Adsl detter ut kvar 6time? Entering renewing state
Internetten detter ut kvar 6 time.. ipen blir også ofte bytta :dontgetit:
Kva er "Entering RENEWING state" ?
modemet er et allied telesyn.
det blir henter automatisk config over en server som står hos ISP. men dette skal bare skje når modemet har vært av.
kjedeligt å måtte passe klokka før en laster ned hm:
noen som har hatt lignende problem? routeren er satt til å ha på samme ip 24/7
14-11-2005 10:22:19 : DHCPC: Entering RENEWING state.
14-11-2005 10:22:19 : DHCPC: T1, timeout and send DHCPREQUEST to renew the IP
14-11-2005 10:22:19 : DHCPC: Send RENEWING Request packet.
14-11-2005 10:22:19 : dhcpcInputHook: dhcpcDestCheck OK.
14-11-2005 10:22:19 : dhcpcInputHook: dhcpcXidVerify OK.
14-11-2005 10:22:19 : dhcpcInputHook: OK.
14-11-2005 10:22:19 : DHCPC: receive DHCPACK!.
14-11-2005 10:22:19 : DHCPC: IP address : 10.0.0.3
DHCP server : 10.0.0.1
DNS1 : 10.0.0.1
Gateway1 : 10.0.0.1
Lease time: 43200 sec
14-11-2005 10:22:19 : DHCPC: Entering BOUND state.
14-11-2005 16:22:19 : DHCPC: Entering RENEWING state.
14-11-2005 16:22:19 : DHCPC: T1, timeout and send DHCPREQUEST to renew the IP
14-11-2005 16:22:19 : DHCPC: Send RENEWING Request packet.
14-11-2005 16:22:19 : dhcpcInputHook: dhcpcDestCheck OK.
14-11-2005 16:22:19 : dhcpcInputHook: dhcpcXidVerify OK.
14-11-2005 16:22:19 : dhcpcInputHook: OK.
14-11-2005 16:22:20 : DHCPC: receive DHCPACK!.
14-11-2005 16:22:20 : DHCPC: IP address : 10.0.0.3
DNS1 : 10.0.0.1
Gateway1 : 10.0.0.1
14-11-2005 16:22:20 : DHCPC: Entering BOUND state.
14-11-2005 22:22:20 : DHCPC: Entering RENEWING state.
14-11-2005 22:22:20 : DHCPC: T1, timeout and send DHCPREQUEST to renew the IP
14-11-2005 22:22:20 : DHCPC: Send RENEWING Request packet.
14-11-2005 22:22:20 : dhcpcInputHook: dhcpcDestCheck OK.
14-11-2005 22:22:20 : dhcpcInputHook: dhcpcXidVerify OK.
14-11-2005 22:22:20 : dhcpcInputHook: OK.
14-11-2005 22:22:20 : DHCPC: receive DHCPACK!.
14-11-2005 22:22:20 : DHCPC: IP address : 10.0.0.3
DNS1 : 10.0.0.1
Gateway1 : 10.0.0.1
14-11-2005 22:22:20 : DHCPC: Entering BOUND state.
:hm::hm:
Det hadde hjulpet litt hvis du hadde skrevet hva slags OS du kjører og hvilken ruter du har. Hvilken ISP du bruker også.
Den "loggen" du viser utdrag fra, hvor fant du den? På PCen?
Den viser en helt normal kommunikasjon mellom en DHCP-klient og en DHCP-server. Klienten (=PCen?) får tildelt IP-adressen 10.0.0.3 fra DHCP-serveren (=ruteren din?), for et tidsrom av 43200s, som tilsvarer 12 timer.
Før denne tiden er ute, nærmere bestemt halvveis gjennom 12timers-perioden, ber DHCP-klienten om å få fornyet (=forlenget) leieperioden for nettopp den IP-adressen. Og det får den; 10.0.0.3 blir bekreftet.
Dette er helt normal nettverkstrafikk og skal ikke forårsake at du mister forbindelsen med internett. Hvis din ruter - som også fungerer som en DHCP-klient mot din ISPs DHCP-server - får en ny IP-adresse hver 6. time, er noe galt med ruteroppsett, vil jeg tro.
Tok og reseta ruteren..og nå er det andre tider...
