duveit Skrevet 3. november 2005 Del Skrevet 3. november 2005 Sygate ga meg beskjed om dette her nå, og jeg lurer på hva dette kunne være for? Irriterer meg at så mange programmer kontaker det ene og det andre uten at jeg kan se noe klart formål med det. File Version : 1.0.10.6 File Description : Common Client CC App (ccApp.exe) File Path : D:\Programfiler\Fellesfiler\Symantec Shared\ccApp.exe Process ID : 0x470 (Heximal) 1136 (Decimal) Connection origin : local initiated Protocol : TCP Local Address : 192.168.0.162 Local Port : 3613 Remote Name : Remote Address : 84.47.16.172 Remote Port : 25 (SMTP - Simple Mail Transfer Protocol) Ethernet packet details: Ethernet II (Packet Length: 76) Destination: 00-11-95-f0-78-23 Source: 00-0f-b5-26-d2-c5 Type: IP (0x0800) Internet Protocol Version: 4 Header Length: 20 bytes Flags: .1.. = Don't fragment: Set ..0. = More fragments: Not set Fragment offset:0 Time to live: 128 Protocol: 0x6 (TCP - Transmission Control Protocol) Header checksum: 0x9d0e (Correct) Source: 192.168.0.162 Destination: 84.47.16.172 Transmission Control Protocol (TCP) Source port: 3613 Destination port: 25 Sequence number: 3560118216 Acknowledgment number: 0 Header length: 28 Flags: 0... .... = Congestion Window Reduce (CWR): Not set .0.. .... = ECN-Echo: Not set ..0. .... = Urgent: Not set ...0 .... = Acknowledgment: Not set .... 0... = Push: Not set .... .0.. = Reset: Not set .... ..1. = Syn: Set .... ...0 = Fin: Not set Checksum: 0xc862 (Correct) Data (0 Bytes) Binary dump of the packet: 0000: 00 11 95 F0 78 23 00 0F : B5 26 D2 C4 08 00 45 00 | ....x#...&....E. 0010: 00 30 C6 05 40 00 80 06 : 0E 9D C0 A8 00 A2 54 2F | [email protected]/ 0020: 10 AC 0E 1D 00 19 D4 33 : 17 C8 00 00 00 00 70 02 | .......3......p. 0030: FF FF 62 C8 00 00 02 04 : 05 B4 01 01 04 02 CE 02 | ..b............. 0040: 00 00 05 00 00 00 64 61 : 6E 6B 65 01 | ......danke. Paranoia kan være en kilde til mye spennende Lenke til kommentar
roac Skrevet 3. november 2005 Del Skrevet 3. november 2005 Paranoia kan være en kilde til mye spennende 5100530[/snapback] Som for eksempel å finne ut at man bruker et fildelingsprogram? Disse jobber tidvis på kjente og ofte brukte porter for å sørge for å komme gjennom brannmurer. Det er da enkelte brukere der ute i verden som setter opp sine PCer til å bruke port 25 eller 110. Lenke til kommentar
duveit Skrevet 3. november 2005 Forfatter Del Skrevet 3. november 2005 (endret) Paranoia kan være en kilde til mye spennende 5100530[/snapback] Som for eksempel å finne ut at man bruker et fildelingsprogram? Disse jobber tidvis på kjente og ofte brukte porter for å sørge for å komme gjennom brannmurer. Det er da enkelte brukere der ute i verden som setter opp sine PCer til å bruke port 25 eller 110. 5100743[/snapback] Godt tenkt, når du nevner det så kjører jeg faktisk slsk, men fant det pussig at symantec var nevnt som avsender. Sygate pleier å advare om et programme kontaker nettet gjennom et annet godkjent program. Men det er jo shared.. så ja tja Endret 3. november 2005 av duveit Lenke til kommentar
PerB Skrevet 3. november 2005 Del Skrevet 3. november 2005 Virus som sprer seg via mail benytter sin egen mailklient (SMTP) slik at spredningen videre ikke er syblig i ditt mailsystem. Her er muligheten for at du er smittet av virus/trojaner eller annet fandenskap. OK å være paranoid... Lenke til kommentar
roac Skrevet 3. november 2005 Del Skrevet 3. november 2005 \Godt tenkt, når du nevner det så kjører jeg faktisk slsk, men fant det pussig at symantec var nevnt som avsender. Sygate pleier å advare om et programme kontaker nettet gjennom et annet godkjent program.Men det er jo shared.. så ja tja 5100856[/snapback] Symantec i likehet med AdAware hekter vel seg på disse portene og tar tak i all trafikk inn/ut til port 25 og 110 tenker jeg, og da vil det oppføre seg på den måten. Det ser ut som om det er mail som sendes (ved første øyekast) men er i realiteten noe ganske annet. Lenke til kommentar
