Musematte til lasermus? Sjekk her!
Detailed information about the 5 layers:
* 1. Plastic coating
Thin plastic coating ensures durability and maintains the texture of the underlying cloth material.
* 2. Cloth
A highly durable and extremely strong cloth material provides a smooth gliding experience. The texture of the plastic coated cloth surface allows for minimal mouse movements and maximum precision.
* 3. Soft polyisoprene
Specially treated soft polyisoprene provides softness to the touch. The softness of the rubber foam is very easy on the users' wrists, even for hardcore gamers and others who use their mouse for extended periods of time.
* 4. Hard plastic
A hard plastic compound maintains the stability and the shape of the mouse pad, and helps ensure a consistent gliding experience even on uneven surfaces.
* 5. Rubber elements
Small soft rubber elements ensures complete non-slippery steadiness.
Er ikke så mye info om den ute nå, men det blir nok mer etterhvert. Tror ikke den blir så fryktelig høy, Steelpad er kjent for lave musematter. Og ja, den fungerer også glimrende til vanlige optiske mus :)