03:15:04
09:15:04
15:15:05
21:15:07
Så er nok ruteren som har pensjonert seg
ro.JPG:hmm:
10.0.0.3 kommer fra Adsl modemet og ikke ruteren.
internett ip--->Adsl modem --->LAN1: 10.0.0.3 ----> 192.168.1.254.
så er nok Jensen routeren som begynner å bli gamel :cool:
på tide å kjøpe ny. ISP er et kraftselskapet i kommunen.
loggen ligger i Jensen ruteren, og bruker siste firmvare 3.36A
Kan det hjelpe å bruke en gammel firmware?
Du skriver at ip`n byttes, er det da ip`n routeren får av modemet ditt, eller er det ip`n som din pc får av routeren?
Skjer det hver gang du faller av nett at du får en ny ip?
Har ikke så mye greie på routere, men det høres veldig ut som problemer med routeren ja. Har du mulighet til å teste direktekobling uten en slik router en dag?
Hvis modemet ditt gir ut 10.0.03 til Jensen-ruteren, da betyr det at modemet ditt også er en ruter ...
Du kjører altså med 2 rutere i "serie" - trenger du det? (Det kan være flere grunner til å gjøre det, så jeg sier ikke at feilen ligger her.)
Med 2 rutere er det i hvert fall dobbelt så mange ting som skal konfigureres ...
Hva skjer dersom du kobler ledningen fra modemet rett inn i PC'en? Får du en stabil internett-forbindelse da?
Jeg lurer fortsatt litt på dette med at du kjører med 2 rutere ...
Er Jensen-ruteren en trådløs ruter? Er det derfor du må/vil bruke den?
Eller er det det at den har flere nettverksporter enn "modemruteren"?
I så fall bør det gå an å koble opp Jensen-ruteren på en litt annen måte slik at du bare bruker den som switch og trådløst aksesspunkt. Da vil det være "modemruteren" som fungerer som DHCP-server i nettverket ditt og du vil få 10.0.0.xxx-adresser på PC'en(e).
Det er 4 lan porter på modemet, men bare Lan1 virker til internett! lan2,3,4 er til
ip-telefon/digitaltv og virker ikke (har testet)
linja er delt på 3 stk så det er grunn til eg bruker ruteren, og den er ikke trådløs.
men siden tiden endret seg etter restart av ruteren, så virker det som det er der feil ligg!
:hmm:
DHCPC: IP address : 10.0.0.2 (adsl modem)
DNS1 : 10.0.0.1
Gateway1 : 10.0.0.1
Lease time: 43200 sec <----- kommer denne fra adsl modemet ?
bilde over med "Lease time" er jo LAN - DHCP Server
Vis eg plugger adsl modemet rett i pcen får eg ipen 10.0.0.2/3
så det er en DHCP server i modemet også
Hmmm ...
Du trenger jo bare en eneste DHCP-server i nettverket ditt, og strengt tatt kunne du da greid deg med en switch istedenfor Jensen-ruteren. (Om jeg ikke har gått helt av skaftet her nå da.)
En ting du kan prøve er:
1. Slå av DHCP-serveren i Jensen-ruteren
2. Slå av Jensen-ruteren
3. Flytt kabelen fra modemet fra WAN-porten på Jensen-ruteren til en av LAN-portene. (En av de 4.) NB! Det kan hende du må bruke en krysset kabel her, men de fleste nyere bokser finner ut av dette selv.
4. Slå på Jensen-ruteren.
5. Se hva slags IP-adresse du får på PC'en(e) nå. Det burde være 10.0.0.x.
Jeg har satt opp en 3Com ruter/Aksesspunkt på denne måten hos en jeg kjenner, og det fungerer der, men det er jo ingen garanti for at det vil virke hos deg. Hvis DHCP-serveren i modem-ruteren din er satt opp til kun å dele ut et lite antall IP-adresser - kanskje færre enn antall PC'er i nettet ditt -, da har du trøbbel.
Men, hvis dette virker, så bruker du altså bare switch-delen av Jensen-ruteren din. Hvis du en gang skulle trenge flere porter, så kan du bytte ut Jensen med en 8-porters switch, f.eks. (Hey, det var du som sa at den var gammel!)
Steve Gibson har laget et par gode orienteringer om dette med rutere og NAT og greier, først og fremst fra et sikkerhets-synspunkt, men det var ganske bra forklart på alle punkter, synes jeg:
http://grc.com/nat/nat.htm
http://grc.com/nat/nats.htm
(Du finner vel ikke noe direkte svar på dine spørsmål her, men av og til er det artig å lese en velskrevet guide ... Når ingenting annet virker.)
