: http://www.rojakpot.com/default.aspx?location=1 dette er instillinger som har mye å si. cas2 istedet for cas3 er ofte viktigere enn noen ekstra mhz på cpu. (og gjør du det riktig, får du begge deler Men vær obs på at jo høyere FSB du kjører, jo mer krav stilles til minnet når det gjelder instillinger som CAS. Her gjelder det å finne balansegangen som gir best ytelse. Du har kanskje en multiplier (MP) lock på cpu. dermed kan du kun øke fsb for å øke cpu hastighet. jo høyere FSB, jo høyere ytelse. denne må fjernes fysisk og det kan være litt tricky hvis du ikke har gjort det før. kort sagt: optimalt sett skal du ha en MP opplåst cpu der du forsøker å få høyest mulig fsb/minneinstilling ratio, samt høyest cpu klokk. Lenke til kommentar
<Andtho/> Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 Står i manualen: FAQ question 1: I cannot see some options that were included in previous BIOS after updating BIOS. Why? Some advanced options are hidden in new bios version. Please press CTRL and F1 keys after entering BIOS menu and you will be able to see these options. 5231336[/snapback] Den har jeg lest.. Det var det jeg gjorde for å få menyen på det siste bildet jeg la ut.. Men den menyen kom ikke frem før jeg flasha Biosen.. Lenke til kommentar
<Andtho/> Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 prøv å få DRAM CAS latency ned på 2 bank interleave la stå på 4. trp tras trcd så lav som mulig. men cas er viktigst. dram command rate ned i 1 viktig! agp fastwrite AV! er et par der jeg ikke husker på strak arm da det ikke er likt i alle bioser. men se her for forklaring: http://www.rojakpot.com/default.aspx?location=1 dette er instillinger som har mye å si. cas2 istedet for cas3 er ofte viktigere enn noen ekstra mhz på cpu. (og gjør du det riktig, får du begge deler Men vær obs på at jo høyere FSB du kjører, jo mer krav stilles til minnet når det gjelder instillinger som CAS. Her gjelder det å finne balansegangen som gir best ytelse. Du har kanskje en multiplier (MP) lock på cpu. dermed kan du kun øke fsb for å øke cpu hastighet. jo høyere FSB, jo høyere ytelse. denne må fjernes fysisk og det kan være litt tricky hvis du ikke har gjort det før. kort sagt: optimalt sett skal du ha en MP opplåst cpu der du forsøker å få høyest mulig fsb/minneinstilling ratio, samt høyest cpu klokk. 5231365[/snapback] Okey, da prøver jeg det! Takk for hjelpen så langt, du er tålmodig.. hehe.. :!: Lenke til kommentar
<Andtho/> Skrevet 30. november 2005 Forfatter Del Skrevet 30. november 2005 (endret) Jeg flashet bios på nytt.. Nå kan jeg justere volten på Vcore inne i easytune programmet.. Hvor høyt er det forsvarlig å justere den? Den ligger på 1,5 standard.. Prøvde på 1,6 i stad og da fryste pcen på 2100Mhz.. Mulig det er minnet mitt som kuker det til for meg.. Skal prøve meg frem litt.. Jeg kan også justere volten på minnet, den er på 2.5 standard.. Er det lurt å justere noe på dette? Endret 30. november 2005 av AnDtHo Lenke til kommentar
eternal Skrevet 30. november 2005 Del Skrevet 30. november 2005 det er lurt ja. hold øye på temperaturen. så lenge den ikke overstiger 70 grader hadde jeg pumpet det som trengs. du når ikke farlige høyder på det hket der kan jeg tenke meg. hva var maksverdiene? samme gjelder minnet. bare kjør de på høyeste instilling. det når man beveger seg over en 1.9 med luftkjøling og over 3v på minnet at man må være forsiktig. Lenke til kommentar
