Japanske kortsverd; forskjell?
Seek and ye shall find
Generally, the swords are classified by length. A daito is a sword with a blade longer than two shaku ( shaku = 11.9 inches ). A wakizashi is between one and two shaku in length, and a tanto is less than one shaku.
There are lots of other names. The most common one, katana, refers to the style most people have seen, a daito which is worn stuck through the obi (belt) with the edge up. A tachi is an older style, slightly longer and more curved, worn slung on cords with the edge down, usually used in a calvary style. A nodachi is a bigger tachi, with a very long handle, worn slung over the back for battlefield application. A kodachi is a smaller tachi. A wakizashi is also a short sword, although of a newer style (kodachi is often used as a generic term for short sword, and so may also be used to refer to a wakizashi). A chokuto, or ken, is a very old style straight sword.
