AMD FX-60 to arrive in January
Åsmund@ATi
The inquirer sier de vil bli lette 15K i 3DMark05!
THE AMD FX-60 is due out in the second week of January.
Preliminary reports are that it will be a decent overclocker, early samples went to almost 3GHz on air, with little or no tweaking. If you couple it with the new NVidia 7800/512 cards, you will be easily able to break the 15K barrier in 3DMark05.
It won't be a cheap rig, but it is something a lightly trained monkey can shatter records with.
the inquirer
