Sony SonicStage 3.3 ute
# Dynamic Playlist is available.This allows you to select genres and artists of tracks and to specify the order of tracks to display, to make Playlist by Date Imported/ Rating/ Playback Count/ the Number of Transfer and the Number of Tracks/ Playback Time/ File Size, dynamically.
# New Playlist updated on My Library renews existing Playlist on an ATRAC Audio Device, transferring the Playlist to an ATRAC Audio Device.
# Ripping an Audio CD in ATRAC Advanced Lossless format is available.
According to new audio-compression technology, an Audio CD can be recorded into My Library without any sound degradation. And this new technology allows to record an Audio CD with the size of 30~80 percent with ATRAC3 or ATRAC3plus current audio-compression technology, in order to keep compatibility with current devices.
# Ripping an Audio CD in WMA format is available.
# 352kbps ATRAC3plus is now available.
Fra http://forums.minidisc.org/index.php?showtopic=12882
http://www.aii.co.jp/contents/sonic/_data/...geInstaller.exe
