åpne pdf fil fra flash med bat fil....
ja, da har jeg et spørsmål på engelsk her. håper det ordner seg... så slipper jeg å oversette...
I have a flash presentation that uses the whole screen like this:
fscommand("fullscreen", "true");
fscommand("showmenu", "false")
I then want to open up a pdf file at certain destinations at the pdf file. This is where it gets tricky. I am using fscommand("exec", "test.bat"); to do this, where test.bat will execute some code to open up my pdf, and this will make the pdf file come on top of my flash presentation.
the pdf lies in the same dir as the flash, and the batch files is in fscommand dir.
If I'm using this code:
- start ..\test.pdf
it will open up the pdf file in whatever pdf reader you have. very good, but I can't specify destinations or bookmarks.
- start AcroRd32.exe /A "nameddest=index" "../test.pdf"
close, this works perfectly, but I don't know for 100% sure that they have adobe reader installed..............
- start adobe.exe /A "nameddest=index" "../test.pdf"
same as above, not quite sure they have adobe professional installed........ might have
I have tried open it with getURL, didn't quite work, and it doesn't get focus....
I need some way of checking if the user have adobe reader, then use that, or else if he has adobe pro, use that, or display a message of "go here and install adobe reader".....
HELP!:) please.
Hvis dere har noen ideer, så tas alt i mot med takk...!
