OpenVPN og samba
Palme
Jeg tenkte jeg skulle kjøre samba over VPN. Har prøvd å få det til, men det vil bare ikke. Har prøvd noe i denne dur med smb.conf, men tror liksom ikke det er her problemet ligger,,
smb.conf:
[global]
workgroup = kamel
netbios name = kamel
encrypt passwords = True
server string = kamel-super-server
smb passwd file = /usr/local/samba/private/smbpasswd
log file = /var/log/samba/samba.log
max log size = 200
hosts allow = 10.8.0.0/24
interfaces  = tun0
bind interfaces = yes
deadtime = 7
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
og klient.conf
#  OpenVPN Configuration for GNS Service
# Specify self as a client
client
# Use the routing method for efficiency and simplicity
dev tun
# Specify server and port to connect to
remote min-ip-til-kamel 1194
# Don't bind to a particular port locally
nobind
# Enable compression - must also be enabled on server
comp-lzo
# Security keys and certificates
ca ca.crt
cert bob.crt
key bob.key
# Route all 10.30.1.0 addresses through vpn
route 10.30.1.0 255.255.255.0
ns-cert-type server
Ligger til server-configen:
dev tun
#Tcp eller udp
proto udp
# Enable a full server on the 10.8.0.0 subnet for all clients
server 10.8.0.0 255.255.255.0
push "route 10.66.0.0 255.255.255.0"
# Write status logs in /etc/openvpn
ifconfig-pool-persist ipp.txt
status openvpn-status.log
# It's a good idea to reduce the OpenVPN
# daemon's privileges after initialization.
# You can uncomment this out on
# non-Windows systems.
user nobody
group nobody
# Launch the server explicitly on the default port
port 1194
# Enable compression - enable on client as well
comp-lzo
# Allow clients to contact each other through vpn
client-to-client
ca ca.crt
cert server.crt
key server.key
dh dh1024.pem
# Ping the clients periodically to determine connectivity
keepalive 10 120
Noen som har klart å få dette til?
Endret av Lassie
