tor-ivar.hals Skrevet 13. november 2005 Del Skrevet 13. november 2005 Antall Webpris Totalt Hauppauge! WinTV-PVR-500MCE, Tv-kort m/radio og 2stk tunere,1pak Bulk Varenr.: 305161 Lagerstatus: 3 stk på lager 1449 1449 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Sony DVD-brenner DWQ30AB2 IDE OEM Black DVD+R/+RW and DVD-R/-RW (Dual Layer) Varenr.: 313883 Lagerstatus: 14 stk på lager 395 395 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Samsung SpinPoint P120S 200GB SATA2 8MB 7200RPM NCQ Varenr.: 307912 Lagerstatus: 500+ stk på lager 850 850 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- AMD Sempron 2600+ 1.6GHz Socket 754, 128KB, 64bit, BOXED m/vifte Varenr.: 311665 Lagerstatus: 500+ stk på lager 575 575 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- MSI K8N NEO3-F, nForce4-4x,Socket-754 ATX, S-ATA/ATA, GbLAN, DDR, AGR/PCI-Ex16 Varenr.: 303749 Lagerstatus: 44 stk på lager 635 635 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Cooler Master Cavalier 4 Kabinett Sort Desktop w/350W PSU Varenr.: 309269 Lagerstatus: 39 stk på lager 895 895 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Corsair Value S PC3200 DDR-DIMM 512MB Unbuffered, Non-parity, 64Megx64, CL2.5 Varenr.: 117212 Lagerstatus: 100+ stk på lager 449 449 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- XFX GeForce FX5200 256MB DDR, AGP8X, Tv-Out/DVI, Retail Varenr.: 304716 Lagerstatus: 34 stk på lager 549 549 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Miljøgebyr: 0 Totalt: 5797 Noen kommentarer? Holder dette til å vise HDTV når den tid kommer? Lenke til kommentar
Wattengård Skrevet 13. november 2005 Del Skrevet 13. november 2005 Hauppauge! WinTV-PVR-500MCE, Tv-kort m/radio og 2stk tunere,1pak Bulk Er egentlig 2xPVR-150 stappet inn på ett PCI kort. Og PVR-150 er et godt kort. Sony DVD-brenner DWQ30AB2 IDE OEM Black DVD+R/+RW and DVD-R/-RW (Dual Layer) Denne vet jeg ikke så mye om. Har NEC 3520 eller hva den heter selv og er fornøyd med det. Men den er vel uansett ikke den viktigste delen av en htpc. Samsung SpinPoint P120S 200GB SATA2 8MB 7200RPM NCQ Sikkert grei, men alt for liten hvis du skal ta opp tv. AMD Sempron 2600+ 1.6GHz Socket 754, 128KB, 64bit, BOXED m/vifte Grei for vanlig opptak, divx, xvid etc. Men kan slite litt med vising av HDTV materiale. WMV-HD og DIVXHD har vel anbefalt P4 3.0ghz for visning av hdtv materiale. Ren TS mpeg2 er jeg usikker på. MSI K8N NEO3-F, nForce4-4x,Socket-754 ATX, S-ATA/ATA, GbLAN, DDR, AGR/PCI-Ex16 Helt greit. Cooler Master Cavalier 4 Kabinett Sort Desktop w/350W PSU Har ingen erfaring med det og syns egentlig det er ganske stygt Corsair Value S PC3200 DDR-DIMM 512MB Unbuffered, Non-parity, 64Megx64, CL2.5 Holder. Har du råd så ta en til slik en XFX GeForce FX5200 256MB DDR, AGP8X, Tv-Out/DVI, Retail Det er nevnt et Gigabyte kort basert på 6600 i en annen tråd her. Denne støtter visst alt av det nvidia kaller "purevideo", diverse former for maskinvareakselerert videoavspilling. https://www.diskusjon.no/index.php?showtopi...dpost&p=5138160 Noen kommentarer? Holder dette til å vise HDTV når den tid kommer? Som nevnt over. Tror CPU blir litt knapp til HDTV materiale. Og så ser jeg ingen lydkort? -C- Lenke til kommentar
