Ati Tray tool tweak guide?
Har sjekket på forumet til ATT ....så også der at noen etterlyste en guide til alle tweaks i ATT. dvs. hva de forskjellige tingene betyr, og gjør osv : ex: Z mask , Z top m.m
På twaekguides.com dekkes endel av dem i "Ati catalyst guide", men ikke alle.....
Så.... er det noen der ute som har peiling på dette programmet, og kan fortelle meg hva de forskjellige tweaks er, eller henvise til en side .... ville det vært kult...
Even
PERFORMANCE BIOS SETTINGS
Use these settings in your BIOS along with the OMEGA drivers to get the best performance possible out of your video card (this settings are not avaiable in all motherboards, use only the ones that fit your BIOS):
Fast Gate A20 Option        : ENABLED
Video BIOS shadowing        : DISABLED
Video BIOS cacheable        : DISABLED
xxxxx - xxxxx Shadow        : ALL DISABLED
IDE prefetch mode          : ENABLED
Init Display First          : AGP or PCI (SELECT YOUR CARD TYPE)
IDE HDD Block Mode          : ENABLED
IDE 32-bit transfer mode    : ENABLED
Assign IRQ for USB          : DISABLED (UNLESS YOU USE USB DEVICES)
Assign IRQ for VGA          : ENABLED
PCI/VGA palette snoop      : DISABLED
PNP OS Installed            : ENABLED (WINDOWS XP CAN HANDLE PNP BETTER THAN BIOS)
Resource Controlled By      : AUTO (UNLESS YOU WANT TO MANUALLY ASSIGN IRQs AND DMAs)
AGP aperture size          : 256 (USE LOWER VALUE IF YOU HAVE TEXTURE PROBLEMS)
AGP master 1 WS write      : DISABLED ***
AGP master 1 WS read        : DISABLED***
Bank 0/1, 2/3 DRAM timing  : TURBO ***
CPU to PCI write buffer    : ENABLED
Delayed Transaction        : DISABLED ****
DRAM speculative leadoff    : ENABLED ***
DRAM Data Integrity Mode    : NON-ECC (UNLESS YOU HAVE ECC MEMORY)
Delay DRAM read latch      : (THE LOWER, THE FASTER) ***
Fast Writes                : DISABLED (ENABLED FOR RADEON 9600 OR ATHLON64 SYSTEMS)
Memory parity/ECC check    : DISABLED ***
Passive Release            : DISABLED
PCI Concurrency            : ENABLED
PCI master 0 WS write      : ENABLED ***
RAS active time            : (THE LOWER, THE FASTER) ***
RAS to CAS delay            : (THE LOWER, THE FASTER) **
Read around write          : ENABLED
SDRAM Bank Interleave      : 4-bank/way
SDRAM CAS Latency Time      : 2 **
SDRAM cycle length          : 2 **
SDRAM Precharge control    : ENABLED
Spread spectrum (modulation): DISABLED
System BIOS cacheable      : DISABLED
Video RAM cacheable        : DISABLED
8 bit I/O Recovery Time    : 1
16 bit I/O Recovery Time    : 1
Turbo frequency            : ENABLED
**  = ONLY IF YOUR MEMORY SUPPORT IT, OTHERWISE USE THE NEXT HIGHER VALUE
***  = WILL IMPROVE SPEED BUT DECREASES STABILITY, IF YOU HAVE PROBLEMS, CHANGE IT
**** = ENABLE IF YOU EXPERIENCE PROBLEMS WITH CREATIVE SOUND CARDS
Well, that's all for the BIOS.
These settings should increase you framerates with your video card, if you want do a benchmark before and after the changes, it will give you a good idea of the gain obtained.
Good Luck!
Fant dette på www.omegadrivers.net
