avtrekkeren Skrevet 15. november 2005 Del Skrevet 15. november 2005 (endret) http://forums.creative.com/creativelabs/bo...essage.id=38276 Nye drivere, skal visst være både for 32-bits og 64-bits windows. Fixes: * Removes randomly occurring audio distortion that may occur after you install drivers and restart your computer. * Improves host CPU utilization performance when you play 3D/EAX games. * Improves the usability of the Bit-Matched Playback feature in Audio Creation Mode. * Resolves some MIDI/SoundFont® compatibility issues. * Restores EAX presets properly when you select default settings in Entertainment Mode. * Resolves the issue of a mode console sometimes not responding after you switch modes. * Restores proper functionality to the EQ sliders when you select EAX effects in Entertainment Mode. * Removes the error message that sometimes appears in THX Setup Console when you switch modes multiple times. * Resolves the issue of your computer not responding when you change the Reverb Aux effect in Audio Creation Mode. Requirements: * Microsoft® Windows® XP Professional x64 Edition or Windows XP Service Pack 2 * Sound Blaster X-Fi series audio device Note: * Creative MediaSource™ DVD-Audio Player is unavailable for Windows XP Professional x64 Edition. edit: link til nedlasting: http://files.americas.creative.com/manuald...B_2_07_0004.exe Endret 15. november 2005 av KriFos Lenke til kommentar
